   (36 reviews)
What's New in Version 2.8.8.1   See changelog
rev2.8.8.1 REPLAY - March 2019
  • Added Vicious Ant Spade theme
rev2.8.8 REPLAY - March 2019
  • Added Lost Vape Drone theme
  • Resistance menu : replay choice added , now you may choose to replay from any profile
  • Trend menu : timeline added
  • Main menu : coil red when locked
  • Bug fixing where possible
  • Inconsistences between Escribe and preheat menu were not possible to fix because of missing parameters in theme editor (or anyway I was not able to find)
rev2.8.7 REPLAY
  • Added SVA mod theme
  • Pre-Heat menu : now you can choose between punch and temperature
  • Pre-Heat menu : power and temp values now increment according step settings
  • New coil menu : resample choice now working correctly
  • More settings menu : added flip and always on options
  • Main menu : live ohms when firing
rev2.8.6 REPLAY
  • Added minimal battery information on lock screen when charging
  • Correction of wrong preheat temperature field on preheat menu
  • Minor aesthetic modifications
  • Added Lost vape Triade & Rebel mod themes
rev2.8.5 REPLAY- May 18 2018
settings.png.c89f1ab16caf163cd2acabe83e42eb1b.png      piumeno.jpg.f1d01095d4f3183d8661ca6aee2faf95.jpg    ==>   moresettings.png.cae2d2a258ce2e6d3499d5f4d017db07.png
Minor bugs fixing
Thanks for your attention  :)
mjordan79
Report ·
· Edited by mjordan79
   8 of 8 members found this review helpful 8 / 8 members
Share this review
Frank65
Report ·
Share this review
GrumpyJoe
Report ·
Share this review
noxtradamus
Report ·
  • Thanks 2
Share this review
eckotek
Report ·
· Edited by eckotek
Then push reset :
Share this review
clivy
Report ·
Share this review
Chodi
Report ·
Share this review
Hearts
Report ·
Share this review
yanoostar
Report ·
Grazie Frank65
Share this review
N8dizzle
Report ·
Share this review
bigbells
Report ·
Share this review
konn4312
Report ·
Share this review
Canadianvape
Report ·
· Edited by Canadianvape
Share this review
Aavatar
Report ·
Keep up the good work mate!!!
Share this review
ronnyko
Report ·
sorry about that.
  • Confused 1
Share this review
chinoloc1
Report ·
Share this review
vapondragon1
Report ·
Primo Ti 21700.ecigtheme
Share this review
saiak
Report ·
Share this review
nightwire
Report ·
Share this review
JapoBR
Report ·
Share this review
rubassdj
Report ·
· Edited by rubassdj
Share this review
Ping
Report ·
Share this review
zark
Report ·
There is an error in the numbers of active batteries. This is the best topic.
Share this review
CasiOpeiA
Report ·
Hi Frank,
thank you for your very nice theme. I love it!
I found one little issue and I can't find a way to change it. In the device monitor, the color of Voltage-Graph is the same as the color of the Power-Graph (red). It should be a nuance of blue. I can't find a way to change that in Escribe. Can you tell us
a way to change that?
Best regards
CasiOpeiA
Share this review
gogototo
Report ·
잘되길바라며
Share this review
