Everything posted by dwcraig1
DNA60 Fire Button Miss clicks - replacement
dwcraig1 replied to AlexeyK's topic in Connectors, Components, and Accessories
The cover on the switch on the DNA board goes off and back on quite easily, it's not held on like the one in the video. This can be done without removing the switch from the board. Be sure to not loose the disc and remember which way it goes back in. -
I can't imagine a way
PWM is what I have been thinking about since reading your first post of this thread. Way back I bought a Smok Vmax and it pusled at around 96 pulses per second and really wasn't that noticeable. Soon they brought out the Zmax and it pulsed at around 33 cycles per second, that was quite noticeable and it was referred to as rattle snaking. Same for a lot of China mods of that era. Vamo was another.
For those that need to know what to do with the service pack SP45 as it is not a .exe. After you download it put it in C/ Users/ your name/ AppData/ Roaming/ Evolv/EScribe Suite/Firmware/DNA 100 Color Then use EScribe as usual to update the firmware.
⭐️ESCRIBE SP27 for Hyperion DNA 100C Link found here
dwcraig1 replied to eckotek's topic in DNA 250 Color
https://downloads.evolvapor.com/SetupEScribe2_SP27_INT_ServicePack.exe Install SP27 -
https://downloads.evolvapor.com/SetupEScribe2_SP27_INT_ServicePack.exe -
The only thing I can think of is look in your Programs and Features (add and remove) and see if Windows Driver Package - Dimension Engineering is listed. If not reinstall a full copy of EScribe making sure "drivers" box is checked during installation. If the option to select various items isn't there it's not a full version.
The cable has to be good enough to handle 3 amps as well. Have you tried other type C cables?
Odin Mini - Can't get anything to work properly
dwcraig1 replied to Dustie's topic in DNA 75 Color and 100 Color
At 2:38 there is mention of the media blasted 510 threads possibly causing connection issues. -
It's past beta version, if you would like to get it now it is here: https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=936820
Was there much trouble fitting in the larger charging/data board?
- 17 replies
My first one still looks like the day I got it, the finish is super strong, for lack of a better word,
- 17 replies
Here is a couple of screens of my Dovpo College DNA60. Of all my 60's it has the most voltage drop which I contribute to the limited contact between battery cap and case. The 1st screen is with a good Samsung 20S 30 amp cell. The 2nd screen is with a LG HD2 25 amp cell that is weak from age and no longer used. Your results should be better than my best results here, IMO. Both cells were 4.19 volts at start.
- 17 replies
- 1
I'm one of those that have had a XvoStick DNA60, my 2nd one, on order for a year and a half. I pretty much have no hopes of ever seeing it.
- 17 replies
- 1
- 17 replies
- 2
While you have found a pretty serious problem with the connection to the 510 pin I feel that it is not causing the problem you described.. I would be looking real close at the power connections from the cell to board/case. The cell you are using when in good condition should be plenty good enough at that power level but it may be weak from age, just a possibility.
- 17 replies
How is the battery ground connected to the board?
- 17 replies
- 1
- 17 replies
- 1
The devices are the same other than firmware.
In the bottom right side corner of Device Monitor in EScribe
Warranty service when connected to external USB charger
dwcraig1 replied to dl12345's topic in Installation and Assembly
Are you able to use a different cable with your external charger? I recall having a problem with getting "warranty service" message once but can't remember if it was from a particular cable or USB port. -
Will it connect to EScribe? You might get some useful info from there.
Your image show 6.54 volts output, this will be dependent on the cell's charge state. But lets just assume that is the boards maximum voltage output. Then figure in your .26 ohm SS coil. As the coil heats up the resistance will increase a bit, let's guess to 0.29 ohms. https://www.the12volt.com/ohm/ohms-law-calculators.asp Keep in mind that as the charge on the cells go down the voltage output will never be higher than the sum of the voltage drop. Example: cell voltage drops to 2.9 volts per cell under load. Max voltage output will not exceed 5.8 volts. If your settings call for more than that the error may show at end of puff.
