   (39 reviews)
rev 2.2.0
13.08.2017
Added last puff power&temp on frontpage
Bigger numbers
  • Like 16
  • Thanks 9
  • Haha 1
mjordan79
· Edited by mjordan79
GrumpyJoe
FrankieS
noxtradamus
  • Thanks 2
eckotek
· Edited by eckotek
Then push reset :
clivy
Chodi
Hearts
yanoostar
Grazie Frank65
N8dizzle
bigbells
konn4312
Canadianvape
· Edited by Canadianvape
Aavatar
Keep up the good work mate!!!
ronnyko
sorry about that.
  • Confused 1
myk376
· Edited by myk376
mactavish
nightwire
JapoBR
rubassdj
· Edited by rubassdj
Ping
