CMK
Everything posted by CMK
  1. Unfortunately, I have given a wrong input, which can lead to a display error in the main screen. MY MISTAKE! It will be uploaded soon a corrected Version.
  2. Unfortunately, I have given a wrong input, which can lead to a display error in the main screen. MY MISTAKE! It will be uploaded soon a corrected Version.
  3. 901 downloads
    Based on the "Evolv Default Enhanced 250C Theme 3.5" from JMat76, I created this SILVER version. In addition to a few small graphics changes, I have modified the lockscreen and mainscreen - but it can be switched to the original look. In the following I quote directly the theme description from the author JMat76: - Several modifications keeping the overall default Evolv theme look. -Main screen "Firing" now red when firing as well as all menu or status bars. - On main screen when not in active Replay saved puff you can select the ohm reading to shortcut you to the Coil Info screen. - Settings changed to Menu for new menu / settings platform - Most "Back" buttons removed and scroll up of down off the screen to go to the previous screen. - Watts now adjustable in 1 watt increments instead of .1. - Temp adjustable in 5 degree increments. - New menu platform dived into Profile, Puff Info, Coil Info and Settings on main menu. - New coil install screen now has cold ohm temp for new coil and old coil resistance and temp when deciding on new coil or keeping old settings. - Profile Menu has added cold ohm temp with current ohm reading and coil material setting added. Also added is the availability to have advanced preheat settings with the Preheat+ toggle when temp control is active. - Puff Info screen enhanced with chart and ability to change wattage and or temp for dialing in a perfect puff. Also the addition of several live readings of the last puff. Live ohms, room temp,average power, puff duration, puff volts, puff amps, and average puff temp, and max puff temp when in temp control. When a non-temp sensing coil is installed gives you current battery % instead of temp. - Recording Screen with new additions to be able to monitor with every puff. - New Coil Info screen added with current profile, coil material, cold ohms, live ohms, coil temp, ability to remeasure resistance, and ability to lock ohms. - New settings menu with System, Display, Device, and About. - System gives you date, time, 12 / 24 hr, F or C temp, max puff time and serial number. - New Display menu has brightness adjustment, always on, stealth level, auto lock, auto lock time out, and # of clicks to lock, and ability to set unlock device sequence. - Device screen now has power bank settings, and battery voltages for up to 4 batteries. - About Menu with Lifetime puff count, current firmware, current revision, edition, puff count total energy, and reset to take you to a rest statistics screen. Also take a look at my own Themes, especially Enhanced 2 in 1 "LOST VAPE" - Four colors
  4. Hier stellt sich natürlich die Frage, wie mit den Möglichkeiten verschiedener Profile umzugehen ist, bzw. was vom Hersteller vorgesehen ist. Ich favorisiere die Nutzung der Profile dahingehend, dass ich meinen Verdampfern eigene Profile zugeordnet habe ("Salix" / "N'[duro]-MTL" / "N'[duro]-scr" / "N'[duro]-DL" / "Pharao" / "Zeus" / "Ammit MTL" / "Brunhilde"). Von hier an möchte ich EScribe nicht mehr bemühen, sondern alle Änderungen der Konfiguration direkt am Akkuträger vornehmen, also Wechsel der Wicklungen, der Materialien usw... Der Gedanke dahinter - Verdampfer wechseln, entsprechendes Profil einstellen, fertig. Ich sehe (für mich) weniger Sinn darin, nach jedem Verdampferwechsel ein in EScribe vorkonfiguriertes Profil neu anzupassen. (Oder ich habe da jetzt was falsch verstanden). Aber das ist hier das Schöne; sich mit anderen über deren Beweggründe, also weshalb etwas in welcher Form umgesetzt wird, auszutauschen 😃
  5. Es ist relativ schwer, komplexe Themes eines anderen Autors in ihrer vollen Funktion zu verstehen, noch dazu wenn die verwendete Sprache einem fremd ist... Aber ich denke, es besteht weiterhin das Problem, dass es möglich ist, bei zuvor eingestelltem Modus die Bedingungen zu verändern; zum Beispiel bei aktiviertem TC nachträglich eine ungeeignete Drahtsorte einzustellen (als Beispiel Kanthal). Mit den derzeitigen Möglichkeiten können wir nur eine Warnung anzeigen, aber den falschen Betrieb nicht verhindern.
