Everything posted by CMK
If there are problems with the font used in the LCARS-theme, it may be due to the fact that you certainly do not have it on your pc. Therefore the download link can be found here: https://gtjlcars.de/LCARSindex/LCARSFONTS.htm Direct download LCARS GT3J.ttf If there are problems installing the font on Windows 10 - adding-new-fonts-to-theme-designer (Thanks to user Formula 1)
To use "Replay", "Watt" must be set as the material - this is what the developers intended. SS316 is ideal for this, but problems can also arise with complex wires (alien or similar). In this case the "Save Puff" field would not appear. A measurable change in resistance is measured and reproduced in "Replay" mode. This is also the practical advantage over the TC mode, in which a given resistance is to be achieved, which only works very imprecisely and therefore unreliably outside of laboratory conditions.
I have a very good treatise on the problems with temperature control and the advantages of "Replay" - unfortunately in German ... https://www.wolke101.de/akkutraeger-replay-modus/
In my themes you always see the calculated temperature of the last puff next to the set target temperature - the results are sometimes frightening and it takes a long time to adjust the two values by manually correcting the resistance.
SS316 - I just have to ask: 1.) simple or complex wire? Complex wire is difficult ... 2.) Do you measure the coil, or the resistance after annealing or the first use? The resistance of the SS316 changes very much after the first heating, which of course gives you completely wrong values. Basically, the temperature mode is very prone to errors, so I would recommend using the wire in power mode with Replay - works great.
How do I remove "Hello" text permanently in condition field ?
CMK replied to YuNVme666's topic in Themes and Custom Screens
Don't just delete the "Hello" text, use some spaces instead - just try it -
Version 3.5.3
593 downloads
This is a theme from the user "Astromike", he uploaded it on July 7th, 2017 and wrote the following: "Just got my Therion today and figured I'd try out the custom theme thing. Here's a Star Trek theme, complete with the LCARS UI. Note this isn't the first 75C Star Trek theme (and it probably won't be the last). Feedback welcome. " This comment follows on April 30, 2018: "PLEASE make it compatible with 250C !! Beautiful theme!" I came across this beautiful topic and thought to myself - it is about time! Here is the (almost) original design expanded to include the replay function. I also used a new toggle design here: -
Ich denke (!), da sind wir wieder beim Thema TSD; der Draht muss erst "getestet" werden...
nein, eigentlich schalten die Betriebsmodie, bzw die dazugehörigen Anzeigen sofort um - nur der Wechsel zwischen den Drahtsorten ( Watt <-> tempsensitiv) dauert etwas, bis er reagiert - ausser Du drückst etwa 1 Sekunde Feuer, dann springt er gleich um
Gerade da es sich bei dem "NewCoil"-Screen um einen Systemaufruf handelt, solltest Du - sofern Du den Screen ohne jede interne Bestätigung, z.B. "Atomizer-> Neue Wicklung->No, Old Coil" , verlassen möchtest, auch den vorgesehenen Weg gehen, also "Atomizer->Neue Wicklung->Abbrechen". Ich denke, wann immer Du versuchst, dem Systemaufruf mit einem von Dir vorgegebenen Sprungbefehl zu begegnen, kannst Du nur verlieren. Wie ich schon mal geschrieben habe.hatte ich früher auch die Probleme - reproduzierbar z.B. ein jedes Mal, wenn ich mein Theme aufgespielt hatte gleich als erste Meldung... Ich denke ich hatte zu der Zeit den NewCoil-Screen auch manuell angesteuert, um mir einen Screen zu sparen und ich hatte ihn seinerzeit auch mit einem "normalen" Sprungbefehl wieder verlasseen.
In EScribe gibt es dafür den passenden Befehl Atomizer>NewCoil>Abbrechen (glaube, so war der Weg; habe gerade kein PC zur Hand) Zur Not schau mal in meinem aktuellen Theme auf den NewAtty Screen auf den Cancel-Button ganz oben. Der bewirkt eine Rückkehr auf den vorherigen Screen ohne Änderungen an den Einstellungen.
Sei mir bitte nicht böse - bei allem Respekt vor der Arbeit - , aber genau aus diesem Grund bevorzuge ich textbasierte Themes; sie erklären sich selbst und benötigen kein Manual. Usability bedeutet für mich, dass ich ohne viel Probieren und Experimentieren zum Ziel gelange. Natürlich gibt es die Möglichkeit, über die Statusleiste entsprechende Informationen einzublenden, allerdings benötigt diese Platz, was in meinem Fall dazu geführt hat, dass ich die Anzahl der Screen wieder erhöhen müsste. Wenn ich mir die Downloadrate meines "Simple-Theme" anschaue, gibt es zwei Erklärungen: Entweder gibt es einen Bedarf, oder aber die Downloader wollen nur schauen, wie ich es umgesetzt habe. (Selbstverständlich gibt es andere Themes mit deutlich höheren Downloadraten, aber ich vergleiche hier innerhalb meiner eigenen und unter Betracht des Verhältnisses Aufruf/Download/Zeit)
... darauf läuft es hinaus - ich schaue mir in jedem Screen jedes Feld mit seinen Bedingungen an und hinterfrage mich selbst. Mit dem Wissen um Escribe, was ich in der Zwischenzeit erlangt habe, kann ich da mitunter nur den Kopf schütteln 🤪 wie umständlich ich es mir gemacht hatte. Immerhin - hat ja funktioniert....
Auf jeden Fall wird mein nächstes Update etwas dauern, da ich "hinter der Kulisse" einige Änderungen plane - zu viele Altlasten aus früheren Versionen der Screens, viele Bedingungen verschachtelt und das ewige Thema Speicherauslastung...
Interessant finde ich ja, wie nach so langer Zeit, die Themes für diesen Chipsatz entworfen werden, immer noch "neue" Aspekte dazu kommen und wie unterschiedlich die Ansätze sind. So sehr ich die Arbeit dahinter respektiere, kann ich mich z. B. für Icon-basierte Themes nicht erwärmen - bei Dir wird es sich vermutlich umgekehrt nicht anders verhalten 😎 Das ist ja hier das Schöne - die mögliche Vielfalt der Darstellungen
Ich denke, ich werde direkt den Hinweis "TC Error" anstelle der Ziel Temperatur einblenden... Im Moment fällt mir nichts besseres ein.
Ich habe die Watt-Anzeige grundsätzlich auch im TC-Modus aktiv, da der Chipsatz den eingestellten Wert im TC-Modus als Obergrenze verwendet. D. h., mit dem eingestellten Wert nimmst Du direkt Einfluß auf das Regelverhalten. Probiert es aus - wenn Du für Deine Zieltemperatur beispielsweise knapp 30 Watt benötigst, stelle die Leistung (im TC-Modus) auf 10 Watt und Du wirst sehen, dass der Mod nicht über 10 Watt geht und somit die Zieltemperatur nicht erreichen wird. Ich nutze diesen Umstand, indem ich im Preheat eine (zu) geringe Leistung einstelle und die Wicklung somit "sanft" auf Temperatur bringe.
In meinen aktuellen Versionen graue ich die eingestellte Ziel Temperatur aus, habe aber eine deutlich weitereichende Umsetzung vor Augen, welche ich in den nächsten Tagen umsetzen werde; einen konkreten Hinweis anstelle der Ziel Temperatur.
Vielleicht (!) besteht das Problem darin, dass der Chip nach einer Reaktivierung auf diesen Return-Stack zugreifen will, dieser aber durch die Deaktivierung, oder einen Neustart geleert ist? (Ich habe keine Ahnung von Basic, oder anderen Programmiersprachen 😬
