Edited by Frank65
What's New in Version 2.8.7   See changelog
rev2.8.7 REPLAY
  • Added SVA mod theme
  • Pre-Heat menu : now you can choose between punch and temperature
  • Pre-Heat menu : power and temp values now increment according step settings
  • New coil menu : resample choice now working correctly
  • More settings menu : added flip and always on options
  • Main menu : live ohms when firing
rev2.8.6 REPLAY - July 28 2018
  • Added minimal battery information on lock screen when charging
  • Correction of wrong preheat temperature field on preheat menu
  • Minor aesthetic modifications
  • Added Lost vape Triade & Rebel mod themes
rev2.8.5 REPLAY- May 18 2018
settings.png.c89f1ab16caf163cd2acabe83e42eb1b.png      piumeno.jpg.f1d01095d4f3183d8661ca6aee2faf95.jpg    ==>   moresettings.png.cae2d2a258ce2e6d3499d5f4d017db07.png
Minor bugs fixing
Thanks for your attention  :)
  • Like 20
  • Thanks 15
  • Haha 1
mjordan79
· Edited by mjordan79
Frank65
FrankieS
GrumpyJoe
noxtradamus
  • Thanks 2
eckotek
· Edited by eckotek
Then push reset :
clivy
Chodi
Hearts
yanoostar
Grazie Frank65
N8dizzle
bigbells
Canadianvape
· Edited by Canadianvape
konn4312
Aavatar
Keep up the good work mate!!!
ronnyko
sorry about that.
  • Confused 1
BEAGLE
myk376
· Edited by myk376
mactavish
chinoloc1
vapondragon1
Primo Ti 21700.ecigtheme
saiak
nightwire
JapoBR
