dwcraig1
Everything posted by dwcraig1
  1. On the DNA250C with 2 cells I don't know the maximum voltage output but I'm pretty sure that isn't much more than a DNA250 running on 2 cells which is 6.2 volts.
  2. I'm curious as to why you are talking about temperature when it doesn't apply. Sure Device Monitor shows the "set line" but the board does absolutely nothing with the temp setting in this case.
  3. So I did some testing with some of mine, here are the results: Using my meter to measure output voltage off the posts. DNA75-- 0.98 ohms--17 watts-- 4.04 volts. DNA75C--0.99 ohms-- 17 watts-- 4.03 volts Dna250C-- 0.98 ohms--17 watts-- 4.03 volts Kanthal coil All mods have internal resistance set. I figure that FW causes slight variances with resistance readings So they say they don't compare vape wise, maybe slight adjustment required to power. I say *****, either that or I need a new meter. The board is probably better than most meters anyway.
  4. This way is the way to contact Evolv" https://helpdesk.evolvapor.com/index.php?a=add&category=1
  5. If yours is a DNA250C it takes the color screen, I'm not sure of the size without looking it up but all the DNA color screens are the same size. TFT color screen for DNA75C, DNA100C and DNA250C
  6. Protovapor still has some color screens. https://www.protovapor.com/product/replacement-dna-screen/
  7. If you use Google Chrome or the new Edge for your browser just right click the text in the post and select "translate to English". On occasion you might need to adjust the language being input, choosing "detect language" is easiest.
  8. Here is an example of what's requested, this is done with Windows Snipping Tool but any screen grab will do.
  9. Up at the top of EScribe under the Help there is a Backups tab, this automatically does backups when connected to a device and you can pick and choose from various backups by board and date.
  10. Most folks use the Replay profile, and of coarse wattage is selected as material though TC wire is required. Or you can enable Replay in the TC profiles as you desire. It's just super easy to use it without TC.......but either way. Now does your TC work? Edit: I guess you answered that in the post above.
  11. Your SS316 profile should look like this except your power settings ect. will be as you want. In this profile Relpay is enabled. It is optional, your choice. Disregard the box puff playing. No need to check that.
  12. I will try to help you with it. Connect your 250C to EScribe and click "Mod" tab then "Safety" tab and using the drop down menu change from "normal coils" to "dubious coils" and upload settings to device.
  13. It just keeps the software as is till the application to the government is approved or denied, Things had to stay as they were from US vape manufacturers till the cutoff date. Note Evolv sell nothing to individual any longer. The software is considered nicotine. Even zero nicotine e-liquid is considered nicotine. The big tobacco companies have their vape products for sale all over.
  14. Federal laws, the government thinks we should smoke tobacco and pay the taxes on the cigarettes. Nothing new was allowed the be added to an existing product. Every piece of your vape is considered nicotine in the US. The ;land of the free.......right?
  15. I would think that the reason that it's not in the latest EScribe is because an update wasn't needed. I can't think of anything that needs fix'n
  16. If the firmware is the US version that is the problem. Restore to default as last resort and only after you saved your original configuration.
  17. Proceed with caution
  18. And while they last: https://www.protovapor.com/product/replacement-dna-screen/
  19. Oh, I seemed to have overlooked this, make sure that you are using the International firmware. In the bottom right lower corner of Device Monitor will show the current firmware that's being used.
  20. Perhaps save your current configuration. Under File/Save As
  21. Look at the settings in EScribe
  22. For starters make sure that you uploaded settings to device. Make sure that you are using the desired profile. Use EScribe's Devise Monitor to check wattage output when firing.
  23. Color screens available here: https://www.stealthvape.co.uk/product/dna-75c-250c-screen-replacement/
  24. I don't have a small screen 60 but I did plug in my big screen 60 to see if it would offer the update and it did not. Ask Evolv here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
  25. I'm only seeing 1_2_SP6_1 INT as the latest on my PC for either large or small screen DNA60.
