Everything posted by dwcraig1
Removing the battery and leaving it out for a minute will reboot the board, did you try that already?
I edited my post about it being the latest firmware for DNA250C, it is the latest firmware for DNA75C instead, my mistake
Have you tried flashing it back to earlier firmware?
That seems to be the latest firmware for a DNA75 C Edited
Are you able to try using a different data cable?
Some images show the board with the rails removed, here is an image with rails. Pay no attention to wire colors as they are for converting a particular mod to DNA60.
Graph looks good, with use Replay in profile checked you will be able to get a replication of the saved puff. Try heating the wire a little hotter perhaps. But not bright red.
Not actually twisting it makes it stiffer. When I'm done twisting it I heat the length of it to a slight red. I torch all my wire prior to coiling (even Tii). You could use a Bic lighter if necessary but be sure to dry fire with low wattage to burn off the black stuff. Twisted lightly really doesn't describe it, it's twisted pretty tight. This makes the 2 strands equal / near 26 gauge with lots of area for juice contact. This photo is from a couple of years ago, I twist it a bit tighter nowadays.
@RealMcCoy Could you post a snippet firing your coil in wattage mode with battery voltage also checked? In this snippet I have unchecked the "set temperature" box to avoid any confusion. This is wattage with a little boost without using Replay.
The coil used in my post is two strands of 28 gauge SS 430 twisted tightly with a drill and in a Kayfun Lite Plus.
It appears to me that you are trying to get your perfect puff in TC mode, it doesn't look like your getting a satisfactory puff to base Replay on. Try this, set your profile to "Watts" then set your wattage and Boost and upload settings, Keep making adjustments till you get that puff that you feel is right. Use my profile snip as your guide. Then save puff. On my snip the test puff is on the left. look at the live ohms to note duration as it's hard to see as it is flat 20 watts. Use Watt profile. use TC capable wire.
Dynamic Temperature Display for Vicious Ant?
dwcraig1 replied to dabberbid's topic in DNA 75 Color and 100 Color
Honestly I don't know, I've been looking for that setting on my VA Spade in Theme Designer and can't find it. Perhaps Wayneo knows and will answer, -
i have mistakenly been giving you advice for a non color board, my apologies. Wayne sent me this just now. -
Do you have this box checked/unchecked? If so uncheck or check it depending with what you want and upload settings. -
asmodus oni 167 check battery issue
dwcraig1 replied to kristine4899's topic in Batteries and Charging
It appears that you have reset the board to default values which would set it for 3 cells. Connect to eScribe and go to Mod/Battery and change from 3 cell to 2 cell and upload settings. -
I buy from here. You can refine your search on the left side of the page pretty well. https://hobbyking.com/en_us/batteries-chargers/batteries/lipo.html
You need a new battery. The voltage is way to low to safely charge it.
How do i upload pictures of my themes?
dwcraig1 replied to valdozandrew's topic in Themes and Custom Screens
This is something that I have never done till now. On the the top of forum page I choose create then file download then Theme Park. Select which DNA group. I had saved the theme to desktop using EScribe. The images are there once your post is opened.
