dwcraig1
Everything posted by dwcraig1
  1. Connect to EScribe, tools tab, apply service pack, choose the one that you want.
  2. TC wire must be used as the board must see a resistance change on the coil from cold to hot for replay to be able to function. So Kanthal and Nichrome will not work as the resistance stays the same from cold to hot. Note: a Clapton coil for example with a TC core wrapped with Nichrome should do reply just fine.
  3. But with the DNA it's super easy to go backwards.
  4. Or just use nickle as your material and set the rest manually DNA200-Nickel_Ni200_(linear_TCR)-SteamEngine.csv
  5. Under "File/ Open", choose .ecig file and upload settings.
  6. Nichrome has no resistance change from cold to hot so the board can't figure temp, Ni200 (pure nickle) has a very large increase in resistance. If you are using Nichrome simply set desired wattage and that's it.
  7. If you know the heating element material use that and enter the other values such as wattage, ect by hand ....and upload settings. What material is the heating element?
  8. Not sure, don't think so Try removing it.
  9. select profile number and "Load Profile" button....upload settings
  10. Pick which way.... profile or material Note: the mod can only store 8 materials, materials can not be deleted if used in a profile so change to another material as needed first when the occasion arises.
  11. What is the purpose of the file? profile, battery, ect.
  12. Import it into Escribe then upload settings to mod using "up load settings" button in Escribe.
  13. I just tried it with Google Chrome browser and it didn't work. Then I tried Internet Explorer and that worked.
  14. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  15. this is the front side, you will be wanting a look at the other side. 3, 2 ,1, gnd Here's how is wired, electrically anyway
  16. Check Device Monitor when fully charged, you should expect to see voltage around 4.13 - 4.14 volts area.
  17. Look to see how they got the voltage for cell #3 to #3 on the balance tap. I have not been inside the LV 200. Wismec used a tiny resister there to jump Batt + and #3, others just solder bridged it or bridged it with wire. Your problem lies in the connection to the battery tap. (appears to anyway) Look for cold solder joints on the balance tap.
  18. sp35 is available, I believe it has the fix for that.
  19. The place that you bought it from Is your best choice for a remedy
  20. Well if you haven't done so already I would use the supplied cable on another device to make sure it works, or try another cable.
  21. Your coils are either Kanthal or Nichrome
  22. Use stainless steel or nickel or any TC wire.
  23. Use Device Monitor to check to make sure the wire's resistance changes from cold to hot. Kanthal and Nichrome will have the resistance stay the same as cold when heated, Replay will not work without the change taking place.
  24. The Escribe snipet is showing Profile #1 but the mod is set on Profile #2
