Edited by Frank65
What's New in Version 2.6.0   See changelog
rev2.6.0
01.09.2017
Added boost time to preheat menu
  • Like 20
  • Thanks 14
  • Haha 1
mjordan79
· Edited by mjordan79
Frank65
FrankieS
GrumpyJoe
noxtradamus
  • Thanks 2
eckotek
· Edited by eckotek
Then push reset :
clivy
Chodi
Hearts
yanoostar
Grazie Frank65
N8dizzle
bigbells
Canadianvape
· Edited by Canadianvape
konn4312
Aavatar
Keep up the good work mate!!!
ronnyko
sorry about that.
  • Confused 1
BEAGLE
myk376
· Edited by myk376
mactavish
chinoloc1
vapondragon1
Primo Ti 21700.ecigtheme
saiak
nightwire
JapoBR
