What problem(s) are you actually having? NO YOU DO NOT Go read my last sentence again
Exactly what it says. That field ONLY ever shows when the field above it 'enable replay' is checked/enabled above it, and YOU have enabled Replay for that profile. Your mod toggles that 'playing' on and off.
Under the 'safety' tab in escribe, you can adjust that 'fill pod' sensitivity or even turn it off. BUT IT IS WORKING (high watts, low airflow) as you've found out, caused by the wicking not able to keep up.
OK, so you got A bad pod.
DNA 200 screen/ large basic theme on DNA250C ?
Wayneo replied to franticseven's topic in Themes and Custom Screens
I would say the evolv default theme fits that bill.- 1 reply
- 1
I don't know, but you can find the chip specs and dimensions on Stealthvape in the UK. I would measure the distance from the bottom actuator to the USB connector. Good luck.
- 1 reply
- 1
Post moved to proper area. What I typed still stands. Thank you.
If this is what your mod looks like, remove the panel over the fire button and see if the problem still exists. Is that a color screen on the mod? You can also (with mod plugged in) use escribe - Device Monitor and the bottom line will show what buttons are being pressed. Sounds like a stuck 'down' button, but is it from the board or panel.
Open a ‘Help Desk’ ticket with your suggestion Click Here
- 1 reply
- 1
Open a ‘Help Desk’ ticket ⬇️ Link in my signature line. ⬇️ Report back with their answers
You can lower or turn off 'fill pod' in escribe - safety tab. Load the latest firmware first.
How to DISABLE charge when connected to laptop
Wayneo replied to mactavish's topic in Batteries and Charging
If that feature works on the 60C you can try the serial command u=0 A to disable charging. -
I have no clue about the OXVA quality control. What I can say is I consistently get more than double your 2,000 puffs on the 0.6 pods, and my wife gets more than double what I get on the 0.8 pods. No sweetener DIY ejuice.
Read the post below and try the firmware if you want. https://forum.evolvapor.com/topic/76162-possible-bug-or-board-problem-and-firmware/
The U.S. version is feature and hardware limited due to the 2016 deeming date. Right down to the Micro USB connector on some boards. I'd always suggest the INT, created without restrictions. YES, not very detailed but they are here from the birth of escribe in mid 2015. RIGHT HERE IN THE VERY SAME area you posted. Naming might seem cryptic, but the 1st pinned post has software and changes, the 2nd pinned post is the discussion post. With the attention span of many and AI, your posts in here will generate more AI slop.
Temperature control with NiFe30 coil on Paramour DNA 80C mod
Wayneo replied to Sorin9898's topic in DNA 80 Color
None of those items exist as they are not required. Instead, you have Watts and Replay. Replay offers a repeatable puff and dry hit protection like TC did without the complexity. After you’ve taken a puff look down at the centre bottom area of your screen, and if you see the word ready, you can then enable Replay. Replay does require TC capable material for best success. -
There are many DNA60C themes under their Downloads tab. A good designer at a minimum would have written what features are included, some might just show the word. You don't need to upload to your mod initially. Download, and just start Theme Designer, open that file you saved, or even just double click on the saved file. You can use any color theme you wish to learn, beware their features might not be available for your board type.
I think you need at least a 'New atomizer' screen. The mod, depending on what was written into a profile and the variance detected now writes that new value into your profile or leaves the old. So I'd say 3 screens. Stealth mode has 3 options (Like where I showed above 'Atomizer Power' Above) there are 2 for stealth. The options for stealth level are 'Off', '1', '2', or '3'. Off = Stealth mode is disabled 1 = Dim 2 = Very dim 3 = Screen turns off You'll need to play around to see which you prefer. Years ago in my old tired mind, I think I used a toggle with the 1st field, on something totally unrelated like a battery icon.
These changes and most of what you wish for are found in/under Theme -> Theme Designer -> Screens. Although 'watts' are in 3 places, you should only need to change the Main Page. Easiest way IMHO is to Highlight the field, click options, choose 1 decimal and then the step size to 1 or 2 for point 1 or point 2. Enable 'don't show units'. Click OK. Or if you want to see the W you can go change the font size. You can actually setup conditions such as watts > 10 increment by .5, watts > 20 step by 1, etc. but that's more complicated (and has been done in other themes) I'll address your other wish list items later, or 'search works' better with 'all' better than 'any' (click the magnifying glass.
There is NO option for a background image.
Under the escribe 'safety' tab are options to lower or even turn off 'fill pod' warnings. There are ranges of resistance for what the coil Ω's displays as. Yours is now in the 1.2Ω range by 2 hundredths of an ohm. Your 'wrong ohms' issue is harder to explain but could be due to your coil raising its resistance due to getting crusty/carmelized from use and/or dirty contacts. Those factors or others, have raised the resistance to be in the 1.2Ω coil range My simple explanation - https://forum.evolvapor.com/topic/76108-oxva-xlim-pro-2-dna-resistance-issues/#findComment-945868 More detailed explanation (same post) - https://forum.evolvapor.com/topic/76108-oxva-xlim-pro-2-dna-resistance-issues/#findComment-945933
