Everything posted by retird
Escribe downloads... https://www.evolvapor.com/escribe
CSV files for Molicell/samsung batteries
retird replied to greenbrucelee's topic in Batteries and Charging
https://www.stealthvape.co.uk/download/molicell-p26a-18650-1s-40w/ This DNA forum has a search function that you can use... -
A quick google search and have not read thru them............ Legacy MOOCH review and test results if you are interested: 2015: https://www.e-cigarette-forum.com/threads/a123-anr26650m1-b-2400mah-3-3v-26650-bench-test-results-an-extraordinary-battery-with-issues.770987/ 2016: https://www.facebook.com/batterymooch/posts/a123-anr26650m1-b-2400mah-33v-26650-bench-test-resultsan-extraordinary-battery-w/1793033857652859/
I have been using a Theme with my 4-cell 250C (configured 400 watts) for over a year. It was one of the first Themes, designed by others, to display 4 cells. I saved the theme from my device and attach it here in case you want to look at it. A very comprehensive theme with loads of features. Theme.ecigtheme
Exactly my thoughts about you. 🙂😊 In the past 10 years of trying to help folks with DNA stuff I have come to the conclusion that when they have trivial issues or trivial questions, they are not trivial to them or they would not have posted.. The only stupid question/issue is the one that never gets asked or posted. 😊
Here is the Data Sheet for the 250C. Lots of info if you care to read it. Also includes a wiring diagram for 2,3,4 cell devices. There is no 400C circuit board, just a 250C board that can function as a 400 watt device depending on how it is configured. Don't take this wrong but the barbs you throw in several posts aren't constructive. I see you just recently joined us, a friendly bunch around here, and I want to WELCOME you. https://downloads.evolvapor.com/dna250color.pdf
Great info to remember....THX
I took a quick look at the .ecig file you gave and none of the profiles is the Power set to 70 watts.... You are using Profile 2 (Watts) right???
Go to the profile in escribe and see if it is locked and uncheck. You may be able to do in the Theme but have not looked at your theme..
Oh, I rechecked the csv file and now see what you say is going on. Didn't scroll down far enough to see it... Your cold ohm's are showing 0.144 and your live ohm's is showing 0.139, 0.14 to 0.142. That is not normal. Cold ohm's are set with the atty and device at room temperature. Cold ohm's should not be locked... Fix this first and see if that helps.
Check cold ohm's vs. live ohm's..... did you lock cold ohm's? The csv file shows firing at 70 watts or just barely below...
That pretty well says it all. And as @James said: TC with Replay is fine. I didn't expect people would combine the two, but the features are (mostly) orthogonal, so there is no reason it shouldn't work if you really want to do it. If it tastes better I am glad.
Try this: In power mode set to maximum if you accidently turn off Replay what happens?? Say you set TC to 400F when you get the best vape at about 365F. Your first vape is not what you want but the second one is so you set Replay. Device Monitor shows your Replay Temp is running at 365F. Max TC is still 400F so what happens if you accidentally turn off Replay? And, again @James said: TC with Replay is fine. I didn't expect people would combine the two, but the features are (mostly) orthogonal, so there is no reason it shouldn't work if you really want to do it. If it tastes better I am glad. Screenshot: Replay in TC mode Screenshot: TC mode with power set to 70 watts using Replay. Screenshot: TC Mode with Replay. TC set to 30 watts and 365F:
Great that you found what you like. Replay works for me in TC mode using premade Notch coils that are very consistent in resistance. TC does not interfere with my Replay but it may with yours. As long as we get what we want it matters not whether we are in TC or Power Mode using Replay.. And in TC mode I can set the peak temperature I want to guarantee I remain vaping at a safe temperature. That's how I roll anyway...😊😊
Just 1 comment. @James wrote: No, Power mode is not necessarily better. If you are already comfortable with TC, by all means, TC with Replay is fine. I didn't expect people would combine the two, but the features are (mostly) orthogonal, so there is no reason it shouldn't work if you really want to do it. If it tastes better I am glad. I spent a great deal of time tweaking TC for my notch coils and now always use Replay in TC mode. I set Replay in room temperature. This works for me but I'm in the minority as it is generally used in Watts mode. TC mode setting keeps me within the "safe" temperature.
And a kinda-tutorial video to add to @Wayneo's excellent post.... Start at 9 minutes into the video... and in Watts/Replay you do not set a temperature like in TC.
Most folks use the Watts profile but you can use the TC profile. Just a note.... The Temp Protect message usually just means that you have reached the set temperature and thus not usually an error message.
Also I see the atty information says this: Top filling or bottom filling design with exchangeable squonkable bottom pins. Could be a connectivity issue between the atty and the device.
What you are asking for does not fit the category of "common problems". I don't want folks that may read this thread to think there is a "problem". I think it better is placed in the category of "I wish there was a theme that would do this.. if possible.." In all my years I never had interest in learning to design themes so I'm no help.. I leave that to those who love designing themes. You might message @Mr.Bottomfeeder or some of the other great theme guys/gals. There are some really great designers and great themes in the download section of this forum as you know. @Mr.Bottomfeeder designed the theme I posted for you to look at. Hope this helps. All 250C boards are capable of 400 watts if the mod is designed and built as such. Here is a DNA250C Datasheet for anybody who is interested in reviewing it. It has wiring diagrams and spec's and a lot more... https://downloads.evolvapor.com/dna250color.pdf
Here is a theme that works with a DNA400C you might look at. Doesn't have guages but......Save your theme first in case you want to reload it... As you know Device Monitor in EScribe is our friend...I use it often to see that the cells are balancing while charging. My Theme 2.ecigtheme
THX for adding that tip. I haven't modded anything for several years but this one peaked my interest.
Just wanted to add that to your thread for those who may come to read. It gives them a lot of info they may want... Great video by the way....😊
https://downloads.evolvapor.com/dna75color.pdf Datasheet for 75C....... has recommended wire sizes for anybody needing them...
If Evolv can't help you you might try Lost Vape..... E-mail: support@lostvape.com
Thanks for answering my question. In over 10 years I've never had a bad experience with Evolv. Sorry to hear that you did but I don't know what contractual agreement Evolv had/has with Lost Vape. Could it be that Evolv can't sell Lost Vape parts but only offer warranty repair/replacement?
