Everything posted by retird
Not really desirable to lock ohms but whatever works for you is what you should do.... lots of posts on this subject if you want to google them here....
5 clicks on and 5 clicks off... click rapidly....
You might review these video's about EScribe..... EScribe is used for the DNA's like yours and other boards also. Since you are new to DNA you might want to review these to learn a bit about how the device works and what Escribe is for....
Google ecigstats.org link.... https://forum.ecigstats.org/ Here is a FAC section from the .org.... https://www.ecigstats.org/faq/.
As far as I know the DNA has no way of knowing your nicotine level nor how many ml of liquid you use per day (or how much is used with each puff) and I guess you could also use different nicotine levels during the day if you have juices of different nick levels or absence of nick. You could manually measure your ML usage, it's nick level, track the number of puffs and build a spreadsheet for that data.....
Evolv only provides the circuit boards. They don't build the device. hum..... @Wayneo gave you good information...... good luck......
Do I need to lock resistance with replay?
retird replied to Adam_Aves's topic in Replay and Atomizers
Replay is Replay..... must be TC wire profile.... not Kanthal.... -
Start a ticket with Evolv and explain just what you did here and they will guide you. (link below for help desk) If it was new and DOA from where you bought it why not just get it replaced under their DOA warranty since you are in Europe?
The Q pods are not designed to use on the Orion but some use them... I think they adjust the watts, boost and warmth but from what I'm told they won't work very well and they don't Replay on the Orion at all..... I don't use them on the Orion. Maybe someone that has used the Q pods on the Orion can pop in and provide some first hand info.... previous version of software will make no difference..... I hid your duplicate post.... no need to post multiple posts.... welcome to the forum....
The web site says they have this: ELECTRICAL DEVICES WITH NO BATTERIES INCLUDED: Where applicable these will be subject to Consumer law and a 12 month warranty And here is their contact phone numbers... why not call them? https://www.esauce.co.uk/index.php?route=information/contact
Do let us know what Evolv says.....
You have to disassemble the device (usually voids warranty). I googled repair for your device and found this for your device (located in UK). You might contact them and explain the issue and ask for info if nobody pops in here to help.... https://www.esauce.co.uk/rebel-repair-service-rebrep01-rebel-vape I know nothing about this company......
If the fire button pinches the ribbon cable to the screen you can have issues.... happens often when the ribbon cable isn't positioned correctly.... ribbon cables fails....
I get plenty restriction by closing the airflow almost completely off....
Not necessary.... With Replay you vape till you get the hit you desire then you activate Replay. Replay takes you to the hit you set. -
OK.... I don't know but your device is either the large or the small screen and both can be purchased from Evolv... They ship worldwide.. here is a link to their site... maybe someone in your country cn fix it for you https://www.evolvapor.com/products/dna60 I think shipping is $2.00
I don't own a rDNA60 but I don't believe you have that functionality.... VaporShark used to do some repair on their devices so you might contact them and see if they can replace the screen....
Here is the download part of this forum.... lots of themes to choose from for the 250C.... https://forum.evolvapor.com/files/
Haven't tried the 0.5 pods lately but just loaded a fresh 0.25 pod just received and it has more wicking than my older ones I have.... and I can MTL with it..... I know.... it designed for DL
if the coil overflow happens when the tank is open then the wicking is not too tight.... if you take multiple hits in a short time the wicking maybe can't keep up......
You should get bubbles with the tank closed.... it also may be the juice (PG/VG %) you are using or the wicking inside that tank is too tight.... some people take a paperclip and play with the wicking but I don't know if that really helps....
FYI The 0.25 ohm coil is for DL (Direct Lung inhale) and the 0.50 ohm coil is for ML (Mouth to Lung inhale). The Orion automatically detects which coil is being used...
hum... I did a google search and found nothing about this device with a DNA Go board in it... do you have any other links ...? THX
So have you verified your other chip wattage is correct? What process is there for your other chip's wattage to be verified? EScribe is used for DNA's... You can see it in Device Monitor.
Try the cable you used on the computer that recognized the Orion on your computer.
