Everything posted by Lanzarotechris
Things got solved thanks to Vandy Vape Support Team. Something was wrong with my first coil, so after the test with the big loop coil, I made 2 new coils in different atomizers with that wire, and now REPLAY works fine on both. Can't explain exactly what was wrong with the first build, but something was... So... even after a year there seems to be a learning curve for me. 😉
Vandy Vape SS316L Fused Clapton Wire (24ga*2+32ga)
Lanzarotechris replied to Lanzarotechris's topic in Replay and Atomizers
I worked together with Vandy Vape support to find out what is wrong, and we found out that it was my buil that created the problem with REPLAY. So I can now confirm that this wire is indeed working with REPLAY and TC. Sorry for the first misleading post, just ignore it. I made 2 new coil builds with support of the Vandy Vape Support Team on different atomizers and both work fine without problems in TC and REPLAY on my Triade DNA250C. So I like to give a shoutout and a big thank you to the good supporters @ Vandy Vape for their patience and help ! PS: If there is an admin following this, maybe you can remove the first post, so people do not get confused ? -
Its a 0,33 Ohm single coil (stable measurement), I run it on 40 Watts, with SS316L as wire configuration. REPLAY says Available, but Ready and Active are disabled, PREHEAT says Enabled, 60W and Temp. 179°C. Punch is about half of the indicator. Vape is nice, not hot, only thing missing is the REPLAY. It says NO REPLAY. I also tried SS304 and SS316, no change. Other simple round coils work fine on the Triade DNA250C, only this specific wire does not. I also changed the security setting about accepting other coils, but no change. No idea what is wrong, my bet is on the wire, but its a pure SS316L, so I really do not understand what the problem is. Should work... or has REPLAY problems with thicker wires ? Because its the only "fancy" coil I use in the moment. I am also in contact with Vandy Vape support and we are working on it. But their staff is a little bit difficult because their english is quite crappy 😉
my gutt and your approval is proof enough for me... 👍
Thanks,... I always can rely on my gutt,... good to know 😉 ...and congrats to your 1st post *hehe* Me myself started today as well... guess that makes us the newbies... Welcome ! (still try to work things out... for example where can I edit my signature for my posts ?) grazie ;-
Can you provide a link please ? I am also looking for a discharge profile. Specificly for: 4x Samsung INR18650-25R (for Reuleaux RX300) I can offer: 1x_Sony_VTC5_Battery_Curve.csv 2x_Sony_VTC5A_Battery_Curve.csv 2x_Sony_VTC6_Battery_Curve.csv 3x_Sony_VTC5_Battery_Curve.csv
Maybe a stupid question, not shure... Can I use this csv file on my Triade DNA250C as well ? Would there be a difference between DNA250 and DNA250C ? My gutt says "no... its the batteries, stupid !" But as I said, not 100% shure... so when in doubt, better ask, right ?
I miss that memory feature too. With the ArcicFox firmware it works fine, won't miss it. Change the atty, and whooop, it switches to the correct settings 😉 Would be something great if the guys from evolv can add that function to the firmware, if you ask me.
The DNA250C Manual says on page 2 in the OPERATING RANGE table the TEMP LIMIT is minimum 200°F, typical 450°F and maximum 600°F.
I keep the presets of BOOST and WARMTH like they are... 5 or 6 when using big fancy coils. With wattage I go normally 50% higher (e.g. when I vape on 40 W, I do 60 W preheat for 1 second). With standard round wire I switch both off. No need for preheat with round wires as they ramp up quite fast (I use normally round 24-28 ga SS wire). Depends on your builds I guess,... I normally build around 0,25-0,5 ohms and vape around 30-50 watts.
Question still remains... WHY ? I have the same problem with a Vandy Vape SS316L Fused Clapton wire (24ga*2+32ga) It's a pure SS316L wire and not too fancy I guess, but replay doesn't work. The coil is fine, its mounted in a Taifun GT IV as a single coil, and the ohms are stable at .33 ohms @ 40 watts. The mod is a Triade DNA250C. Should work, doesn't it ? I also contacted Vandy Vape as it is the only wire where I have this problem. Other (round) wires work fine. So, is it the wire or the mod ? I changed the "security" setting but no change. In the REPLAY section of the mod menu it says AVAILABLE, but not READY or ACTIVE. In the COIL INFO the TEMP CONTROL is also active. Don't know what to do next... still waiting for Vandy Vape customer service to get things sorted out.
Use bigger coils that don't slip into that space... or try flat coils which can be easier to hit with the grub. Had that same problem when using standard round wire.
Yeah, I am also confused with the WARMTH and BOOST settings... not very well explained. From the power side I would guess its the same.
My choice would be based on how long do the batteries last. If you get through the day with 2x18650 then there is no need for 3 batteries to carry around. But if I am right by reading your posts, as a cloudchaser with low ohms coils you might be better off with triple batteries. Depending how much you vape of course. Like I said, what gets you through the day is the right choice for you. I own single, dual, triple and a quadruple mod, and I use them accordingly... the quad for the evening at home (and for building on it), the single for the short trip (to the supermarket and back), and the triple for longer days away from home (work). So it depends on your needs which one you should get. For myself I can not complain about the Triade DNA250C. Fine piece of work and enough power to get me through the day.
1. Vapor is a question of the PG/VG percentage in your liquid, not a question of the coil material. (LINK to an article which explains it) In general the VG is responsable for the clouds. But the article gives you more info on PG/VG and their functions/effects, like gunk, taste, throat hit, etc. 2. TC does not work with kathal. So you don't need to search for curves etc. as it will not work. Kanthal ONLY works in wattage(=power) mode. On "schooling" you on TC, there are of course the ones who like it, and the ones who don't. But in general you can say that TC has some benefits, like no dry hits EVER (as the temp will be stable, so if you stay below the temp that burns the cotton/wick (about 250°C I think), you will be safe from the bad burn taste) It also has the benefit that because of the stable temp, you can adjust it to the specific flavour of your liquid. Depending on the liquid, a different temp means a different taste. HERE is a link to a TC related article, with some mentioning about the different temps for different liquids and also for PG/VG and nic, which will give you an idea how "sophisticated" you can control flavour with TC. I hope I could help you with your question... If you need more infos, please ask or search on google/youtube, as there is a lot of information out there 😉
I have a replay problem too, when using the Vandy Vape SS316L Fused Clapton wire 24GA *2(=) + 32GA. No replay option available. I contacted Vandy Vape support and we are working on that problem. Will keep you guys updated as soon as I get an answer what the problem is. (actually they asked me to build a 10 cm straight "coil" to check... see photo)
