VapingBad
  1. Device manager shows the mWh used under Energy at the bottom just note it when fully charged, then when the DNA refuses to fire and the difference divided by a thousand should be a good value for your Wh setting.
  2. Unless you are chain vaping at 200 W the Samsungs and LGs are better value IMO.
  3. Don't do it, the current rating is IIRC only about a quarter of what's needed. You need a constant discharge rating of 23 A or more. So Sony VTC3, 4 or 5, Samsung 25R or LG HE2 or HE4, only the Sonys are up to spec on paper, but the others are conservatively rated at 20 A and would be fine for 99% of vapers in a DNA200.
  4. Yes that is fine, the math: current rating = C rating x Capacity in Amp Hours (divide by 1000 if using mAh) current rating = 25 x 1350/1000 current rating = 25 x 1.35 current rating = 33.75 A
  5. The community spreadsheet includes real battery dimensions it would be great if you have ran the analyser to add these, it also has many categories of resources. /topic/65816-topic/
  6. If I had just waited a few more hours to register I could have had nothing too! -shakes fist- [/QUOTE] You get a warm welcome, welcome wiredl0ve!
  7. The top 2 are a 0.049 ohm dual twisted Ni200 build in an Aromamizer, if the TCR is 0.00641 then ?R per degree C is ~0.314 milliohm, preheat was 100 W. The 3rd is a 0.224 ohm 0.4 mm TiG1 dual build in an Aromamizer, if the TCR is 0.00366 then ?R per degree C is ~0.82 milliohm, preheat was 100 W. The bottom one is a dual 0.5x0.1 ribbon Ni200 on stainless steal wicks in an Origenny V2, if the TCR is 0.00641 then ?R per degree C is ~0.3 milliohm, preheat was 80 W. All are smoother than the ss above, so I don't think resistance resolution is the reason as 2 of those plots have a much lower ?R per degree C. timescale was 10 sec, but cropped to 6-7, but they are all the same scale.
  8. Got the last one after only 3 post < 1 minute, they didn't have random text in the profile.
  9. It is an inductor not a chip, if it were me I would return it to the vendor as it seem it took a knock during manufacture. This may be of interest /topic/67527-topic/
  10. In EScribe on the Mod tab under Manufacture settings check that it is below 0.010, even that is high IMO all my mods are < 0.004 ohm. If it is set it is worth zeroing it (take a note of the value first) to see if that helps.
  11. Cheers blueridgedog, I mainly use Ni so it is easy to forget Ti and SS coils have a lot more mass to heat.
  12. When it does not show the temp it is normally because it doesn't sense a temperature raise of 150 F in the first second. Is your mod resistance set high? zero is better that too high.
  13. You are doing the right things and shouldn't be getting the hot spots, I would re-tighten the coils and clean both sides of the 510 then if that doesn't work try a different atomiser.
  14. What wire are you using Tom?
  15. /topic/67435-topic/?do=findComment&comment=906824
  16. I will PM an answer, discussing the detail can only help the spammers.
  17. In EScribe - Screen tab set the "Charging Brightness" to 0%.
  18. Today's the day, can't wait to get these through the letter box.
  19. Maybe, they are now banned and it's cleaned up.
  20. Cell 3 is too low for it to charge normally, is it a 2 cell mod with the setting in the mod tab set to 3 cell?
  21. Just zapped 17 thread and banned the spammer.[/QUOTE] . It's 3am in the UK, you just woke up?[/QUOTE] No time for soon though.