  6. Die Mehrstufige Leistungsanpassung habe ich auch bereits seit Längerem implementiert; in Bezug auf die Bedeutung und Relevanz der Genauigkeit des Spulenwiderstandes (also noch genauer als 1/1000 Ohm) verfolge ich eine komplett andere Philosophie, auch unter Berücksichtigung der physikalischen Gesetze. Wenn überhaupt sehe ich eine relevante Bedeutung dieser Genauigkeit im Bereich des TC-Dampfens, aber genau wegen dieser Unwägbarkeiten haben wir ja heute den Replay-Mode. Über diese Thematik und deren Bedeutung in der Praxis (des Dampfens) kann man sicher am Stammtisch lange kontrovers diskutieren - leider ist dies hier nur sehr eingeschränkt möglich, da unsere unterschiedlichen Muttersprachen sicherlich zu Missverständnissen führen könnten. Es ist sehr schade, denn ich tausche mich gerne sachlich mit jemanden aus, welcher ebenfalls sehr viel Zeit in die Umsetzung seiner Vorstellungen investiert.
  7. Das werde ich mir auf jeden Fall mal näher anschauen und mich gegebenenfalls inspirieren lassen 🤔 Da stehe ich auf einem anderen Standpunkt; einerseits überlasse ich das Festlegen des Widerstandes dem Chipsatz, andererseits müsste ich dann auch konsequenterweise die Leistungseinstellung im Bereich von weniger als 0,1 Watt vornehmen... Hier kann ich nur meine Freude zum Ausdruck bringen, dass die vielen Stunden "Arbeit" erkannt und anerkannt werden - leider gibt es mitunter sehr wenig Feedback...
  8. "Попытка (не удалось) убрать глюк, когда при использовании термоконтрольных профилей, мод при принудительном переключении в режим мощности или воспроизведения все равно показывает график температуры и значения температуры спирали." Ich denke, es handelt sich hierbei um einen Designfehler in der Escribe-Software. Ich habe im Gegensatz versucht, bei deaktiviertem Temp Control genau an diese Temp-Werte aus dem Diagramm heranzukommen, sie auszulesen - leider ebenfalls erfolglos, fehlgeschlagen. Meine Intention war ein Auslesen der Temperatur um überhaupt erst die Entscheidung zu treffen, ob es sinnvoll ist, den TC-Mode überhaupt zu aktivieren. Habe bisher keine Lösung gefunden.
  9. Danke Dir, dass Du die Arbeit in dem Theme erkennst.... Der Fehler - meinst Du die Akku-Anzeige im Screenshot? Diese erscheint nur als Warnung bei Akku unter 10%,dann steht auch alles in Reihe ohne Zeilenumbruch
    Schön, mal wieder was in deutsch zu sehen, noch dazu mit neuen (?) Grafiken 👍 Die Funktionalität selbst habe ich allerdings nicht getestet... 😬 - kann den Theme Designer nach meinem letzten Marathon nicht mehr sehen 😒
    Normally, I'm not a fan of "real" background images in the menus because legibility suffers - but here the wallpaper is chosen or edited to keep the fonts easily recognizable. Good work 👍
  10. It was not my intention to attack you personally, but your description presented these features as exclusive and this bothered me 😉
  11. That's no problem - you just need to mark the battery indicator in the Creator and save the two images
  12. 👍 Bist Du auf einem guten Weg
  13. Hola, dann lass mich mal den Anfang machen und Dich zuerst einmal willkommen heißen! Du hast in Deinem Theme ein paar interessante Grafiken verarbeitet und nun kommt das unvermeidliche ABER: meine persönliche Meinung dazu - achte auf die Usability, also auch auf die Lesbarkeit der einzelnen Screens. Besonders deutlich wird dies auf Deinem Diagnosescreen, wo der Text sich kaum von der Hintergrundgrafik abhebt; es mangelt an Kontrast. Ansonsten noch ein Tip für die Zukunft: Widerstehe der Versuchung, ob der vielen Möglichkeiten im Theme Creator Deine Oberflächen mit Funktionen zu überfrachten, stell Dir immer die Frage "Muss das sein, brauche ich das am AT?" Der Weg zurück ist schwer, ich spreche da aus Erfahrung.... 😉
  14. Hola - ich würde ja gerne direkt meine gestrige Kritik bearbeiten, aber scheinbar bin ich dazu nicht imstande - daher auf diesem Weg: nach dem Update gibt's von mir jetzt die vollen 5 Sterne und noch einen für den Umgang mit Kritik; leider reagieren nicht alle so offen, wenn man seine Meinung vertritt. Zurück zum Theme: Die Lesbarkeit hat ungemein gewonnen und auch den dezenten Farbverlauf im Hintergrund finde ich sehr gelungen.
