dwcraig1
Everything posted by dwcraig1
  1. I was hoping for a different answer, I'm sure you were too.
  2. What model DNA board do you have?
  3. dwcraig1
    DNA 250
    Some of the earliest ones I believe "left" without the coating. Sounds good.
  4. dwcraig1
    DNA 250
    Is the board coated?
  5. dwcraig1
    DNA 250
    I know....nice.
  6. dwcraig1
    DNA 250
    Well if they were to send me one like that I surely would not be disappointed.
  7. dwcraig1
    DNA 250
    While I don't know I purchased one on the 4th. I'll be slightly disappointed if it's not a typical ERM with 900 mah lipo.
  8. I got thinking about this post when I stumbled across this while using a Velosity on my VT133 with 2 25r's. Here is the live view of it firing at 90 watts with 1 second 110 watt preheat and 11 punch. I've upped the temp to keep it out of the way. So I move the atty to my VTBox200 with lipo, same settings. I'm looking at the green line, temp at this point is null. When I get home from work I'm going to replace the two 25r's in the VT133 with some LG HD2's that I got yesterday and check it again. OK, got home and put in two never used just off the charger LG HD2's....It was my not very old Samsung 25r's was the problem (maybe fakes, who knows but I doubt it) Here is my live view on the VT133 with new batteries. Looks better than with the lipo. Sorry BL, I didn't think it would turn out this way.....LOL
  9. I believe the screens changed some do to the place that made them burning down...something like that.
  10. I for sure don't know the answer but I suspect that even set higher than it's 23.xx amps it can still only draw 23.xx amps max.
  11. Yes go for it as it will work very well with SS. Your battery icon will be empty at first but will come back on reboot, upload or by it's self. You need to go to "options" and select "manufacturer" to see all the fields that you currently see. Quite a few of us have been using it for awhile with no problems. You can always revert it if you want. For using SS 3xx I highly recommend it.
  12. Under the "Diagnostics" tab of Device Monitor there is "Reset USB Current Limit", have you tried that? I didn't know if the setting was made to EScribe or the mod so I set mine to charge at 0.15A and moved it to a stand alone charger and it would only charge at 0.15A. Mine did show the lightning bolt at 0.15A BTW Oh, I see that you said 0.015A, I'll try it again. Edit: no lightning bolt with 0.015A on mine as well.
  13. By the latest software I hope you mean SP3 as that will give you the best results with SS 3XX.
  14. When you get it into EScribe of left box highlight and hit button to put on device...then upload settings. Then apply to profile or select from device as needed.
  15. You can not remove a material from the device if it's being used on a profile, you need to switch the material on the profile first then it will let you remove it.......if you happen to run into that.
  16. If you only have 3 material on the device then no, just change the material on the profile. Use a browser other than Microsoft....in case you didn't already know.
  17. You may want to name it so as not to confuse it with the others. Very possible it may be the same TCR as one you already have. Add to EScribe. Add to mod. Add to profile. Upload to device. You can skip adding to profile and add from the device if you wish.
  18. use this button to add material to EScribe. The device only holds 8 so keep that in mind when adding to device. EScribe can hold many many.
  19. /topic/66088-topic/?do=findComment&comment=893826
  20. Early released firmware is found here... labeled "Early" This works with all EScribe DNA devices. /topic/66731-topic/?do=findComment&comment=900119 Recommended software for 75/200 is here: https://downloads.evolvapor.com/SetupES75.exe
  21. The fuse is to protect you from the battery not to protect the board. At least put in a blade fuse inline on a battery wire. Do it for you. You can buy the original type fuses BTW
  22. $10....no $1 should satisfy that situation.
  23. Well when I ordered my DNA250 custom from Evolv I had to do an age verification check using the last for of my SS #
  24. Best answer: https://helpdesk.evolvapor.com/index.php?a=add
