  1. You might want to upgrade your firmware. The .25 is the DL coil, not the MTL coil. The Max Puff Time limit is under the 'Safety' tab. Cheers.
  2. @TorturedZen IMHO the OP is purposely vague in his description, needs and intended purpose, so I'll take a wild a*s guess. As weed/cannabis is being decriminalized in many places, or CBD for medicinal purposes ........... one could put a non liquid (think weed/shatter) in a tank, and heat it till it vaporizes, then inhale after their timer ends for a full puff. Specialized vaporizers like that but much more rudimentary have been around for years for that market. OR SO I'VE HEARD Or perhaps has Strabismus, allowing them to focus that close. There are other specialized forums for that use case.
  3. Solidly attached. I'm not gonna start jamming anything anywhere. Sorry.
  4. Checked and crashed with High Sierra here.
  5. You need a minimum of Escribe SP18 for Mojave. Escribe Link found in my sig.
  6. Your post was edited, but you might want to describe how they had you build your new coils so others can benefit.
  7. @asmcriminalConsidering this ^^^ from over a year ago, what can I say. You can open a ticket with Evolv. Link in my sig
  8. @steamer861 SP18 now available, and works. Link in my sig.
  9. In your other post, you were already told 30 watts, boosting to 40. The answer will not change. Boost and warmth - 11. Tiny 900mAh battery (large for pods) Many are vaping in the 11 - 13 watt range on these non rebuildable pods. This is not an Aromamizer Titan atty holding 30ml of juice sitting on a 400 watt 4S Lipo.
  10. N80/Ni80 is a good old regular power/watts material (wire). No profile required. Having said that you can download curves from steam-engine or create your own within escribe 'Materials' tab. Welcome
  11. All I can think is that perhaps the coil was not at ambient temp when you went into temp control. Maybe take the atty off your mod, hit the fire button so the mod shows check atomizer, let the atty sit for a bit (say half hour), reinstall atty answer 'yes' for a new coil if prompted. Ideally it'll show a resistance lower than before. If that doesn't work, What kind of atty, and can you describe the coil
  12. Is your mod is actually a 3 button color screen Paranormal 250c? Last I checked the online manual was not for these newest boards. I'd suggest you start with a YT video or two. This one's pretty long but DJLSB Vapes is quite thorough. The 75C and 250C both have the same interface/themes.
  13. What type of material are you using AND post the link for the material file
  14. @Dougvapes If you're using SP17, I'd suggest you upgrade to SP18. Link in my sig
  15. @iltrainu Sp 18 is the latest and works. Link in my sig.
  16. Sp 18 is the latest. Link in my sig.
  17. My Rhombus panels are attached. No suction cup or alternates in the package.
  18. That mod's not Color (unless there's an update from March 2017), VT75D looks decent but not their latest.
  19. There's also a new Vapcige, Thinkvape Finder (2&3 battery), MadModder I believe, JacVapor Scotland. Around my area I'm now seeing mainly unregulated squonk mods, or high nic pods out the ying yang. I'm using my BB as a mtl box at 3x my regular nic when running around.
  20. I wouldn't do that. Lotsa good info here. And welcome.
  21. Yes Choose from the last 3 of your Printscreen. Details for each are on that same link for them.
  22. I'm using my own theme. There are many, some better documented than others. Here's one that I tested, for starters and replay enabled.
  23. SP17 had an issue. I'd use 15 or 18. 18 Intl found here (last post). IIRC, if you look at Profile 2 (Device Monitor), it's called Replay
  24. Can you swap the battery position of those same batteries within that mod, and see if that sag follows the battery. Printscreen afterwards appreciated.
  25. My opinions only Seems like replay is very much based on vw mode? <- Seems so, to me. And this is how I've used it. Do you think it’s even worth getting a replay enabled on tc? <- I do not
