Maxamps 2800 4s discharge question
Wayneo replied to thelateoctober's topic in Batteries and Charging
If you look at your 4 cell voltages when it 'cuts off' at least 1 of them is at 3 volts. You should also get a 'check battery' message at that time -
Thanks for that. Changing the 'curve' in any way does NOT affect your working mod, at all. The curve will not give you extra battery life. It will only give you an accurate icon. Like I mentioned earlier, run the 'battery analyzer' once your battery is fully charged and all 4 cells are balanced. Lipo's usually have a long relatively flattish slope, then fall of a cliff. You can vape it right down to 'weak battery', knowing the 'check battery' is not far behind. -
Can you post a full Device Monitor printscreen for starters. Also, at the end of the day, you ought to run the 'battery analyzer' to get a valid curve for it -
I said a lot more than that. I will quote myself. You are certainly free to change anything you want, whenever you want. You should understand why you make a change. You can quite easily make unwise changes
You can use Boost - Punch for extra watts at start of puff. Punch is 1-11. Higher numbers mean more power, start at 5 and work your way up for more.
The Yihi SXmini delivers power (watts) in a different manner to DNA chips. The DNA's are straight line DC-DC while the Yihi chips pulse their power, called pulse width modulation (PWM). It might seem more powerful to you. Describe what you mean by more powerful for the SXmini. You should not be changing things you do not understand, and the change you made did NOT make it more powerful. You should watch a video or two to get a better understanding before making anymore changes.
So you straight up refuse to answer MY questions, and this will be my last post to you. But I will answer your question. You cannot do anything with mod 1 and mod 2.
And what are these mods? #1, #2, and #3
What is that 'Mod resistance' for each of the 3 mods?
In escribe do this Options → User Interface → Advanced so the ‘Mod tab’ shows. Then go to Mod → Electrical What currently shows for Mod 1, 2, and 3
So out of your 3 DNA60 mods, do any of them have USB ports? Let's refer to them as mod 1 and 2, showing the 0.66Ω value, and #3 having the 074Ω.
Double resistance read and temp protect issue
Wayneo replied to BlackFireDragon's topic in DNA 250 Color
Does this occur with other/different atomizers on this Plus? -
lost vape thelama solo 100c with vaperz cloud asgard rda
Wayneo replied to kory's topic in DNA 75 Color and 100 Color
I have not heard anything bad, but not my style of vape. Watch reviews on it, or find a generalized vaping forum. I usually run my single battery mods with a single coil atty/rda, but nothing wrong at all with your setup -
Did you move directly to this mod after your Orion? What watts are you currently using? Did you turn the Boost Punch on/up as already suggested? -
Best for you to open a Help Desk ticket. There's a link in my signature line.
My photo was clearly the mech version. 👍 Thanks for the updated pic, it's good to have. I see now the magic's hidden under that black cover. As far as this current dude, it's still too early to call.
@BillW50here was another HOG post. In the past they have had issues with the closing panel/plate, and even sold repair/replacements. IIRC they called it an X connector. You can see from this post it clearly was NOT a BMIC/board issue. https://forum.evolvapor.com/topic/71785-hammer-of-god-dna-400-dna-250c-wrong-battery-information-always-12something-volts/?do=findComment&comment=938127
@Jjhaire Can you post a screenshot like @ScubaSteve did in his initial post, please.
That lines up better with your initial post specs. Dual coil would be half that, not the .33 your DM showed. In your next post, can you describe your coil(s) in more detail. 1 or 2, spaced or contact, ID, wraps, etc. Also, If you're still in Profile 2, can you post that screenshot of Profile 2, along with a new DM screenshot. (Your numbers did not line up in your initial post). Do you have another atty you can use, preferably with a single spaced coil, for now. You should also check the 510 positive is snug, and clean on both the atty and mod. P.S What was that initial atty?
Was there a special theme on the mod ?
Was this happening from new when you first got the mod? Was there a special theme on the mod?
If it were me or in hindsight, the very first question would have been 'Describe your coil'. All we know now is it's a combination kanthal/SS coil, where it has nothing to do with your theme. I would consider it somewhat unstable, but is working for now. IMHO the title should be changed to be more relevant.
@Lukasz369ns I have removed your DUPLICATE post. You NEVER need/should do that here. That's usually a shitty theme issue. Try just using the Evolv default theme and let me know if the issue persists. https://forum.evolvapor.com/files/file/1438-stock-theme-puff-count-edit/
Now that's a first. I have managed to recreate the '22' on all 3 color boards running that SP55.1 firmware. I have opened a Help Desk ticket describing the issue.
Need to see a picture of that. What theme, firmware, and board type (verifying it's a 250C) on that mod?
