dwcraig1
Everything posted by dwcraig1
  1. The screen sticks to the board. Be sure the screen comes with the board and not sticking in mod. Carefully pry off the metal cover of the switch (red arrow). Try to bend it as little as possible, remove rubber piece, remove small metal disc. Remove the screen prior to cleaning too. https://downloads.evolvapor.com/dna250.pdf
  2. The Lava box dna200 looks to have the typical set up for the buttons, a button on the face pushes against the button of the switch on the board.
  3. I just finished one this morning that I got from the Ebay guy. It was a Hotcig DX200 Does the Lava box use a daughter board for the switches? These are not clones, choose no battery, he will include one. He included two with mine. https://www.ebay.com/itm/HANA-MODZ-DNA-250-200-75-Do-It-Yourself-DIY-kit-11-colors-Free-Battery-incl-/112645968597
  4. So I finally locate VB's post showing the switch disassembled and the photo is gone.
  5. Make sure to pay attention to which way the metal disc in the switches go, it is just one way.
  6. I'm to understand that Lost Vape only works on one product at a time. Here's one more: https://vapordna.com/products/hcigar-vt75d-tc-dna-75c-box-mod
  7. https://www.elementvape.com/lost-vape-skar-dna75-tc-box-mod https://www.protovapor.com/product/xpv-dna-75c/
  8. When you press the fire button once with it locked does the LED light up? If it does that would indicate that the button it's self is functional. To unlock requires 5 fairly quick presses.
  9. The best place to get an answer to that is here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  10. I thought that SP38 solved that problem. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=929633
  11. Use a magnifying glass if needed. It goes into the slot marked by arrow, not above it. Put it in squarely past the notch marked by arrow and carefully close cover. I had major problems with this on my first one, I kept trying to put it between the door and connector instead of the slot. https://forum.evolvapor.com/topic/67402-best-way-to-put-the-screen-ribbon-in-place/?do=findComment&comment=906534
  12. In Escribe change the figure for battery capacity and upload settings. You didn't mention what cells that you are using so either convert mah to watt hours and subtract 20% or try a conservative figure like 25 wh if using 3 cells. Or run Battery Analyzer. Note: I have modified the curve to reflect the change from max puffs to max recharges (charging stops at 4.1 volts)
  13. EScribe 2.0 SP17 includes firmware SP35 https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=928400
  14. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=929633 Suggest Int.
  15. Are you using a version of EScribe that is one of the older versions that came out before the 250?
  16. I'm surprised they didn't accept it.
  17. Give it a try, pretty sure it will work out.
  18. Might be an interesting read here:
  19. If I were to guess I'd say the 510 ground connection is poor, for what ever reason. Since it's new are you able to return it. If not open a ticket with Evolv and they will most likely take care of it for you. https://helpdesk.evolvapor.com/index.php?a=add&category=1
  20. If your not using this version of EScribe give it a try, this should do it. https://downloads.evolvapor.com/SetupEScribe2_SP19_INT.pkg Welcome to the forum
  21. I figure that I should set this straight, the readings from my volt meter were wonky, I measured again with my other meter and the readings between what EScribe was reporting and the meter were the same.
  22. This is probably the best way to start: https://helpdesk.evolvapor.com/index.php?a=add&category=5
  23. EScribe shows the two cells around 4.135 volts when charging stops. It is set foe maximum puffs. If I check the cells with a volt meter they read 4.2 volts. Does anyone else have this problem?
