James Posted August 5, 2015 Report Posted August 5, 2015 Thanks speed4mee. That is a good find. I've rebuilt it and no longer get that error.So there's a newer version up. Also made Device Monitor remember the time scale while I was at it.
speed4mee Posted August 5, 2015 Report Posted August 5, 2015 Another bug in the 8/5/2015 EScribe Version:Sorry, it's German If i activate debug with 7-click on Evolv Logo then all is ok.
James Posted August 5, 2015 Report Posted August 5, 2015 Good find. Fixed. I updated the 2015-08-05 download.
speed4mee Posted August 5, 2015 Report Posted August 5, 2015 Is it possible to show a live view from the screen of the display that isn't attached This can be useful for testing a mod without an attached display or with a defective display.My display is dead and so i wish a software screen for the missing display.
laadam Posted August 6, 2015 Report Posted August 6, 2015 Just tried the new update, 2015-08-05 EScribe, 2015-07-29 R1 firmware.It forced a new USB driver install that put EScribe into a "not responding" state.Bricked my V200. Closed everything through task manager and re-opened.Using the tools menu, I forced the firmware upgrade and everything is up and running.However, I lost all data and settings... like a factory reset!BTW, running Win7 32bit
VapingBad Posted August 6, 2015 Report Posted August 6, 2015 Sounds like you updated while the device was connected which is asking for trouble, but if you had saved your escribe settings you should be able to reload them like most software. It is not "bricked" unless it never works again.
laadam Posted August 6, 2015 Report Posted August 6, 2015 VapingBad said:Sounds like you updated while the device was connected which is asking for trouble, but if you had saved your escribe settings you should be able to reload them like most software. It is not "bricked" unless it never works again.You are right, it was connected! Not doing that againRegardless, it's working now.I'll search the forum, but where are the settings saved?
James Posted August 6, 2015 Report Posted August 6, 2015 VapingBad: What do you mean by while the device was connected? Normally it's connected when it suggests updating firmware. Or have you found that affects its success?
laadam Posted August 6, 2015 Report Posted August 6, 2015 Hold up, doesn't the device need to be connected to update the firmware?Or am I missing something...
VapingBad Posted August 6, 2015 Report Posted August 6, 2015 James said:VapingBad: What do you mean by while the device was connected? Normally it's connected when it suggests updating firmware. Or have you found that affects its success?Connected when updating the escribe executable not the fw, that's how I read it, but could be wrong.
laadam Posted August 6, 2015 Report Posted August 6, 2015 VapingBad said:[QUOTE=James]VapingBad: What do you mean by while the device was connected? Normally it's connected when it suggests updating firmware. Or have you found that affects its success?Connected when updating the escribe executable not the fw, that's how I read it, but could be wrong.[/QUOTE]Yes, EScribe was already updated. The failed update was of the firmware.Sorry for the confusion.
VapingBad Posted August 6, 2015 Report Posted August 6, 2015 laadam said:[QUOTE=VapingBad][QUOTE=James]VapingBad: What do you mean by while the device was connected? Normally it's connected when it suggests updating firmware. Or have you found that affects its success?Connected when updating the escribe executable not the fw, that's how I read it, but could be wrong.[/QUOTE]Yes, EScribe was already updated. The failed update was of the firmware.Sorry for the confusion.[/QUOTE]Sorry my bad, you know what they say about assumption, sometimes Windows is too slow assigning drivers and can do it if it is a known device just on a different port.
laadam Posted August 6, 2015 Report Posted August 6, 2015 VapingBad said:[QUOTE=laadam][QUOTE=VapingBad][QUOTE=James]VapingBad: What do you mean by while the device was connected? Normally it's connected when it suggests updating firmware. Or have you found that affects its success?Connected when updating the escribe executable not the fw, that's how I read it, but could be wrong.[/QUOTE]Yes, EScribe was already updated. The failed update was of the firmware.Sorry for the confusion.[/QUOTE]Sorry my bad, you know what they say about assumption, sometimes Windows is too slow assigning drivers and can do it if it is a known device just on a different port.[/QUOTE]Windows can sure be wonky that way... Since I'm a Mac user, had to dig out an old netbook of mine to run the software so that just adds to the slowness. I wanted to run it natively and not through parallels or bootcamp.
sammao Posted August 6, 2015 Report Posted August 6, 2015 Date:SetupES_2015-08-05.exeVersion:1.0.29.2Unknown error:System.Reflection.AmbiguousMatchException: Ambiguous match found.at System.RuntimeType.GetPropertyImpl(String name, BindingFlags bindingAttr, Binder binder, Type returnType, Type[] types, ParameterModifier[] modifiers)at System.Type.GetProperty(String name)at CookComputing.XmlRpc.XmlRpcDeserializer.MapStruct(IEnumerator`1 iter, Type valueType, MappingStack mappingStack, MappingAction mappingAction, Type& mappedType)at CookComputing.XmlRpc.XmlRpcDeserializer.MapValueNode(IEnumerator`1 iter, Type valType, MappingStack mappingStack, MappingAction mappingAction)at CookComputing.XmlRpc.XmlRpcResponseDeserializer.DeserializeResponse(XmlReader rdr, Type returnType)at CookComputing.XmlRpc.XmlRpcResponseDeserializer.DeserializeResponse(Stream stm, Type svcType)at CookComputing.XmlRpc.XmlRpcClientProtocol.ReadResponse(XmlRpcRequest req, WebResponse webResp, Stream respStm)at CookComputing.XmlRpc.XmlRpcClientProtocol.Invoke(Object clientObj, MethodInfo mi, Object[] parameters)at CookComputing.XmlRpc.XmlRpcClientProtocol.Invoke(MethodInfo mi, Object[] Parameters)at XmlRpcProxydb258ca3-cab5-446a-ab4f-3ead415df692.M(String , String )at A.on.hh(Object , EventArgs )
Vape_Like_A_Boss Posted August 6, 2015 Report Posted August 6, 2015 Hey James, John, or Brandon, For "beta testing" purposes for us that are installing the early software updates from this thread, would you prefer we do an "update" installation by just running the new exe installer, or would you rather us do a "clean install" and uninstall the old program from Windows before installing the new one?I haven't even had a problem to report yet, but I've had developers prefer both ways, and I've just been installing on top of the old one. I want to test how it helps you guys most though.
speed4mee Posted August 6, 2015 Report Posted August 6, 2015 I've had no problem to install over an existing version under Windows 7
James Posted August 6, 2015 Report Posted August 6, 2015 Hello sammao,What are you clicking that gives that error?ThanksJames
sammao Posted August 7, 2015 Report Posted August 7, 2015 James said:Hello sammao,What are you clicking that gives that error?ThanksJamesHi James,I just took account login.After I enter the account password,i click login button,that error will Appear.Sammao
dsidab81 Posted August 7, 2015 Report Posted August 7, 2015 This may sound too simple, but have you tested removing escribe and reinstalling as admin? I had a similar error after installing the 8/6 rc over the previous version.
Swiftroot Posted August 7, 2015 Report Posted August 7, 2015 I'm having trouble where my device isn't being detected at all with the USB. Hana v200 On 7/29 software and firmware Any ideas or what I should do?
speed4mee Posted August 7, 2015 Report Posted August 7, 2015 Which operating system do you use?Can your USB cable provide data transfer?
John Posted August 7, 2015 Report Posted August 7, 2015 There are a lot of micro USB cables that are charge only. That'd be the first thing I would try. USB had to work at Hana for them to load the newest firmware onto the device, and had to work here to get through the programming and test cycle (though that tests the board, not the connector), so the board has talked to a computer at least twice in its life before it gets to you.
