Everything posted by retird
CSV for Lost Vape Triade250c 3xSamsung 25R
retird replied to komplex's topic in Batteries and Charging
No way to disable /reduce the number of profiles as far as I know.... I just Name the Profiles I use (Profiles starting with profile 1 thru 4) then I can just pick the one I want using the up or down button....
NOPE..... The Orion auto detects which of the only 2 available pods approved for the Orion is being used (DL or MTL). The 1.0 ohm kanthal pod is not for the Orion even if you can vape it will not be good and won't Replay...
If you just received the device it was DOA..... contact the vendor for a replacement.... I don't have a retail version of the Orion to diagnose with but my best guess is a bad switch .... someone with a Orion may jump in with more thoughts....
Chip Suddenly Died - No Warning Signs, What Can I Do?
retird replied to HxChris's topic in DNA 200 and 250
There is no option with the 75C for "dubious coils"..... the 250C has that option.....
Could it be a 510 issue, a wiring issue, a grounding issue, or connectivity issue between the atty and 510 connector causing the resistance issue.... not necessarily a board issue.... Evolv makes the board but not the device and they replaced the board so you might look elsewhere...
No the cvs won't effect the grayed out default battery type........ but the proper battery cvs (if it is for your battery) is all you need.... Which 26650 battery do you have? ... that's the proper cvs you need to install.... Also, you need not delete EScribe to install a newer version.... And, it is good to save the *.ecig file to your computer before making any changes just in case you need to re-install it later....
Could it be locked.... 5 clicks to unlock
I did a bit of checking about this 1 ohm pod. Apparently it has a Kanthal coil and is a Lost Vapes pod, however, it is not compatible with the DNA Orion. The 1 ohm kanthal coil is not compatible with the original Orion but you can force the Orion to recognize the pod. Because the DNA Go board is designed for pod resistances from 0.2 to 0.5 ohms, and SS coils are needed for replay,, it is not recommended. It'll work but not well and not at all with replay. Hopes this will prevent Orion users from thinking this 1 ohm pod is compatible with the original Orion replay feature. Have a great day....
Welcome to the Evolv DNA Forum. This is an EVOLV Forum thus Non-DNA products are not tracked here. This forum thread is for the DNA Go board. Talking about the Lost Vape pods fits because it is a part of the Lost Vape Orion which contains a DNA Go board. You might be able to get some discussion by visiting an e-cig forum such as ECF.
So it's not a Lost Vapes 1 ohm pod but a knock off?
Got a link to these 1 ohm pods? THX
The failure rate for the GO board is very low. Here is the link if you want to see the numbers in real time. https://www.evolvapor.com/info/dna-go-stats Currently the failure rate is less than 1% (the majority from early production issue) for the over 225,000 devices produced. Only 69 failures are for other reasons for the over 250,000 boards. Evolv folks personally helped you out with the 2 dead units before. A unit that does not charge can be caused by many things so why not just let them look at it.
Has anyone figured out the 0.59 charging problem?
retird replied to Freshertwin's topic in Batteries and Charging
It may also be the charger you are using, USB cable, .or many other things.... well, back to Christmas festivities.... good luck.... -
The Vaporshark DNA200 has a Zip charging circuitry that is proprietary to the Vapor Shark and the charging circuit of a normal DNA is only a 1 amp charging circuit. Contact Vaporshark about that device... The DNA250 has a built in Cell Balancer and can charge at 2 amps. During charging, is vital that none of the batteries charge beyond 4.2 volts per cell. If one of the cells in the battery has more charge than the others, its voltage will be higher. During charging, the DNA 250 will turn on a “balancer” to charge that cell more slowly, to allow the less charged cells to catch up. By monitoring and charging each cell individually, the safety of a multi-cell pack is equivalent to using a single cell. Many products, from power tools to laptops to electric vehicles, use multi-cell packs. All responsible multi-cell lithium based designs use cell by cell monitoring and balancing to operate safely. If the 250 boards had a 0.59 charging issue I don't recall it (memory not what it used to be..he-he). But at any rate you could fill out a ticket with Evolv and give the information you posted here. They should get back with you. Here is the link to the Help Desk... https://helpdesk.evolvapor.com/index.php?a=add&category=1 -
Who knows?????
hum, my opinion (and disclaimer) .....opening the device may void the warranty and anything done to the board (such as shorting the device components) may render the board useless... It is not an Evolv fix....
As far as I know there is no Case Analyzer for the DNA60. Using the numbers from the 75 is just a "shot in the dark" and I would not use them. Why do you need to change the default settings for the 60?
Here is an elaborate theme that has been updated frequently by the author.... scroll down to the bottom of the link for the download options..... in the theme designer look at the Pack Screen.... maybe what you are looking for... Select Menu 1 Battery Pack on the device to see batteries.... Link..... https://forum.evolvapor.com/files/file/708-mr-theo-bottomfeeder-led-easy-colors/
Newest firmware update 250c
retird replied to Vapingturtle's topic in EScribe, Software and Firmware
Download the INT install exe file for EScribe from this link to your COMPUTER...... https://www.evolvapor.com/escribe Install EScribe to your computer.... open EScribe and connect your device to the computer.... if there is a newer firmware update (Service Pack) you will see a message (usually in blue letters on my computer) that there is an update... click on that to install... As far as I know there is no install process for a cell phone... @dwcraig1... we posted at the same time....he-he.... -
hum.... did you get this download from this forum? I can't seem to find Carbob-V2-4.ecigtheme. Here is Carbon V2 download from this forum if you want to give it a try... Carbon V2.ecigtheme
If the boards worked when you removed them then setting on the shelf won't damage them. They are way out of warranty but you might start a ticket with Evolv anyway. Explain and give the pictures to them. They may have some 200 boards left but they have not sold them for awhile now. They may help you or maybe sell you a couple boards????
Did you just plug in the battery and not plug in the balancing plug/wires? Sure that your USB cable is a data cable?
Too Hot: The DNA 75C has onboard temperature sensing. It will shut down and display this message if the internal board temperature becomes excessive. Could there be e-liquid that has leaked onto the DNA board? You can start a ticket with Evolv and they will guide you........ link........... https://helpdesk.evolvapor.com/index.php?a=add&category=1 By the way you posted in the wrong thread.. I will move it to the proper area on this Forum....
- 1 reply
- 1
