That all looks good to me, my man!
Peak and average temp vs the set temp in device monitor?
Wayneo replied to denniz's topic in DNA 75 Color and 100 Color
Dunno, but it's very quick, and that's a pretty tiny screen. You should trust the hard numbers. Here's an alternate printscreen with the bump shown. Mod set for 440F, hit 444F. -
And you're going backwards by doing this KEYWORD is 'soft'
Usually as it ramps up, and then drops to your set temp. Usually due to a high punch ... say 11, and on a subsequent vape, will get lower. Also known as the Karloz bump. That 215.5C for temp is the average of your vape which would include the ramp UP to your set temp. -
Hotay, I only use a fan half the time anyway, but that doesn't matter. I looked at csv, and it showed 100% at 4.21 volts. You can change that to 4.20 and your icon will then show 100%. Don't know what your 'cell soft cutoff' is set at, but 2.7-2.9v or even a bit lower, will give you more run time. Authentic 5A's are a solid battery with less sag than a VTC6.
An accurate Battery Profile only affects your Icon. BUT you can run your own Battery Analyzer which will be guaranteed accurate for your mod and pair of batteries. All you need is an RDA, 4 loops of wire, fan, and an hour. Welcome
Just got my paranormal 166 want to get 316l for tc any help
Wayneo replied to Dtgodmage22's topic in DNA 200 and 250
So on your Paranormal, you unscrewed the 510, cleaned off the loctite, and it's now working fine? Did you verify that in Device Monitor? Using any TC wire your coil resistance will always rise, BUT YOU SHOULD ONLY EVER SEE THAT IN DEVICE MONITOR OR IF TC IS NOT WORKING or you're using just watts. Read that two or 3 times. For your Oni what straight watts have you vaped this at, and find good? What are your Profile settings for this (Preheat Power, Punch, Time) and then Power. Screenshot instructions in my signature line. -
ON Page 1, as there has now been another commenter. -
Hey @Doyle4 just an FYI, Ni80 is not a temp wire, and as such you should only be using watts/power. But from your info, there's a dip (lower value) in that material profile. Personally, I'd just trash it.
"LV Paranormals have issues...https://forum.evolvapor.com/topic/69140-paranormal-75c-resistance-too-high-fix/ ... but the problem seems to persist across all Paranormals" @VapingDad I'd suggest you read the thread listed. 1st post and the last 3 posts. For your Oni, can you describe your coils, and a Printscreen (Device Monitor) while firing would help. Well, none of the shops I frequent have any clue about temp control either, and voice that opinion based on selling non DNA devices. -
Hmmm, before trying on Windows ............ So you can connect and do a restore which should be checking the validity of the configuration. Without making any changes at all ... can you then disconnect and reconnect without any errors, can you 'upload settings to device' without the error ? IMHO, if your answers are yes, it could be in what you are changing. Just for giggles, have you tried using the default evolv theme with your changes?
Go to 1 of your 8 profiles. Click Load. Choose the one you just saved.
Another user had this same issue yesterday. He found that by running escribe as an administrator solved the issue. YMMV. Please do report back either way. Welcome Have you tried to change anything with wires/material, or battery?
Recomended setting for Mig Vapor Black
Wayneo replied to BobBitchen's topic in DNA 75 Color and 100 Color
I'm not reading your manual. If the coil is SS304, you should either download that material profile from Steam-Engine, or create a custom material using the TCR value from there. 304 has a higher TCR than 316 IIRC, so your temps will be wrong (lower) -
Therion "Curve is not one-to-one" error strikes again
Wayneo replied to Martin G.'s topic in EScribe, Software and Firmware
Did you check if your language was set to Autodetect? The workaround according to that thread was to set it to English. BTW, what version of escribe are you using? -
I don't think I've ever seen or heard of that error. 'Curve' would usually apply to material/wire. Did you possibly play with wire types? Or battery? -
Solara DNA30 converted to DNA60 have a few questions
Wayneo replied to MikeyG's topic in Modders' Forum
First off, Evolv says a lower or more conservative value is better than being higher. They also say the lowest they've seen is .004 on their reference 510. Now having said all that, having personally tested 9, I get from .002 to .007 I have seen a virgin LostVape Paranormal file where .01 was configured, so who knows. At least we got COLOR <- Christmas Festive Theme -
Not sure which part you didn't understand, but i'll try. Your Smok mod is made by Smok. The menuing, key sequences to change modes, pretty much everything can be Smok specific. DNA boards are made by Evolv, and used by different manufacturers such as LostVape or HCigar, etc. Because the board in those is all the same (Evolv DNA), with the same menuing, key sequences, etc. this forum can help DNA users with issues or fine tuning. Your problem was a general vaper type issue, and was answered in a general manner. If I didn't answer your query, quote the section. Enjoy your mod. Edit: And the best part is a true 1 year warranty on the board/chip right here from Evolv.
@Edgar We're all vapers here, and luckily your problem is now resolved. Having said that, this is DNA forum, where help is usually DNA specific. I have friends with your mod, but no clue how to change modes, etc. on it. Eventually, when you're ready to upgrade, these are fine boards, and as you've found, a low noise area dedicated to help resolve user issues. Cheers man, and vape on
You gents do realize he said this
Before doing anything. File -> Save As and save a copy of your entire current settings. Trust me. Custom screens. Download or create your own. Go to field (startup, ohms too xxxx, whatever) you want to change in escribe Hit Load Find new screen Upload to device.
For an accurate battery icon, I'd suggest you run the 'Battery Analyzer' on the mod tab. Takes about an hour, your batteries at full, a fan, and an RDA. Guaranteed accurate for your batteries. Welcome
HELP! PARANORMAL DNA 166 SETTINGS PLEASE :(
Wayneo replied to tami's topic in EScribe, Software and Firmware
I DON'T OWN ONE, BUT MOD TAB, BATTERY SECTION. SET CELLS FROM 3 TO 2 WILL GET IT WORKING. I'D SUGGEST YOU WATCH A TUTORIAL OR 2 TO BETTER UNDER STAND WHAT YOU'RE DOING. WELCOME.- 4 replies
- 1
- paranormal dna 166
- paranormal dna 250
- (and 5 more)
Dead paranormal. Thank God I recovered it though.
Wayneo replied to Aalmosawi's topic in EScribe, Software and Firmware
That's what you did. You kept loading the Evolv defaults, which is set for 3 batteries NOT 2. -
SS316 Profile setting for Lost Vape Triade DNA250
Wayneo replied to Archie's topic in DNA 200 and 250
All my black tanks and RDA's work just peachy. All my black tanks and RDA's have shiny Stainless Steel 510 threading. No idea about the Azeroth.
