dwcraig1
Everything posted by dwcraig1
  1. Ribbon getting pinched most likely....as retird said above.
  2. A screen like this would be helpful: (SS430)
  3. My thoughts are as follows, either the wrong TCR or a horrible connection somewhere between the board and the coil. K5's are known to have a slightly shorter 510 so a wonky connection between the M - F 510 is quite possible.
  4. Ask that here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  5. In Escribe on the profile that you are using untick the box that says "Temperature Dominant" and upload settings...that shoud do it.
  6. Nothing to adjust there on a non Color 75, I had to go retrieve my wife's 75 to assist with my memory...LOL I have no 75 color so I don't know how that one is.
  7. What mod is it for?
  8. Options/ User Interface/ Manufacturer.....at top of Ecscribe.
  9. Under the "Options" tab at the top of Escribe choose "User Interface". Change it to "Manufacturer"
  10. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  11. Open a ticket with Evolv would be my best guess.
  12. One of the 3 board screws is accessed through the hole for the fire button. The small ring around the button unscrews allowing the button to be removed to get to it.
  13. Well is it a Yihi board or an EvolvDNA board? SX350J is not an Evolv product.
  14. I was able to download it here in California soon after post #2.....with Chrome.
  15. Here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  16. Voltage of cell 2 (5.24v) in 2nd picture indicates that the battery management chip on the board has gone bad. This is providing that the tap is configured as in the diagram posted above. Voltages measured off the JST plug would be: Cell #1's voltage between ground and pin 1 Cell #2's voltage between pin #1 and pin(s) 3 or 2 Voltage between pins 3/2 and ground should be the sum of both cells
  17. Well the first thing to check is what the cell voltages show in EScribe/ Device Monitor, also make sure it's set to 2 cells and not 3.............to start with. Maybe post a screen on Device Monitor. The tap should be reading pack voltage between 3 and ground.
  18. I've asked giz_60 to respond to your post. Atty resistance surely comes into play.
  19. Well then it's .009 ohms or under, probably under. SP firmware will not read under .009 ohms. So what did you set it at?
  20. Well the room/board temp is way off. It must think it's too cold to safely charge. Probably you should open a ticket with Evolv.
  21. What does voltages does EScribe say the cells are, a screen of device monitor would be helpful.
  22. 316/317 is a challenge of sorts, 430 is just well normal.
  23. I use pretty much only Unkamen's 430, but when I have had that happen to me it was wick too loose in the coil. Your cold ohms/live ohm's is consistent in both examples
  24. If it were mine I'd be looking at the wick, too loose inside the coil perhaps. Just a thought. The coil looks "electrically' the same to me.
