  1. That's pretty funny considering these were 3 dudes with VC San Aio's. Then this happened.
  2. I'd search the large free 3D stl file sites, because this really smells like a spam magnet 🧲 to me, but I'll leave it until the first spam post.
  3. Search works. https://forum.evolvapor.com/topic/72299-getting-the-most-out-of-250c-in-tc-mode/?do=findComment&comment=941203
  4. The mod has the ability to have 4 languages stored with it, but only English is populated by default. You can use escribe -> Display, look for Language (far down the page). Using (1) as a sample, you can create another as French or just overwrite the English. Then 'upload settings'. If you want to share your translation for others, you can do that here.
  5. You don't need to post the same problem twice. Ever. What version of escribe are you using? Found in the bottom right corner of Device Monitor or in About escribe. Post a photo of your main mod screen.
  6. At some revision the DNA40 screen connection was upgraded to a ZIF connector. You ought to open a Help Desk ticket (link in my signature line).
  7. I have no idea what you're talking about, or if you did as I suggested beforehand. I cannot help you any longer, but someone else might. Failing that, you should open a 'Help Desk' ticket, link listed below.
  8. Load the latest version of escribe from here. https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=940849 Try plugging directly into your PC and not through a hub. There is no easy 'on and off' at all, only a lock, then a state of sleep, then a power down.
  9. Does your mod connect to escribe? Are you asking about lock and unlock, or 'session mode'? DO NOT TYPE IN ALL CAPS, IT IS ANNOYING.
  10. Do you know if that is an Evolv charger board? After removing the cable from the board, what was the battery voltage?
  11. What kind of mod is that? Have you done anything with the battery connections? It looks like the JST connector is not connected
  12. Wayneo
    Replay Mode
    Try taking a longer puff, like 3 seconds. Describe your coil? I run my GX's at mid 40's, 2x24/32 n80.
  13. Wayneo
    Replay Mode
    You can download the default theme from within escribe while your mod is plugged in, when it first starts up. Why do you want to remove 'Replay'? I use it with my 3 Taifun GX's just fine, even with Nichrome, SS, and Titanium.
  14. Wayneo
    Replay Mode
    No, not the way you'd think. You can zero out the field location and icons but You would need to check it all works the same. Why would you or anyone else want to remove 'Replay' from the mod? There are other 80 watt mods on the market with different boards, and cheaper.
  15. Is the lock resistor necessary when using the temperature control function? <- NO, not necessary if you have a stable atomizer as noticed in Atomizer Analyzer. For a boro device I'd leave it available. Also, why can't I set the room temperature? <- The room temp is read with the resistance, but you can make it changeable.
  16. The easiest thing for you is to find a theme that already has it and do the same for yours. IIRC Frank's theme among many others have a puff reset.
  17. The board must also be connected to a battery for escribe to recognize it.
  18. How can I help when that IS NOT an Evolv product? Find the pin layouts on line, or ask the manufacturer. This is now the third connector you are inquiring about, what happened with the connector from a few days ago?
  19. Post a photo of the mod screen. Just looked. It's not a DNA mod.
  20. For starters @balt did you ever try 'session mode'. You never came back and updated this post? @RicketyPumpkin Your vendor should have given you instructions on how to set this up based on their testing, and looking at those photos and your comments I don't think it will work for you. Any material file you used with Arctic Fox will work on your Therion. Hell, it started as a clone of escribe. DNAs have always had the ability to use TFRs and TCRs and AF copied that, so whatever you already have can be uploaded on your Therion. I'd really suggest you ask that dude with a thermocouple and same version crucible to share the material file with you. Could you post a link to their instructions?
  21. Using this diagram, follow pins 11-15 *Take note of pin 15.
  22. No, not normal. Reach out to your place of purchase, there should be a warranty of some sort. Failing that open an RMA at the Help Desk. Link in my signature.
  23. Correct, NOT a DNA. Their display and font is a dead giveaway. Especially that backward slash through the zero. 😉 If you're just a plain watts user it'll be a fine mod.
  24. Can you post a photo of the main screen. Lost Vape makes non DNA versions of many of their mods (while keeping the same name). That main screen will be different.
