  1. Did you click the 'mod' button ? and what did it say?
  2. @Vapor2600 If you will be using 3 different battery models, why not just leave it at the default? You can only ever have 1 profile on the mod at a time
  3. Boost, even at a lower value like 3 will give you a warmer vape, but Replay really is the coil saver. No more dry hits, even if your pod is full.
  4. @Backdoor That vtbox dna 250 uses a LiPo battery, doesn't it? If the cell voltages are out of balance, a recovery charge might work. If you look in Device Monitor it will show the individual cell voltages. A 'weak battery' says one or more cells is triggering that warning. If you find any below 2V, you should recycle that LiPo
  5. Welcome. IMHO, from my take, burping (opening fill cap occasionally), turning down 'warmth', and using Replay will extend your pod life. Others have resorted to combing out some of the cotton to help them wick better. The better news is LV has announced new pods where the coil itself is replaceable and one is a mesh coil. IQS has also come out with a 3rd party pod. So all is not lost on your purchase. Hope this helps
  6. N80 is NOT a TC capable material/wire. Just use straight watts. There is also NO preheating/boosting of watts on the 75 at this time. Welcome
  7. 2 videos were posted for you, just before my post
  8. Your mod only supplies watts to the coils in various manners. I'd suggest you go watch video reviews on you RDA, or ask on other forums that cater to RDAs. You'll get better responses there.
  9. @mexus Try a few different themes, and you'll find one that mostly fits with what you like. Use Theme Designer with that theme and others to see 'how' they did it. The 'Main Screen' is really the heart or 'meat and potatoes' of any theme. Many will take the theme they like and customize it further to match their needs, and give credit to the original designer if they decide to publish it here. For now, just enjoy your mod
  10. Good to hear all is well, and you are back to a working state.
  11. @mexus Correct. There are NO native key sequence shortcuts. It's all up to the theme how quick and easy it is to get to.
  12. @Habubi Look at cell 2 in your video, that battery is showing like 2.8v (can't tell from fuzzy video, PRINTSCREEN would have been better. Did this just start? Did you have any leaking?
  13. Search box works here. It was a somewhat common problem, solved by bending the cable out of the way, like an accordian. In this search link, I think @Spector NS5 RD had the most detailed response. https://forum.evolvapor.com/search/?q=bend ribbon fire&search_and_or=and Welcome
  14. I'd suggest you do a backup of your current config if you decide to install that firmware, and need to go back. Until it's published here, officially by Evolv, you're on the bleeding edge, or to be more PC (an early adopter)
  15. Great information Thom. Stealthvape in the UK is responsible for LV repairs. I do believe if you contact them, they should be able to send you a replacement. But first, you should remove the other 2, lift that assembly gently and see if the broken remaining portion falls out. IIRC it's a T5 torx. If you're lucky, you can remove one of the others, and check for it if you have a specialty fastener shop close by. Good luck
  16. Welcome @Nicomanteno Have you reached out Ginger about your Boxer issues? Evolv is truly only responsible for the board, and if you look at the photos the Boxer has some custom parts. Personally, I'd try there first, Evolv second. Evolv IS the repair center for your Triad and now Drone so they're stocked with necessary bits.
  17. Welcome Markus This should help you. https://forum.evolvapor.com/topic/70557-nife48/?do=findComment&comment=930009
  18. So hey @lordmage, did my help completely squash all the errors? I haven't heard from you or @nibo. @FAQZY You might want to read the post directly above yours.
  19. Well, I should just say that's the same on mine. Really, really, really long story but you did see the atty warning. Welcome DJLSB vapes has some videos out for these DNA mods, escribe, etc. Themes are like the Wild West, from beautiful and functional to NOT. Search works, and we're a helpful bunch.
  20. Yo @Moparman, here's the link expanded https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/ I have 2 and 4 cell 250C. On the 4 cell I can get to 400watts with the international software. Make sure you choose that one. Down at the bottom, SP19
  21. Click the Link in my signature. If you scroll up and down, they're all there. After you download them they (individual firmware files) are in your FW folder Tools/Apply Service Pack at top left of EScribe to flash it. Just pick the one that you want. Edit: Is there any reason you don't want the most current?
  22. Yes, that file looks good. * A proper csv only only makes a battery icon or % more accurate. The board will protect the battery and itself but you cannot create a hard cutoff yourself
  23. @lupinehorror You can check that on board up button by removing 4 bolts. I'd suggest you do that first and check in DM. I'm assuming from your comments you're only sending in the board?
  24. Did you check the above? DW circled the button for you in red?
  25. @zark I have never heard or found any Ni200 mesh anywhere, ever. So why would anyone expect it to work with a Nickel setting. If you look at the OG post, after placing the mesh only portion in another atty it just does NOT work in Replay. Hmmm. As far as Replay goes ................. using SMOKs wattage ratings, does the resistance even rise while firing (from what to what)? Device Monitor printscreen while firing? What do they advertise for mesh material?
