  1. Unfortunately, no it's not working right. If you look at this graph, that pinkish line, your cold ohms is a solid line (good), but you don't see the live ohms line raising (like you do in the prior .5 printscreen) well a rise of .003 is not enough. Is it at ambient/room temperature? Go use that .5 coil for a bit, and come back to this one. The initial settings looked fine, don't change anything during troubleshooting as it changes your known state.
  2. Remember that your coils need to be as close to identical as possible. I use both contact and spaced fused claptons, but you gotta make sure your connections are tight (not Superman tight) and no hotspots. Overall, I'm team spaced. Enjoy your mod.
  3. It's gotta be a connection issue ........... somewhere. Either in a dirty 510 or connector, or a loose 510 pin, or hotspots in your coil. Can you space (if it's a contact coil) slightly and retry? Even with just a single coil to prove to yourself it works. And don't lock the ohms And welcome
  4. A quicker, easier way would be; Go to "About" Escribe. Click the juice droplet (middle of the logo) 7 times till it flashes. Fire up "Device Monitor" Way down on the left you'll see "Screen disconnects". That value should be zero 0. Welcome Stephan The rubberized casing on my Black SDNA75 is still mint.
  5. While I fully agree with @iAlexander and many of these last 2 points, here are 2 functional points. 1. Change the timing of when the backups are done to after the device has been fully enumerated. As it sits, it's really of no use to a user with multiple boards of the same type. 2. And most importantly, you already know setting an accurate Mod resistance only works for 75 boards.
  6. Don't bother ........ I'll never see it. Have a great day, enjoy your mod.
  7. At least it's only a simple solder job, which is much less time consuming to repair, compared to sending it to the US for service. Looks like the old battery tab connector wire. Glad you found it.
  8. Hey @retird, if it wouldn't be too much of a bother, could you describe how boost works on your 60. Mine has no USB, and I don't want to actually 'fire' with only loose wires. I think @James said it was proportional up to a 60w max. Like from 1-11 is it both wattage and time?
  9. With those varying voltages shown for each cell, could there be eliquid in there? I'd really check/clean all contacts, then open the ticket like @retird suggested.
  10. Will it connect to escribe? If 'yes', can you post a 'printscreen' of 'Device Monitor' And welcome
  11. Welcome No comments on such things as using the spacebar or the return/enter key for accepting a dialog box, or copy/paste in an editable field. IMHO, there are bigger fish to fry.
  12. And if that doesn't solve your issue, read this one post. Link in @retird's signature And welcome
  13. Yo @mactavish, the url you show (that works), is not the same as his on his mobile. His 'fix' I'd betcha is written on his image posted.
  14. 2 questions What were you doing just before it stopped working? Did you do/try a 'Restore Defaults'? Welcome
  15. So are those your actual values you are using?
  16. Yes, just stays there as 0.005, no more ?. I noticed the change (stopped working) with my 200's from 1.2 SP3, FDA deadline. IIRC, you limited the max peak and sustained current at 24A, and identified as '-Other changes'. No comments about anything else?
  17. You are correct, sir! But nowhere in this post was the 6.0 volt limitation ever mentioned. Perhaps it was meant for a different thread? And welcome
  18. @James, with the solid copper 510 tool, with multiple 200's using the last 2016/02/23 firmware and escribe 1.0.39 or 42, I was getting down to .002 on a couple mods. Later firmware and escribe was down to ~.006 before a ? mark. The last i checked (if you can tell I'm a mod res natzi) it would get to .005 and stay there, but testing on the prior versions would still get my 11 DNAs .002 and higher. The 75 non color (when tested) managed to show lower values. You said "Always make sure the Mod Resistance you have is conservative", they (users and quality manufacturer's) will think .005 is accurate. I don't own a C version. On my BilletBox (only DNA60) it was set at .0004, and no way to validate that or thermal characteristics (even though I only need board temp to room temp offset) as there's no USB port. Telling me another way is more useful, than an easy 'just use the defaults'. I had a DNA250 custom built, with the shortest, biggest, fattest wires possible for every connection with a shitty Varitube v2 (which is now being replaced) and got .003 using an alternative method. I'm no Electrical Engineer, but if a '0' value is the default, couldn't you put Mod Res calculation on the Manufacturer Mod tab, and perhaps disable the fire button, allowing us to use the solid copper tool or something? A simple yes or no would suffice. A nice feature would also allow one to Save "Mod" parameters, allowing us to load default settings across the slew, then load individual Mod parameters. Mod Res setting IMHO is a 'premium feature' parameter from the Temperature vaping pioneer company.
  19. They're the experts, take them up on their replacement offer. A CSV will definitely not fix a battery drain issue.
  20. True words. Even here with DNA devices, knowing that we can no longer get an accurate Mod Resistance value from Atomizer Analyzer as we know it. But we do get COLOR screens ........yes!!!.
  21. I can't see it. Maybe as a niche product. There's only 1 standard really, being the 510 connector. From that we get the resistance of any coil/atty combination. I think it's gotta be done through software, a la Hohmtech. Just my thoughts. Think of interchangeability consumer choice.
  22. Yup Yup Yup to ya's. @awsum140 Last week I was gifted 6@30 foot spools of Temco Ti01, and 1 box of NiFe70. This stuff just doesn't have the market, but Gold to me. Ni200 is considered commercially pure @ 99.6% Nickel and was used as the material by Evolv on the DNA40's. Also used by Steam-engine as their reference material. Ti01 is ~99.5%
  23. Much easier for sure. But SS, IMHO has become the defacto standard for many, due to safety fear mongering. I posted a a table below showing composition for each SS
  24. @denniz Just to add slightly .... If you look at the composition off what makes SS304 304, or SS316 316, the specs clearly show both minimums and maximums for each wire type designation. If one batch were to follow all the minimums/maximums/average it will all throw off accurate TCR. Not disagreeing with your 120 ........ just saying. I'm with @awsum140 .... every word.
  25. Enjoy your mod. You're welcome
