Are any of you having success with the file posted above (top, 1st post)? what resistance coil? what power setting? replay yes/no? what firmware (bottom right hand corner of escribe - Device Monitor)?
NOT a file for you to install.
Guessing you did not see the pinned post already in this area.
Open a ‘Help Desk’ ticket with your suggestion. ⬇️ Link in my signature line. ⬇️
No. But because it's alloyed Titanium you can use the default Ti01 material file, and set your temp limit lower, raising it higher if you want till it feels right for you. OR, if you have a 'Replay capable' mod, you can vape in straight watts at your preferred watts. OR, just vape in straight watts, starting at around 20 watts and increasing till you like it.
No.
Your mod is working as intended. There is no workaround. Even if you were to remove, fill and replace the same pod, you'll need to reactivate replay.
Just to keep this succinct; You're always getting dry hit protection and fill pod warnings, as long as you're using these SS pods. Replay or not. You can hover over the 'warmth' term (escribe) for an official definition, but Replay must be enabled for it to do anything. Notice the default is 1. You can enable Replay whenever you want, and it's not working until you do.
Just popping in and out again, and apologies if you already realized this. Boost works at the start of a puff. Warmth is only activated if Replay is enabled. You really won't notice warmth unless you only activated Replay near the end of a session and allowed the coil to cool down.
Reset using escribe. Device Monitor. Bottom right hand corner.
OXVA Xlim Pro 2 DNA Problems - "Fill Pod" and Stuttering Vape
Wayneo replied to Simon Martin-Lemmon's topic in Oxva Pro 2 DNA
Closing the airflow a little more, or increasing the pressure while taking a hit might help fix the stuttering issue. As for the 'fill pod' issues, I have no advice and I hope you did not change any parameters in escribe. If you're not sure you could always reload a copy of the original. -
That other user had some different issues. Have you updated the firmware on your mod, from the file on this site, and what is it. -
That's as long as it can be for now. Open a ‘Help Desk’ ticket and ask for the Manufacturer's limit to be exposed. ⬇️ Link in my signature line. ⬇️
XR-80 Boro AIO By Monarchy & Vaperzcloud
Wayneo replied to KamilB's topic in Themes and Custom Screens
You're welcome. Enjoy your mod. -
LostVape typically installs the Evolv default settings with maybe a logo and some extra non-TC material names on some profiles. I'd suggest you just look for a wallpaper with the logo, that is easily copied from a theme.
Under 'Help' the mod has been keeping backups on your behalf. Go restore from a date before you did your accidental delete. -
Open a ‘Help Desk’ ticket ⬇️ Link in my signature line. ⬇️
That's fine. Warmth is only used by Replay.
Yes. Turn off boost/warmth on mod. Start 'Device Monitor', only enable 'power' 'power set', <- that shows what is set, take a puff, hit pause, hover mouse over the lines.
Open a Help Desk ticket with your suggestion. ⬇️ Link in my signature line. ⬇️
Thanks for the updates.
On the mod. Right after the 0.6. Like the 1 o'clock position of the Ω symbol. I double my nic from my regular mod, and 15 watts for me, gives me similar flavour.
I do the opposite. I leave my warmth at 2 or 3, and adjust my boost. I'm running my 0.6Ω pod right now at 15 watts. It's a pod. I know others running theirs at >23 watts. Boost has always been at most 1 second. Turn up your watts to the heat you like, and if you want more at the beginning add some boost. If you look really carefully at that Ω symbol you'll notice a little squiggly through it. Those are equivalent ohms. They vape very similarly to the regular OXVA .6Ω pods. That's 100% correct, as shown by Atomizer Analyzer. Did you really believe all these pods from all the manufacturers build to such exacting standards. How you get to the vape you enjoy is all up to you, and your device is working as expected.
