   (39 reviews)
What's New in Version 2.0.0   See changelog
rev002
10.08.2017
Modified resistance & settings screens
New clearer icons for onoff toggle
minor adjustments , more colorful
mjordan79
Report ·
· Edited by mjordan79
Share this review
Frank65
Report ·
Share this review
GrumpyJoe
Report ·
Share this review
FrankieS
Report ·
Share this review
noxtradamus
Report ·
  • Thanks 2
Share this review
eckotek
Report ·
· Edited by eckotek
Then push reset :
Share this review
clivy
Report ·
Share this review
Chodi
Report ·
Share this review
Hearts
Report ·
Share this review
yanoostar
Report ·
Grazie Frank65
Share this review
N8dizzle
Report ·
Share this review
bigbells
Report ·
Share this review
konn4312
Report ·
Share this review
Canadianvape
Report ·
· Edited by Canadianvape
Share this review
Aavatar
Report ·
Keep up the good work mate!!!
Share this review
ronnyko
Report ·
sorry about that.
  • Confused 1
Share this review
myk376
Report ·
· Edited by myk376
Share this review
mactavish
Report ·
Share this review
chinoloc1
Report ·
Share this review
vapondragon1
Report ·
Primo Ti 21700.ecigtheme
Share this review
saiak
Report ·
Share this review
nightwire
Report ·
Share this review
JapoBR
Report ·
Share this review
rubassdj
Report ·
· Edited by rubassdj
Share this review
Ping
Report ·
Share this review
