Everything posted by retird
hum, I found many unused wallpapers in a file (not show in theme) and deleted about 5 and it still would't load.... didn't delete any wallpapers being used by the theme tho.... good you got it to load @Wayneo. I'll delete a wallpaper being used and load it.... curious about the theme contents....
That .ecig file gives me the same error message that you are getting. I wonder if the Mod Designer has somehow locked the file so it cannot be installed on another 75C device? I also grabbed just the theme out of your .ecig file to try to upload and get the same message. From your .ecig file I see this and you might want to contact them at the e-mail shown... Please let us know what you find out.,....
Can you save the .ecig file and attach that file to a post here... I'll look at it... Also attach the Theme file you are trying to upload...
Are you trying to upload the .ecig file or just the Theme?
Maybe it is a bad pod? You updated the Orion to the Orion Plus with the software update that Lost Vape put out. The pods that work on the Orion continue to work. Maybe the pod is just bad .. You might check Lost Vape web site to see if they have the original software available. Did you ever have any old Orion Q pods?
cotton always cut in half in tc mode
retird replied to leea12345's topic in DNA 75 Color and 100 Color
Can you post a picture of it? -
Resample resistance when switching profiles?
retird replied to TubThumper's topic in DNA 75 Color and 100 Color
Cat out of bag?.... deleted info...... You read it so now deleted to maybe not get banned from ECF.... -
"retired" was not me...... -
Are your drivers up to date? Could this help????? https://www.drivereasy.com/knowledge/fix-usb-composite-device-driver-error-solved/
Memories........ 😀 Yep I too started with the Darwin too and have a " herd" of one of each board.... still use the Darwin from time-to-time... As you said... "I really miss seeing Basil, Mike P, Jaquinth, Retird (that's me)and others. I even miss Dr G because when he wasn't beating back the perceived trolls he had great posts Great times, days and people!" Those were good times at ECF before Dr G got booted and some of us got grilled and investigated twice by ECF for false claims...... put a bad taste in our mouths' and I left ECF. -
DNA 75C - SS316L Material Issue
retird replied to Chef Ginger Pants's topic in DNA 75 Color and 100 Color
Try this and see what goes: Make sure all connections are tight in the atty and no coil wrap is touching the one next to it (called a spaced coil). With the atty off the device fire the device several times. Now let the atty and the device set until both are at room temperature. Screw on the atty, fire the device and select "new coil". This sets the cold ohms as can be seen in Device Monitor. The Live ohms will be higher as you vape as the ohms elevate due to heating the coil. You should not get an immediate "temp protect" message and the message will show when the set temp is reached. Temp Protect is not an error message but lets you know the temp has been reached. An immediate "temp protect" can mean a hot spot in the coil or coil wires touching each other among other things. -
My best guess is that it is either a bad circuit board or excessive heat while soldering battery wires (negative connection) to the board may have damaged it. From your picture it looks like the area around the negative solder point is discolored like it got very hot. At any rate just start a ticket with Evolv and explain it to them and provide the pictures... they will guide you... https://helpdesk.evolvapor.com/index.php?a=add&category=1
Does the screen light up when usb cable is not plugged in?
Not enough info from you to determine the issue.... did you build the mod? The default firmware and software should be OK. Best guess is short circuit or bad grounding. More info would help....
Once the cotton wicking gets burnt it's done and the taste will remain. .... replace with new wicking/coil/pod depending on what you have....
DNA250c Balance port info needed please
retird replied to jsforder's topic in Batteries and Charging
Here is a data sheet for the 250C.... may be of help to you if you don't already have the datasheet... https://downloads.evolvapor.com/dna250color.pdf -
Glad you got it sorted out.... and glad your vendor came thru....
Steam Engine has a calculator that can generate CSVs for custom materials.
You are good to go...... and yes EScribe will suggest an update when available...
temp control issues advice please
retird replied to leea12345's topic in Manuals, Instructions, and Tutorials
I assume the 75C is your first DNA device... DNA's work best using spaced coils (coils do not touch each other). Connectivity of coil to the atty should be tight and a good connection between the atty and the device when using TC. Many things can cause the TC to drop out to power mode. You might want to build a single wire coil (spaced coil) with the SS316L material and strive for consistent TC. Then play with the aliens again... -
Read thru this thread and wonder if you have tried this basic exercise....... Have you made a single wire spaced coil (not alien) and tried that. Use wire Material such as Kanthal, SS316L, etc. Check the ohms reading with an ohm's reader before using (reading would be the cold ohms). Device is at room temp and atty at room temp before firing as a new coil? Fire device and select "New Coil" What reading do you get for Cold Ohms? What reading do you get for Live Ohms?
Oh, you can post in your language as we can translate easily here.... might be easier for you and for us....
We don't need date of purchase here. Best case with Evolv is that they may want you to send them the device or maybe just the board out of the device or maybe they just will send you a board.. They will guide you...
OK... I am concerned about 3 things. 1. The board temperature is too low showing only 42.71 F. 2. You have had the device for 1 week and vaped 7000 puffs. How many puffs did it have out of the box new? 3. The wattage shown while firing is too low and not as smooth as it should be. Many things can cause this. Here is a screenshot of my DNA Go device set at 9 watts... You have started a ticket with Evolv. It is the weekend so they may get back to you in a few days when the work week starts.. They warranty the board, not the device. If they decide to look at the board they will guide you on what to do. You might send another ticket to Evolv and include the last screenshot you posted. I shows the 3 things I listed. Since your device is 1 week old I would try again to get the seller to replace it. That would be the easiest especially if the board is good but the device assembly is faulty. That's the best I can troubleshoot without having the device as you say both atty's you tried are functioning properly. Good Luck and just for your info we are not employees of Evolv but just help if we can.
