Lanzarotechris
Everything posted by Lanzarotechris
  1. OK, that sounds good. I just was confused abbout the explicit mentioning of the 18650 in the battery settings. Then it would make sense to just mention Li-ION in that dropdown menu instead of mentioning a specific battery-size. With "my theme question" you mean my post in the themes section asking for confirmation that the "Simple Theme xxx.v.2.0.4" is working on the Therion ? *confused again!* 😉 ... anyway... Thanks for the clarification about the batteries !
  2. Just wondering,... since there is no update on EScribe since the release of the Hyperion model; shouldn't it be updated because of the different battieries I can use in the mod ? (20/21700) I still can only choose between Li-Ion18650 or Li-Po in the settings, but no 20700 or 21700 Li-Ion which (should) have different curves and other characteristics. I inserted a 21700 curve anyway, but it would be nice if the software can correspond to the correct hardware/values. Maybe also some other values/internal calculations need some adjustment, but I am no battery guru... just thinking, because its a different size/volume of the battery so there should be differences.
  3. Hi ! (Still using this theme for all my DNAs... except the old 75 mono-colour Therion) Is it ok to use one of them (which?) for the "new" Hyperion device (with single 21700 battery) ? or do you have to "tweak" the existing theme ? Would be nice to get it for my latest DNA 😉 Appreciate your work !
  4. sorry, my mistake... I had the ground rule (Ni and Ti temp only) in my head, but NiCr is a different horse 😉
  5. So why has the thelema in the material tab ni80 and kanthal csv's ? Sorry, my fault,... I already updated the materials from my sources. But if I take a look at ni80 for example, there definately is a curve progression... a slight one, but it rises. Can't the DNA chip work with it ?
  6. Version 1.0.0
    2,702 downloads
    This is my personal collection of my csv files for escribe. I collected these from multiple sources on the web within my 3 years of vaping. Its not a complete collection, but these are the materials I use and build with. Please keep in mind that there is always some "range" within different products and manufacturers of wires. I am quite obsessed on details and I believe these are the optimal csv's I could find so far. (But If you have a "better" one and some explanation why it is superior, pls add it to this forum) keep vaping 😉 chris
  7. Hi Folks, I'm looking for a csv file for my new Thelema mod. As Evolv claims it supports Ni90, but in the stock config on the mod there was no material curve for it. As I also have some Ni90 wire at hand I now just need the file to get it work. Thanks for your help ! chris
  8. Only guys I know who vape this low use mech mods.
  9. Version 1.0.0
    949 downloads
    Just unpacked my new DNA device which arrived today! This is out-of-the-box settings from the device. Have fun ;-)) Production History Monday, November 2, 2020, 3:12 PM @ Shenzhen, Guangdong, China Mod configured Tuesday, October 13, 2020, 12:11 PM Board programmed
  10. As long as it works on an out-of-box ubuntu installation I don't care how you call it, beta, test, developer or whatever version 😉 I want only 2 things: It has to work (I even don't care about the designer plugins or that puff counter stuff), and it should not F*ckup my system. As long as these points are granted I would be happy 😉 BTW: Would it be easier to make a snap install ? I'm not a linux guy but I recognized that a lot of software isnow a snap... whatever that is :-S
  11. @wayneo When I say lost vape website I talk (of course) about https://lostvape.com/ Not some cryptic b-side noone else know about... sorry...
  12. That implies that everything else is ok. From the first post it looks like something is wrong.
  13. Sorry to hear that. Can you provide us with some screenshots of the escribemonitor (when you puff on it), and maybe a photo of the coil build ?
  14. I heared she could be a real bitch sometimes... 😜
  15. Or I just use my 2nd OS which is a stable windows ;-) Not that I wanna excuse myself, but when you grew up with windows (I started 94 with win 3.11 for workgroups) then Linux can be a challenge. Yes, its nice and (hopefully) more secure and less intrusive, but I don't heve the time to get deeper into it to frickle around with it to get something running that WAS running fine until the last upgrade. I expect from an OS that it runs and do what was advertised. I expect the same from a software (even if its free). If it stops working, then I switch or doesn't use it anymore. If you go to the Lost Vape webpage and try to look for any DNA X Mod (and I mean REAL Mods, with removable batteries and DIY Coils, like DNA75, 250...) then you will see where the focus is. I already wrote an email to them that it is a shame to remove all content of these (sustainable) devices and go for these "throw away" shit pod systems (like everybody else, it seems). I am also shure that humanity will end soon because no one seems to care about waste production, saving energy and ressources, clean landscapes and water, health of millions, or whatever makes/made this stinking pile of plastic-shit called planet eath attractive for living. Well, China and USA for shure do not give a shit. Others only as long as it does not interfere with their capitalism system. So it seems we will all die in a pile of used pods and empty coffee-to-go cups ;-)
  16. different themes ?
  17. There is no e-cigarettefourm.com there is also no e-cigaretteforum.com only a e-cigarette-forum.com and that works fine 🙂
  18. I thought temp protect is not a bug, but a feature... As the function of temp protect IS to cut the power to PROTECT from dry hits. Or how should it work otherwise ?
  19. Is this problem solved ? @Esporova Does it hit now like expected or is there still a problem ?
  20. @dwcraig1 Thanks for the info. Appreciated ! Is there a formula to calculate it or is it manufacturer related ? btw: the triade (250c) has 3 cells...
  21. @drjohnson61 f**k wendy 😉
  22. I removed escribe completely... as it wasn't working with mono 5.18, and I don't have time nor patience to go deeper into that problem. I will keep an eye on this thread to see when there is a solution for it so it will work again on linux. BTW: Why isn't there an android app for it ? Would be nice to attach my pad to my mod and change settings while I am at work or in a train... just a thought 😉
  23. @drjohnson61 Glad to help you ;-) @zark Sorry, but I don't understand you when you write kyrillic. Thats a good idea. The developers of the mod-software/escribe should think about implementing this as a standard !
  24. Still not working on the latest ubuntu (and I installed and locked the Mono version to 5.18) It starts, reads the settings of the attached mod, and then shuts down after a few seconds. 😞 Did someone contacted the helpdesk in the meantime ?