    very cool 👍 I like the way to keep it simple ... When I look at the other themes (and especially my own) I see far too many things that are almost never used, so I've already started on one Theme to work, which combines both requirements - simple AND expanded. Your theme: great work, great graphics
  15. Ich habe auf dem Monitor-Screen einen Zugang zum Boost-/Preheat-Screen geschaffenen, um einen kurzen Weg zwischen Einstellungen und grafischer Kontrolle zu schaffen. Es ist somit möglich, auf kürzestem Weg Einfluss alle relevanten Parameter zu bekommen. Dies hat mir sehr geholfen, diverse Einstellungen überhaupt erst zu verstehen. Dadurch bin ich auch erst darauf gestoßen, dass bei einem Temp-Sensing-Material ohne aktivem Temp-Protect kein Preheat möglich ist.
  16. Hallo zark - habe gerade gesehen, auf dem change-resistance-screen muss es richtig heissen "resample" - nicht "resimple", desweiteren sollte es "Temp-protect" anstelle von Termo-protect lauten. Wünsche noch einen schönen Abend. PS: Ich frage mich, ob eigentlich allen bewusst ist, dass der "Temp-Protect"-Schalter in der Software kein Schutz im eigentlichen Sinne ist , sondern die komplette TC-Steuerung ein-, beziehungsweise ausschaltet. Der "Temp-Protect"-Schalter steht in keinem Zusammenhang mit der Statusmeldung "Temp-Protect", welche der Chipsatz bei Überhitzung ausgibt. Soweit jedenfalls meine Beobachtungen und Tests. Der Kreis schliesst sich, wenn bei einem temp-sensitiven Material (zum Beispiel SS316) der "Temp-proteckt"-Schalter AUS ist, funktioniert auch kein Preheat, Boost sowieso nicht.
  17. Das kann ich auch verstehen - allerdings wäre es mir zu aufwendig, zwei separate Versionen zu pflegen.
  18. Die Einschränkungen haben mir auch schon viel Kopfzerbrechen bereitet, zumal ich auch keine Dokumentation dazu besitze... "Out of space!" - Wie jetzt? Habe doch noch Speicher!? Nicht besonders vielsagend, dabei war nur zuviel auf dem Screen, zuviel Anzeigen übereinander, oder ähnliches.
  19. Das kenne ich zur Genüge; Speicher bei 99,7% - auf welches Icon kann ich verzichten, was kann ich einfacher gestalten... Aber die zweite Sprache belegt so gut wie keinen Speicher. Ist lediglich ein freier User-Toggle notwendig.
  20. «Repley не может работать должным образом в режиме Temp Sensing, потому что Repley является режимом управления питанием с точки зрения параметров изменения сопротивления.» Это верно, воспроизведение работает только при обнаружении изменения сопротивления, поэтому я выбираю способ обнаружения Temp-Sensing. Однако, поскольку это не обязательно означает, что управление TC возможно, я включил переключатель режима TC. По моим наблюдениям Replay в режиме TC игнорирует настройки температуры, а также настройки мощности в режиме питания. Может быть, я ошибаюсь, но это мои наблюдения. «Обратите внимание, что Repley всегда находится в режиме Power на основных темах, что означает, что обнаружение Temp Sensing не активно.» У меня будет больше времени, прежде чем я вернусь и снова перейду к стандартной теме и к моим мыслям более обширный тест с различными проводами и обмотками. «Спасибо за умный диалог!» Да, определенно - спасибо Google ....
  21. Здравствуйте, прежде всего спасибо за подробный отзыв. На экране профиля: я использовал Temp Sensing для определения режима воспроизведения, потому что не каждый (сложный) Temp Sensing Material Wire действительно подходит. Переключатель режима TC используется для определения температуры, но все еще контролируется мощность испарения; Тем не менее, я заметил проблемы с предварительным нагревом, а также с презентацией на Main-2, поэтому я должен позаботиться о выходных .... Переходы действительно не всегда очевидны, но я думаю, что они используются ежедневно. очень хорошо использовать.
  22. 7,480 downloads
    Tailormade themes for private use are available on request for almost every brand in almost every color - deutsch und englisch umschaltbar in einer Bedienoberfläche - too many details to list them; You will discover them in daily use and you will love them ... + Description_for _translation.txt If someone is interested in a version with a brand logo / background according to their own wishes - just leave a comment and I'll see if it can be implemented. See also my other Themes:
