Edited by Frank65
What's New in Version 2.8.3   See changelog
rev2.8.3 REPLAY
Bug Fixing .
Replay now can be assigned to any profile , pre-heat and boost menu rewritten
Needs firmware 1.2 SP33.2
  • Like 20
  • Thanks 15
  • Haha 1
mjordan79
· Edited by mjordan79
Frank65
FrankieS
GrumpyJoe
noxtradamus
  • Thanks 2
eckotek
· Edited by eckotek
Then push reset :
clivy
Chodi
Hearts
yanoostar
Grazie Frank65
N8dizzle
bigbells
Canadianvape
· Edited by Canadianvape
konn4312
Aavatar
Keep up the good work mate!!!
ronnyko
sorry about that.
  • Confused 1
BEAGLE
myk376
· Edited by myk376
mactavish
chinoloc1
vapondragon1
Primo Ti 21700.ecigtheme
saiak
nightwire
JapoBR
