dwcraig1
Everything posted by dwcraig1
  1. I'm assuming that after opening Escribe and it didn't connect that you pushed the "connect and download setting " button...correct? Also the version of Escribe is for the 250....correct? I had something similar happen awhile back but can't remember just what.
  2. Have you tried using a different USB cable?
  3. A new battery is a good idea, there is sure to be some damage from it sitting that low for an extended period.
  4. Your cells are below the voltage that the charger will start charging from, You will need to do USB Recovery charge. At the top left of Escribe under the tools tab is the option for USB Recovery Charge. It's a slow process and you may have to do it numerous times.
  5. I got about the same on my SDNA75
  6. Try this, explain details here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  7. Sounds like a blown fuse, does it still look green?
  8. You should check the voltage on both batteries when they appear to need charged to make sure the mod is actually operating using both. There have been situations in the past where only one battery was running the mod even though 2 batteries were present. Easy enough to check.
  9. I think you will find that it's this guy. I feel just the opposite, I cringe at the idea of removing the battery from the board so I charge almost always with USB.... for the same fears.
  10. On an ERM case that I broke a screw off in one of the boards mounting holes I put a machine screw with a soldering tab and nut through one of the 510' holes through the case and soldered a wire to the tab and output GND. I had to mount the screw that used in my Dremel. I chucked it in my Dremel and run it's head against a file to get it to fit the hole properly. Just saying.
  11. For a short time they were $20, went up to $40 These are not the ones with stabilized wood, same otherwise though.
  12. Kanger K1 A few of us over on ECF got a great deal on these.
  13. I would be contacting the seller about it.
  14. Not much doubt then that that is the problem. Search the forum for more on that using the "search" feature. For example:
  15. I would guess its a problem with the contacts on the battery sled if it is of the flat bent sheet metal type.
  16. I had seen that picture before but didn't comment at the time. That is caused by a high resistance connection... or bad connection simply put.
  17. Here's the positive and it's insulator, it would be near impossible to be able to short there. But 2nd picture shows how it may short if installed with too much force.
  18. So just what do you suppose was the reason for this happening?
  19. The spring loaded positive battery connector looks like a place to be looking for your problem provided battery door threads are doing their job, just my opinion though, this video may help. (at 8:23)
  20. From Protovapor, LE Silo DNA250
  21. Scroll to "Early Service Pack" section on this page. To upgrade the firmware you may have to go to Tools / Apply Service Pack and choose it from list that will appear.
  22. Also you might want to add what atomizer that you are using, ones that have spring loaded/ adjustable 510 pins are problematic.
  23. It looks like to also include DNA60
  24. Also DNA 75C replacement screens can be found here: http://www.protovapor.com/product/replacement-dna-screen/
