  1. I was not aware of the Lore using a DNA60C. Does it have any USB input? It does not sound like a 'stealth' issue, more like a brightness setting, or a dead screen.
  2. What device? Was it bought new? When did this start? How do you set your watts if you can't see anything?
  3. No.
  4. Insert a black and white image. Choose color by clicking on bottom right box called 'Logo/Welcme' and change there.
  5. 😂 Yes
  6. @emaahh Only the Evolv 'Help Desk' might answer that. Link in my signature line. I will say, as a moderator and using their products for nearly 10 years I'd prefer a few minor changes, but I'm more than happy with what has been produced and in use now for over a year.
  7. Not possible, but (on your mod) you go to settings, then scroll up to the 4 dots at the top, push fire button, you'll see your puff count there. Reset using escribe.
  8. There is NO 'theme designer' for the 80C. All changes such as wallpaper, icons, words are changed/customized under the 'Display' tab.
  9. Did you even look through this area before posting? I think not. But look at the post title directly before yours. ⬇️
  10. Screens that go bad usually develop a small white blob in the middle that grows to be a thumbprint size over time. In all my only 1 has ever done that.
  11. Even that's replaceable for like $12 USD
  12. Yes, I understand the problem, but in my opinion you should focus on the board temp primarily. Afterwards we'll look at resistance. Plug in the 75C mod (nothing attached to the mod) How much does the board temp rise just sitting there and not being used? Note down temp after 2 minutes and 20 minutes after being plugged in. Leave mod and escribe running. Attach Bakx. How much does the board temp rise just sitting there and not being used? Note down temp now and 20 minutes after being plugged in. Report back those 4 temps like below , and battery description. 75C Nothing attached 2 minutes (temp here) 20 minutes (temp here) 75C bak attached 2 minutes (temp here) 20 minutes (temp here)
  13. What atty is that? Have you tried a different one on that mod?
  14. NO. What atomizer would that be? Can you do an escribe 'Device Monitor' screenshot while firing with only Power, Power Set, Cold Ohms, Live Ohms enabled
  15. @Jooki First I must say you've posted most excellent DM screenshots. It would be much easier for you to do some tests at 50 watts so @dwcraig1 doesn't waste his setup at 80 watts. Mooch hasn't updated his listing to show the P28B, but the P28A's were only really a 25A battery good for 75 watts.
  16. Dude, both @dwcraig1 and I are volunteers. We are NOT employees. That's been the top line of my signature line on every post for years. I'll include @JacobEvolv here. HE IS AN EMPLOYEE. @JacobEvolv You might wanna start at the top.
  17. Seriously, if you look in the DNA60C area you will see that I have personally created 4 pinned posts regarding this new board. In my opinion I should not have needed to do that. I was not asked to do that, and I understand the frustration of regular users and builders. But yelling at us (ALL CAPS) is not going to move the needle. I share your frustration.
  18. 137 DAYS AGO I SAID THIS YOU BOUGHT A HUSSAR PRODUCT. OH WOW, 137 DAYS AGO YOU COULD HAVE REACHED OUT TO THEM ALSO. IT IS ALSO NOT REASONABLE WHEN YOU HAVE BEEN GIVEN TWO OPTIONS TO FULFILL YOUR WISHES TO THEN COME BACK HERE, BEFORE REACHING OUT TO EITHER OF THE 2.
  19. Was it this way yesterday when you first purchased it? Yes. I believe if you purchase a new screen from Stealthvape in the U.K it should fix your color issues, and Stealthvape should be able to verify.
  20. We have NO idea what theme is on your mod or what changes have been made by your Manufacturer. Here's a listing of the default Evolv informational/warnings/errors in their theme for the 60C, both long and short forms. We only understand these. To find yours; Start Theme Designer (with mod plugged in) Choose Connect and Download Theme Then go to the Language tab. Tell us the Long wording *Change yours at your own risk. You can't harm anything but you can overflow the field size which screws up your display.
  21. Dude, not a DNA issue. Go find a battery forum.
  22. IMHO, but I'll defer to DW if he doesn't agree. You have a non functioning board right now. I'd pull the board, clean and reflux the 510 ends and the area on the board. And redo the soldering. Seems we posted at the same time. I'll let DW comment.
  23. It was worth a try. Follow what @dwcraig1 said.
  24. Dude is that 510 positive able to move up and down if you push it with a screwdriver. If it's stuck down it won't make a connection. You might wanna test a few more attys. Usually if you see 5-11 puffs on a brand new mod, that shows the board was tested before being sent to you. Actually all boards are tested before shipping. EDIT: You might be able to push the positive up from the inside of the mod, which is probably the easiest, to check.
