Everything posted by dwcraig1
Check cell soft cutoff In device monitor check voltage drop under load (firing), see if one or both cells drop below cell soft cutoff. Make sure battery connection are clean, even if they look clean.
29 watt hours will put you pretty close. 2.9 volt cell soft cutoff
250. EScribe doesn't lie.
And if not plugged into computer? (error or no error)
@Damian, do you get the battery error message when it's plugged into a wall charger. Also just to be clear is this error only displaying when connected with data cable?
Have you tried using a different USB cable?
HCigar VT133 Check Battery Message When Fired
dwcraig1 replied to txmonkey214's topic in DNA 200 and 250
You should be good....PM sent -
Against my better judgment I will post this, my friend bought a 3D printer and made this box for me. So I built it.
Time for a replacement board. -
It looks to me that the battery is no good. Cells 1 & 3 show excessive sag under load.
Accidentally reset ONI 167 DNA 250 PLZ HELP
dwcraig1 replied to esamalamad's topic in Batteries and Charging
Being the board has a hardware cutoff of 2.85 because it's designed for a LiPo. LiPo has mah rated between 3 volts ant 4.2 volts. A IMR round cell has it's mah rated between 2.5 volts and 4.2 volts. So with a 200/250 board the capacity between 2.5 and 2.85 volts isn't able to be used. What I do is subtract about 12% for what the calculator comes up with when using round cells. It's much easier on the cells to not use them to their lowest point. -
If it were mine I'd use 19.5 wh and soft cell cutoff of 2.85 v -
My first atty (Velocity) is a good candidate for checking but my 2nd one was a Merlin. The Merlin very well may have needed a good cleaning.
Call me skeptical, I tried on my SMY SDNA75 which tests out to 0.002 ohm with tool. With an atty with 0.07 resistance it came out to 0.002 -0.003 with above method. But with an atty with a higher resistance (0.58 ohms) I got something around 0.008 ohms. Of coarse there's always the possibility that I didn't do it correctly....these things happen here on occasion (many)
Karloz spike.......LOL Gone but not forgotten
Well here is what's going on, with all the 250 boards and all the 200 boards with 1.2 SP? software Atomizer Analyzer will not read below 0.007 ohms. So if it displays down to .007 then throws up a "?" it's .007 ohms or less. On the earlier firmware it wouldn't read below 0.002 ohms.
Early on I put heavy strand of copper through the posts of my Velocity, reading was 0.02 ohms. Using and old cartomizer or 510 adapter with it's end soldered together works well.
Just in case you need more ideas they can be found here: /topic/65540-topic/
Did you try it, the numbers mean nothing as far as what the temp really is. 275 -280 C should do it.
Try taking your temp way higher, it's by no means accurate when used this way
Most likely a grounding problem (lack of) at the board mounting screws and/or 510
It's almost time to make another 500 ml bottle, That will be the 9th one. Old Habits die hard.
As long as the other wire (s) is SS316 or Kanthal/Nichrome you should be fine using the same setting. But If you have say two strands of SS316 wrapped with another TC wire (eg. Ti) then a different CSV is needed.
