That's not how this works. If the resistance is the same AND the watts are the same the watts will be the same.
When was the last time you used this mod, and did anything happen beforehand? For a blown battery chip, many times that Printscreen looks differently. At the same time, 0 volts remaining in a single cell is odd. If no one has any better thoughts, you should open a ticket with the Help Desk. https://helpdesk.evolvapor.com/?a=add
Never ran the US version actually, so not sure if Replay is on it. Other than that, nothing more I can think of for a 2 cell 250C.
Update to the early release, SP19. That should get you going. Escribe link in my sig.
Can you post a Device Monitor FULL printscreen. Moderator comment: Moved to more relevant area.
It'll work fine out of the box. Install escribe and see if there are any firmware updates. A battery profile to match YOUR battery type will ONLY make the icon on the display more accurate. Watch a video or 2 on your mod, and the 'search' feature here works. Enjoy your mod 🖐️
Does the resistance displayed for the coil match (or really close) what your other mods show? Using just pure watts on your Triade at the same value as your other mods should give you the same vape experience. Punch would cause a stronger vape not weaker, but not good to use on any of the mods for a straight up comparison between 2 mods.
How to download the theme designer
Wayneo replied to Snowman251's topic in Themes and Custom Screens
It's part of the escribe suite and not an individual item you download. Link here: -
Rebel 250c squonk mod battery sag when firing
Wayneo replied to Chief Salty's topic in DNA 250 Color
Chief, pretty sure @AMDtrucking also has one and has ripped his apart. Hopefully if you undertake this mission you have proper electronics flux and solder. 🖐️ -
Looking at those individual low cell voltages, your battery could now be ready for a replacement.
2 options. You can either start at step 4 below (by selecting the NiFe you have in the left window), completely overwriting what you have OR start at step 1 for brand new 'Materials' tab Click '+' under left window There'll be a new 'unnamed' material in left window. Bottom of the display, right side, click 'actions' select bottom option (TCR) enter what you want like 0.003 Just above graph, rename Name: unnamed to what you want. Follow posts by dwcraig here: https://forum.evolvapor.com/topic/66544-dna75-solidworks-iges-and-step-files/?do=findComment&comment=928634 Remember to upload to your mod when done
NiFe48 is NOT a standard/default material profile from Evolv that I have seen. (I checked 2 different C mods, but I could be wrong). You CAN create a custom TCR profile for your wire if you know what value you want to use.
Constant temp protect warning in wattage mode
Wayneo replied to Calvary_Creations's topic in Modders' Forum
Hmmmm, for starters you might get him to upgrade to the latest firmware (SP19). Also, that temp protect message behaviour has been changed on these color boards to also identify run-away ohms in non TC mode. He can address the firmware from the comfort of his home with no downtime. If that doesn't solve it, then you should look at the build. -
True dat. However we're talking output voltage (voltage supplied to the coil), which for a 2 cell mod is the the current pack voltage of the 2 cells. And for 3 and 4 cell mods, 10V max. (Less sag and inefficiences).
@Nexolek Page 2 of the datasheet shows Output Voltage 10.0 Volts Maximum, which can only be reached with a 3 or 4 cell battery mod.
I'd suggest this, now. EARLY SERVICE PACK EScribe Suite 2.0 SP19
Yeah, with the latest firmware. I surmise that the datasheets once published don't get updated. Some mods with the 60 chip don't have USB natively so be aware of that.
No. In 'DNA speak' you can only pre heat a TC material. But all is not lost. You can do a Boost Punch with any material in watts/wattage/power mode. It's a value from 1-11, which is a 1 second boost of the watts you've set. (effectively pre heating your coil)
Moderator: Moved to the DNA GO area. You'll see there are multiple battery posts.
- 1 reply
- 1
@cassdncr Yes. @saku No. Weak battery means your mod cannot supply the watts you selected, and has lowered the watts when you hit the fire button.
Along with @retird's advice, @Mehrdad Seeing as you're in Kuwait, the standard LostVape 6 month warranty (details in your booklet) should apply. Have you tried to contact your place of purchase.
Feature request : add profile ID in saved puffs log
Wayneo replied to Struktur's topic in EScribe, Software and Firmware
You are correct, and why I specified 'color screen'. The color screen 250 saves those fields as a delimited csv file for each puff. AND with much more precision than the non color 250 using 'save all data'. Not that I'm aware of, although there is a 'Data Aquisition' option in the 'Research' tab but I haven't played with it. -
Click the link, and choose EARLY SERVICE PACK EScribe Suite 2.0 SP19
