Everything posted by dwcraig1
That's correct, I don't think it will contain much if anything "extra" for the 75 though. It (SP3) has some nice additions to EScribe though. Worth getting IMO.
1.0.56 is for the 75....and 200. 1.0.42 is for the 200 only
The DNA75 does well with SS3XX Download for recommended EScribe is on this page. https://www.evolvapor.com/products/dna75 Otherwise you may use the SP3 "Early" from the 1st post of the Early software page. /topic/66731-topic/?do=findComment&comment=900119
The latest software is always in the first post of this thread: /topic/66731-topic/?do=findComment&comment=900119 It is labeled "Early"
I just got through 8 ml of juice, not a drop was left in the tank (2nd tank) of my Kayfun 5 with glass tank. Just after I hit 8 ml the next fire was with battery icon flashing. This is 40 watt, 50 wat preheat, my drags are just under 2 seconds so it was mostly at 50 watts. 3.6 ohm ss430. This was with an LG HD2, 2000 mah, 25 amp cdr, a 25r might do even better.
I have no idea, back then I was checking on battery life. I generally keep it on the upper end of the charge never letting it get very low. Using a Kayfun 5 clone instead of Bellus, 40/50 watt @ 430.....it never throttles down (normally) I'll see what I can do about getting an answer for you.
from CW"s site "Chemical Composition: Fe, <0.12% C, 16-18% Cr, <0.75% Ni, <1.0% Mn, <1.0% Si, <0.040% P, <0.030% S C Min - - Max - 0.12 Mn Min - - Max - 1 Si Min - - Max - 1 P Min - - Max - 0.04 S Min - - Max - 0.30 Cr Min - 16 Max - 0.18 Mo Min - - Max - - Ni Min - - Max - 0.50 N Min - - Max - -"
I ordered their shortest spool of 430, 10 meters I think, they sent me two 25 meter spools. Maybe because I said why I was buying it...LOL
I didn't notice anything regarding an off taste created by the wire it's self. That is actually why I bought it, I had read it tasted bad and didn't believe it so I bought some. I paid very close attention to how clean it was coming off the spool as well as if there was an odor given off when first heated. I found nothing unusual.
As I said in a few posts back. I use TCR setting of 0.00238. It's a different composition than Unkamen's 430, CW's contains Ni for one. The TCR I'm using is one that I came up with after much experimenting (not a scientist, not even close).
Yes I bought some of their 25 gauge SS430
It works fine, softer than Unkamen's but the TCR value has not been published as yet. Not relevant perhaps but I prefer twisted 28 gauge Unkamen's ss430 better than CW's 26 gauge 430. I probably would like twisted 28 gauge CW 430 just fine if I had that as well. I'm using a couple duals of twisted 25 CW 430 in an Aromamizer with TP, works well.
I'm using TCR value of 0.00238 for that ss430 from UK. For the Ni free ss430 like Unkamen sells the value is 0.00138.
I ordered one from here: https://www.evolvapor.com/products/custom
I'm going to have to guess at it but I suspect Kanger is still using that sliding 510 pin in the base of the atomizer as with the ST mini. Probably the pin is not getting pressed in good to make connection with the heads positive pin. Try pressing it in before screwing on the atty and see if that seems to help.
battery draining to 3.1V - doesn't this damage it?
dwcraig1 replied to alfie's topic in Batteries and Charging
In EScribe under the screen tab you can set it to show pack voltage. Perhaps increase your cell soft cut off. -
Well it's for sure better to not be taking your battery all the way down but 18650's are cheap and easy to replace, maybe carry another battery in a battery box if a charger isn't handy. -
What it drops to under load is of concern, less than 2.5 volts would not be good for the battery. Do you get the "weak battery" message or with the newer firmware the battery symbol flashes? -
Is this during use or is it draining while not being used for a while? -
Since it is close to the same (same actually) to what readings I got with tha DNA 200 I don't see any problem. Thanks though. Had I measured the voltage where the 510's wires are soldered to the board there probably would have been a different reading. The main grit of my post was that the output measured was the same on the DNA 200 with both firmware.
