What version software is on your PC? Have you tried different cables? Do you know or heard of any other users of this SXK device that have used escribe with theirs?
Escribe -> safety tab.
It should still be under Manufacturer warranty. I'd return it to place of purchase or ask Mission. It does not sound like a board problem.
Think Vape Finder 250 (without c) lost Firmware
Wayneo replied to Fearomoon2's topic in DNA 200 and 250
NONE of the files posted so far are FIRMWARE files. These have ALL been theme files (logo, etc). A FIRMWARE file has a .ecig file extension. -
You could use a multimeter at the back of the jst connector to measure each cells voltage and the total pack voltage
While the retailer should be the one to address this, I'd really suggest you open a Help Desk ticket, and let Evolv guide you. Like Bill, everything looks somewhat normal with decent brand batteries. All the cell soft cutoff does is say what voltage to generate a 'Weak battery' warning, letting you know the 'check battery' will be coming soon. The polling interval for device monitor was ~4 times per second, on the mod it is always reading everything live and at a much faster rate. There are no warnings or errors on escribe Device Monitor, only your mod. You think it's heat related, BIll thinks it's the board, I think it could hardware, firmware, or an over taxed battery(even though it wasn't hot). Hence, my suggestion to contact the Help Desk (link in my signature line)
When the mod starts limiting the watts, can you feel the battery, and is it hot or anywhere on the mod hot? How long has this been happening Can you tell me the battery details. Can you tell me the firmware version on your mod. For future DM screenshots, can you do a full one (it would have shown firmware), and you only need volts, power, power set.
Yes, excellent. And turn down the watts while vaping. From your Profile 2 settings, with the DRv2 you are using everything basic. Any/every mod with no sort of boost, with fresh batteries should be almost identical at 55 watts. Every atty/RDA you need to check/prepare the coil before wicking. Low glow dry burn and check for hotspots Because it's an RDA you need to keep those wicks juiced up between puffs (5, 10, 12 puffs). I can't see it being your mod or RDA.
Easy Answer: Turn down the watts. Longer Answer: Do a FULL screenprint of your current profile in escribe, like this and answer the 3 questions below. Did you try your DRv2 on your friends mod? And how was it? What material (wire) are your coils?
How/where in Escribe to change puff count?
Wayneo replied to BlueALtra2013's topic in EScribe, Software and Firmware
If you were to look in theme designer at that field it should show 'Statistics -> since reset -> puff count' with a tick mark. Change that to 'statistics -> total -> puff count' then 'apply' when you're done making changes- 1 reply
- 1
Steam Crave Hadron Pro DNA250c room temperature issue
Wayneo replied to Anonfishe's topic in DNA 250 Color
Good with that hard reboot. Each profile keeps it's own resistance and temp when it was set, so you'll need to remeasure in each profile if your mod does not pickup the change in temp. -
You can use escribe - Device Monitor to validate what that theme is showing you. It's on the left hand side of DM down by where the graph ends. 'Room temp'. Couple of questions; How many different profiles do you use on a typical day, and what one(s)? What firmware is on your mod? I have never seen any 250C where that temp would always stick at a specific value every time. I don't use that theme, but if does not match with 'Device Monitor' leave a comment for the theme author on his theme. -
Short Answer - Nothing wrong with the board, your dealer was right. Longer Answer All 3 board types (75C, 100C, 250C) use different BMIC's. All 3 behave differently. Each board type also has different screen on, quiescent and power down 'current draw' rates, and internal timers. The 250C with the latest firmware powers down after 24 hours of waiting for a button press or an atty removal. That's usually at most .1 volt per cell. That timer has been adjusted over time and IIRC ~SP33 it was at 12 hours. But on the 250C, once it powers down it completely rereads the temperature and coil Ω's on startup.
Hyperion dna 100c internal resitence test on escribe
Wayneo replied to SVAPROLET's topic in DNA 75 Color and 100 Color
any update on the topic? ➔ No. Stil100c can't be calibrated? ➔ Haven't checked, so can't say. -
Your mod works fine out of the box with that default battery profile. A battery profile to match YOUR battery type will ONLY make the icon or % on the display more accurate. YOU can run your own Battery Analyzer for that battery. All you need is an RDA, a kanthal coil and an hour of your time.
Escribe will not connect to any of my mods.
Wayneo replied to Folkart's topic in EScribe, Software and Firmware
Thanks for reporting back in with your success. For others that might stumble across this post, no drivers are required at all, as that is now handled natively within Windows 10. -
Download this version and install. https://downloads.evolvapor.com/SetupEScribe2_SP50_INT_ServicePack.exe The SQEVO is a DNA mod, the Pulse is not. Hopefully you can plug into the PC directly. And use that SQEVO -
Have you ever used escribe on this PC before? What mod? OS version? Just what Service Pack did you download? I'm a Mac guy, but these are usual steps taken Reboot PC. Use a known data cable (like for your phone), if you can plug directly into PC (not a hub). -
Can I customise the actual Power, Watts, Ohms screen with custom images?
Wayneo replied to dylanl5883's topic in DNA 60
Well ........... yeah. Black and white only, on each profile. In escribe. You can't change the display font of the mods working parameters though.- 1 reply
- 1
Tim, never pestering. I don't create many new posts but this issue deserved a dedicated post explaining the conundrum.
Tim, Dicodes Resistherm material is different because it contains trace elements of Aluminium, Chromium, and Manganese. The entire NiFeXX is sorta in disarray. I try to explain it better here. https://forum.evolvapor.com/files/file/1570-6-nife-material-files-and-tcr-list-for-all-dna-mods/
At the top of that same page it shows 2 alternate batteries. You can check if their dimensions differ. Depending on how you treat your Lipo's they can start to swell and you want a little wiggle room in there (which the doors provide).
- 1 reply
- 1
TCR for SS430 and Zirconium from Zivipf?
Wayneo replied to TimWiseman9000's topic in Manuals, Instructions, and Tutorials
Howdy @TimWiseman9000. They show (for their material); SS430 TCR 184. or 0.00184 Zirconium TCR 270 or 0.00270 https://www.zivipf.com/epages/63862298.sf/en_GB/?ObjectPath=/Shops/63862298/Categories/Drahtliste Edit: Which I realize are both different from the standard steam-engine values. I would trust zivipf values. -
Glad you spotted that. The mod IIRC wil also count 'fire button' presses (lock/unlock) towards puff counts, but should clean itself up when syncing and with ecigstats. That could account for all those extras in the theme.
Show me a screenshot of ecigstats, and the bottom half of Device Monitor. screenshot how-to in my signature line. 🙂 Either way, numbers might not jive/line-up but not a problem for how your mod works.
