You're welcome. I'm gonna change the subject title to better reflect the issue. Hope you don't mind.
Were both batteries charged externally? And what make and model are they? Look at each battery's voltage right now. Unplug your mod, and swap the battery positions in your mod. If cell 1 (old cell 2) still shows lower than cell 1, then we know something is wrong with that area. Either way you might want to clean all their contacts with Isopropyl alcohol (IPO), or even better, semi dismantle the mod and look for ejuice and wipe down the area around the bottom of the board (both sides), those 2 fatter connections and those 5 small ones. There might be white connector which you can pull apart off the board. Wipe down everything. Looking at your screenshot, ideally/regularly they should be parallel. When you take a puff they should both dip/sag equally. No, it's not dangerous, but it should be fixed. Because that % is based on the lowest cell, your mod will give you a weak or check battery much sooner than it should, and stop working.
Thanks, great. Your cell 1 is only at 3.5V. That % is based on the lowest cell. Charge both fully, hopefully externally and try it then.
Show me, like before.
That's one of those relatively rare issues, that even I wouldn't be able to come up with good search terms (but I have seen it a posted here). I'd suggest you open a Help Desk ticket. ⬇️ Link in my signature line. ⬇️ Edit: Thanks for that Device Monitor screenshot with relevant fields enabled 👍
IT WAS NEVER IN TC.
See how in your screenshot near the bottom across from material it shows 'Watts' ? So you were never in TC. If it happens in the future, follow what I said.
Yup, that was perfect. That all looks pretty normal. Did you remeasure the Ω's of your coil?, the photo showed 0.11Ω's, now 0.19Ω. Do you have another atty you can try on this mod? Remeasure ohms with it before use.
Start escribe with your mod plugged in, navigate to your ‘watt boost’ profile and do a screenshot. Post it here screenshot instructions in my signature line
Aaaaah, that is not 'temp mode', just a poorly worded informational message that can have many reasons. The most common reason are an ohms mismatch or runaway ohms. You should remeasure your coil Ω's and try to see if that was it, failing that you should check your coil. Let me know your outcome.
What do you mean by that?
Yup, gonna lock this thread. Re-read what I have posted. If you still have concerns, please open a 'Help Desk' ticket. ⬇️ Link in my signature line. ⬇️
Come on man, when I vape my room temperature does not change. I do not expect the room temperature to change. When I press 'fire' I can't even see the screen. Why do you think it should change?
OK, so think this through. When you hit the fire button, batteries generate heat (but this doesn't count) as well as inductors on the back of the board. That's where the majority of the heat comes from. Stop doing that. The programming on the board is doing all that.
In normal usage the ambient temp is pretty flat, but it will change. It really only matters if you are a TC vaper. When you put cells back in, it also re-reads the resistance of your coil.
Modalità Replay e atomizzatore RTA/Replay Mode and RTA Atomizer
Wayneo replied to Nicola420's topic in Replay and Atomizers
I'll take a guess. Weak flavor, tiny clouds. Coil barely reached 260°F. (I walked the line 🤮) -
Easy, just use straight watts at the risk of a dry burn from your cotton. -
Let me give you a general explanation based on what you have written. Replay wants to recreate the puff you saved. Your coil/mesh will raise its resistance when you fire it, and lower its resistance as it cools back to ambient temperature. When in your 'Replay' mode, but NOT enabled, the mod keeps track of that resistance curve created by your puff. And when you click 'Save Puff' your mod tries to recreate that curve. Sometimes exactly, or at lower wattages. Your mod 'right now' shows 'boost:Punch' at 3 (but not on), 'warmth' at 1. So right now you get no boost of watts initially, and it's just 50 watts. Once you click 'save puff' warmth now enters the picture. IF you were chain vaping your coil before enabling replay and your coil has cooled to ambient you will get even more watts than 50 but not too much. That's warmth. OR depending on different factors you definitely get less watts than what you initially set. Like if your coil is not as saturated as when you enabled replay. You can actually vape that mesh almost DRY without a dry burn. If you have any questions or want me to clarify anything let me know. Or if I have cleared up your understanding. -
I can't look at that. For the third time, look at dwcraig's S C R E E N S H O T -
You need to plug into your PC, and start escribe. I need you to go into escribe (with mod plugged in) and do a full screenshot of the profile you're using. When you start escribe you'll see 'current profile' and a number. Click below on that number then do a screenshot. -
@dwcraig was right when he said it could be your wicking, but post an escribe screenshot of the profile you are using. Bolded words have special meanings Screenshot instructions in my signature line ⬇️ -
DNA60c wont connect to escribe ! Please Help
Wayneo replied to GrumpiTurnip's topic in Modders' Forum
IMHO you've gotta meter out all your connections. For the USB-C you know it has worked outside the box. I'd lift that off and see if it connects, then lift at the board end if it still didn't connect. What else could it be? Same thing for the battery. Using 1 battery, measure it externally then in each slot at all the connection points to the board. Then do the other battery slot. Same thing for the fire button and up/down.
