Canadianvape
Everything posted by Canadianvape
Any links to tutorial videos where they show where to change the wattage amount and the temperature would be really useful, spent the whole day combing the internet and watching videos yet none tell me where to change those values, the place they were in 1.5 is gone and I'm not familiar with this new EScribe .
I set up franks profile on my dna250C but I cant seem to find where or how to change the way temperature is configured in the main screen. what do i do to change it from 5c increments to 1c increments? thank you
Boost is set is EScribe or depending on your theme, on the device, it's for tc and in the 250c can be set 200/300/400w doesn't nesesarly use that, just makes ramp up to temp non existent. Boost is for power mode, I think it's more like % of what you have set another member can help you, I only use tc and replay.
Linux EScribe Suite Beta Thread
Canadianvape replied to James's topic in EScribe, Software and Firmware
those commands didn't work out, ill just use it on windows till I figure it out -
Can anyone help me with what code lines do I put on terminal in order to install in on ubuntu 16.04 LTS? It's opening as a text file, I do not know how to install Linux applications that are not in the ubuntu store without a dummy guide. Thanks -
"Off" message in temperature control when firing Therion DNA 75
Canadianvape replied to jsayers's topic in DNA 75
Happens with sdna75 aswell, reset to factory default temporarily fixed mine, don't got a clue on what causes it so I moved back to the 200. edit: changed the FW to the first version and resistance to 0, after reading it worked for someone, it's working now. -
Preset 5 should be power dominant by default, just change material if you are using TC.
That is a temperature dominant profile, uncheck the box. I like having 4 and 4,
Just arrived! Love the 2/3 cell option although it's tiny on 2 cells! It does not have the mod electrical resistance, shows 0, anyone know it?
Ordered yellow VT250s for Father's Day, should be here in 1-2 weeks
Happens with sdna75 aswell, reset to factory default temporarily fixed mine, don't got a clue on what causes it so I moved back to the 200. Ed: on another note it has no problem doing NICHROME temp control, nickel is tricky (have to constantly move the liquid control on Kay v5) 317l on ice3 works fine, at least it's not just only mine. Companies should really remove the "can't use nichrome" since it's actually in the limit range. -
Factory reset seems to have worked for now, thank you, I do not know if it will last though.
Ive tried factory reset and placing the new firmware, it works fine with nickel, haven't tried titanium since I don't like it personally, worked with rda then it has to cool for 10 secs to use tc again either it marks it at 400c+ and 1w or turns off both with ss316l and 317l, I'm just gonna hope for a new firmware update that fixes it... it's almost a year since last so hopefully evolv has collected enough data on the dna75 through EScribe to fix it.
It worked for a day, this morning the vcmt with ss316l is playing funny again, the tc is off after first puff, doesn't work for another 5 puffs then works again, no problems when using ice3 rda... same tanks and rta that won't do ss tc on 75 work fine on the 200...
That fixed it! Thank you very much... I'm still on the fence on the dna250 since I don't use 200w on the 200 ( 6 months and no problems)
It might be the 510 and/or wiring on my 75 then, it now turns tc ss316l off, works fine on the 200 though, got no idea how to fix it since I don't know what is broken. It does nickel fine, just not ss...
30Q is 15A CDC, to fire dna250 it requires 28a cdc 32a pulse (like 60/75/75c) so 97% means you have to buy lg hb6 (1500mha 30cdc) that is what is keeping me off the 250, already annoying that I got cornered to vtc4 on DNA200
