   (34 reviews)
What's New in Version 2.0.0   See changelog
rev002
10.08.2017
Modified resistance & settings screens
New clearer icons for onoff toggle
minor adjustments , more colorful
Added Paranormal version
mjordan79
Report ·
· Edited by mjordan79
Share this review
GrumpyJoe
Report ·
Share this review
Frank65
Report ·
Share this review
noxtradamus
Report ·
Share this review
eckotek
Report ·
· Edited by eckotek
Then push reset :
Share this review
clivy
Report ·
Share this review
Chodi
Report ·
Share this review
Hearts
Report ·
Share this review
yanoostar
Report ·
Grazie Frank65
Share this review
N8dizzle
Report ·
Share this review
bigbells
Report ·
Share this review
konn4312
Report ·
Share this review
Canadianvape
Report ·
· Edited by Canadianvape
Share this review
Aavatar
Report ·
Keep up the good work mate!!!
Share this review
ronnyko
Report ·
sorry about that.
  • Confused 1
Share this review
saiak
Report ·
Share this review
nightwire
Report ·
Share this review
JapoBR
Report ·
Share this review
rubassdj
Report ·
· Edited by rubassdj
Share this review
Ping
Report ·
Share this review
zark
Report ·
There is an error in the numbers of active batteries. This is the best topic.
Share this review
CasiOpeiA
Report ·
Hi Frank,
thank you for your very nice theme. I love it!
I found one little issue and I can't find a way to change it. In the device monitor, the color of Voltage-Graph is the same as the color of the Power-Graph (red). It should be a nuance of blue. I can't find a way to change that in Escribe. Can you tell us
a way to change that?
Best regards
CasiOpeiA
Share this review
gogototo
Report ·
잘되길바라며
Share this review
JustTheJokerr
Report ·
Great theme, looks awesome, works well. A few bugs though, such as the date seems to change in a weird way? Doesn’t seem to go day by day but instead jumps a few days here jumps back a few days etc etc even resets sometimes. Also, I’m not really understanding stealth mode.. 1 and 2 seem to be exactly the same, about a 10 sec delay before going to black screen. I figure they should be different somehow but are exactly the same.... otherwise I don’t think there’s any other problems! Maybe one other small bug somewhere that I can’t think of. But yeah great UI works great looks awesome highly recommend!! Just hope the creator is staying up to date and fixing these little bugs!
Share this review
Miromarques
Report ·
Can you do it for SVA ponto?
Share this review
