  1. Same coil as before (or all week) when it was working fine? Can you let that atty sit for 10-15 minutes, THEN do the resample, puff and save
  2. If you still have questions after reading that post ⬇ let me know https://forum.evolvapor.com/topic/71835-color-themes-compatibile-with-all-c-boards/?do=findComment&comment=938444
  3. There have been many escribe updates. Click on the link in my sig. No update required for the battery size. Choose Li-Ion18650. Think of round cell or cell in a canister instead of 18650. They all share the SAME characteristics. Like what? Even with the old 26650's, they all charge to 4.2V and have a fully discharged value of ~2.5V. Just because it's longer? Edit: You should read the link below to answer your theme question. https://forum.evolvapor.com/topic/71835-theme-compatibility-with-the-dna100c-hyperion
  4. Go read his very first post a second time.
  5. YES! Every theme that is posted will for sure load on the 100C and 250C, and nearly all will load on the 75C. Not every feature a theme has will work on the 75C or the 100C. A good theme designer wll not even show a feature if it won't work on your mod. EDIT: will for sure <- Should really change to if it can load on the 250C it can load on the 100C
  6. Good luck with your mod 🙌 They've gone above and beyond. When you get it back, ask or search here first.
  7. since yesterday?
  8. Did you ever get it to connect to escribe? No comment on what they thought was wrong? On the topic of warranty, it's always been 1 year on the board (not screen) to the OG purchaser https://www.evolvapor.com/warranty
  9. Have you heard back from the Help Desk, and if so, what did they say?
  10. All 250C's are wired serial. You just don't see the long ass wire used to have both batteries pointing in the same direction EDIT: You may as well just send the Help Desk that first photo
  11. OR in my signature line, there's a link to the Help Desk, you could open a ticket with them
  12. IIRC in that drone, both batteries go in, pointing in the same direction. Or restart your PC and try again. No use getting pissed off, that doesn't help anyone. 👍
  13. Sadly, I can't see a full screenshot. It should show everything like that first picture including the bottom corner which would also show the current firmware on your mod.
  14. I can wait for a full screenshot like I asked before, when you get home. That photo cut off the firmware information I don't see any puffs at all, I don't see any batteries in there. Are you saying those 400 puffs disappeared during a firmware update? Was it working fine for those 400 puffs, then just stop, or what did you do shortly before? EDIT: At this point hoping to see the latest firmware installed
  15. Can you post a full screenshot from Device Monitor. I imagine one of your 2 cells is showing a low voltage That is usually a shitty theme error, and for now you should reinstall the default. Or even (one of the very few times I've ever recommended) a full Restore Defaults in escribe. You should also update to the latest Service Pack (link in my signature line)
  16. Ummm, the DNA250C does NOT have a 'USB-C' connector. 🤷‍♀️ Something's off here, are you sure you have a 250C product
  17. If you did not understand the djlsb video, try finding one in your native language. If you do not understand something we say, ask us to rephrase our comment. These quotes make no sense if you go back and read prior posts
  18. @IcyFridge It will not be accurate, so no. Plus, that would not fix {in any way} the discrepancy you see between the mod and charger display
  19. Weak watts is not a DNA warning. Maybe weak battery which would mean your battery is too low (in volts) to apply 85watts. Normally fixed by charging the battery or using a higher amp battery.
  20. You should look through this datasheet and also pick up some silicone sheathed wire and jut rewire it completely. Ideally you have an electronics store nearby, or maybe even stealthvape. You'll only need a max of 4 wires about 6 inches of each (max) https://downloads.evolvapor.com/dna75color.pdf
  21. Brought to you by the same people that do not recommend firmware updates. 🙃 They missed the word (externally, about that 3A max) I'll quote what I said 6 days ago elsewhere "That simple swapout to charge means you’ll be using a Lipo charger. Depending on how you vape you might get away by just plugging your mod into 2A charger during the day. Remember it’s really 4@1600 mAh cells, each charging at 2A/4(cells) or .5A each. Your mod comes with a great balance charger for th batteries." You can use your 3A charger (I use a much more powerful laptop charger) because your mod will only ever draw 2A max.
  22. That's the same distance as the 100C, so the buttons should line up. It might be tight in there. Here's the drawing of the 100C if you want to check even more. https://www.stealthvape.co.uk/product/evolv-dna100c/ Good luck.
  23. What is the distance in mm from the middle of the bottom actuator to the middle of the USB connector? on the cyborg
  24. So if you have a 4 cell (battery) mod, if one or more cells is lower than the highest it can appear very slow as it's a balance charger. It would be much quicker to charge externally (even if it's just that once cell), to get them balanced again. escribe Device Monitor will show the volts of each cell, or maybe the theme on your mod EDIT: The DNA250C balances the charging for every cell count. 2-4 cells. Added for clarity.
