Everything posted by dwcraig1
Vapecice dna 75c original firmware
dwcraig1 replied to Luke's topic in EScribe, Software and Firmware
Escribe automatically makes a backup, it is located in help/ backup at the top of Escribe. Not there? -
The boards are the same as other brand mods when same firmware is used.
It is the large screen https://www.evolvapor.com/products/dna60
- 1 reply
- 2
Doesn't sound like it's the fuse. Start here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
With 2 cells powering it the maximum voltage output is reduced from 9.3 volts to 6.2 volt. If your your mod hits that limit because your wattage/resistance requires more voltage then the message appears.
The message means it's genuine but you should need to press button below 1 watt on purpose, not by it's self. Perhaps your down button is sticking for what ever reason.
I know this isn't right...Therion 166 TC issues!
dwcraig1 replied to TorturedZen's topic in DNA 200 and 250
This isn't SS316 but here is a screen with 120 watts for 0.5 seconds preheat and 45 watts after. No air, just holding the fire button down. -
My guess on this is the wick isn't keeping up with the coil, you might try dripping a bit of juice through the drip tip /top to prove/disprove this. -
DNA 250 Check Battery at 40% Help!!
dwcraig1 replied to SVapor's topic in EScribe, Software and Firmware
Just curious as to what the unloaded (standing) voltage of the cells are when they start cutting off. -
Per resistance error read here, probably the same problem. Battery CSV only effects "fuel gauge" readings and not battery performance. You might want to set your Cell Soft Cutoff to 2.8 volts if not already done. Use Escribe Device Monitor to see if your battery sag is hitting Cell Soft Cutoff, I think cell hardware cutoff is 2.85 volts so setting it lower wouldn't accomplish anything. -
Dual battery diagnostic situation
dwcraig1 replied to wxjunkie's topic in DNA 75 Color and 100 Color
For sure the problem is on the battery sled end, wiring, contacts, ect. The board has no idea how many cells as it sees it as one battery. Look for broken connection between battery contacts of the sled on either end.- 1 reply
- 1
You might try setting your soft cell cut off to 2.65 volts (3.09 is ideal for LiPo)
No compatible USB devices are connected
dwcraig1 replied to macd2point0's topic in DNA 75 Color and 100 Color
In Windows Device Monitor the USB device will show when connected, in my case it listed as "USB Composite Device", if driver problem it would indicate as such. And just in case you installed a wrong version of Escribe, DNA75C requires Escribe 2- 1 reply
- 2
Factory reset reverts the board to Evolv factory setting... not the mod's factory settings. So if your mod uses 2 cells instead of three the factory reset set it to 3. Use Escribe to change back to 2 if needed.
Paranormal Battery csv file needed
dwcraig1 replied to Smokin Dave's topic in Manuals, Instructions, and Tutorials
Battery Analyzer under-reporting parallel batteries
dwcraig1 replied to skineedog's topic in DNA 75 Color and 100 Color
Is the soft cell cutoff set to the same value on these mods? -
I've added to my last post. -
How about posting which firmware your using on the 75c? Another thing, perhaps check with using just one cell then the other to see if the results are the same for each. Have you measured each cell with a meter to see if they are discharging the same? -
Check in EScribe/Device Monitor while firing at 50 - 60 watts and look to see if the voltage drop during firing seems excessive. Decent cells with that mah should be in the area of 10 Wh each. Does the mod/batteries perform well during normal use? -
Sorry but no.
Probably, ask them here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
Dna200 reverse battery reverse protection
dwcraig1 replied to Vape Bullet's topic in DNA 200 and 250
The DNA200 has no reverse battery protection other than the fuse that will blow. Sometimes the mod manufacturer will build it into the sled. The 250 has it though. -
I use 3.09 volts for Lipo's, that's the default setting.
