JamezC Posted October 21, 2016 Author Report Share Posted October 21, 2016 So, maybe a few weeks ago, I bought a Therion BF and I've been having issues with TC using SS 316L wire. Quite often, I'll be taking a drag, and then the power will drop off and I'll get the "temperature protected" error message. Other times, It'll cut off right at the beginning of a drag. Sometimes, It'll work fine for a day or two at most, and then it starts doing it again. I've done some googling and troubleshooting myself but have not found a solution to the problem. I've just been using it in power mode for the past day or so, and it's been working well, but I'd like to figure out how to use TC without getting that constant error message.I'm using a Stumpy RDA with dual 26g SS 316L coils, 2mm in diameter, spaced, coming out to 0.33 ohms. The connection is solid and the ohms are stable, so I've already ruled that out. I originally had the same coil configuration, but with contact coils, so I thought maybe TC was wonky with contact coils, but building spaced coils didn't seem to make a bit of difference.As for the other information:Power: 33WTemp: 450FPreheat power: 40WPreheat punch: 5Preheat time limit: 1sI'm running the latest firmware for the mod, and I'm also using Steam Engine's profile for SS 316L. I'd appreciate any help in figuring this out! Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted October 22, 2016 Report Share Posted October 22, 2016 welcome to the forum JamezC. just so you know, the "temp protect" message isn't an error. it purpose is to let you know that you've reached your set temp and the dna board is adjusting wattage to maintain and not go over that set temp. i have that message turned off. i find it quite annoying, however some find it helpful. while vaping, if i reach my set temp very quickly and the vape drops off sharply, it's usually a wicking issue. since you're using an rda, what i would do is raise the temp slightly until i got the vape i wanted. 450F is a cool vape for SS, IMO, i tend to vape SS in the 500F and up range. i find it needs to be bumped up a little further in temp than my other TC wires. if you want, you could post a screenshot of device monitor while firing your SS build. device monitor comes in handy when diagnosing problems. Link to comment Share on other sites More sharing options...
JamezC Posted October 22, 2016 Author Report Share Posted October 22, 2016 Thanks for the welcome, Chunky, I appreciate the help. I actually forgot you could turn off messages, I'm glad you mentioned that. I've been vaping for right at 3 years now, but since this is my first mod using a DNA board, I'm still in the learning process. I generally like a vape a little on the cool side, but hopefully I can find a compromise where I won't be getting the temperature protected message constantly. Also, I'm not getting the temp protect message at the moment (go figure), but hopefully this screenshot might help some. Link to comment Share on other sites More sharing options...
VapingBad Posted October 22, 2016 Report Share Posted October 22, 2016 You are not getting close to the temp limit you have set in that screen (450 F) and just vaping at 30 W, it could just be that the cold res had not refined when you got the message earlier. Refinement is a process where the board tracks the coil res against the board temp as the coil cools during idle to get a more accurate base resistance reading. Link to comment Share on other sites More sharing options...
JamezC Posted October 23, 2016 Author Report Share Posted October 23, 2016 So, it takes a little while for the board to get an accurate reading of the cold resistance? Also, vaping at a lower wattage, I'm guessing that affects the refinement process? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted October 23, 2016 Report Share Posted October 23, 2016 correct, the board will continuously try to refine the resistance, usually settling at the lowest resistance it can read after a while. refinement will take place regardless of your set wattage. it will not refine if you lock your ohms or if you're not in TC mode.think of it as, the board gets an initial accurate ohm reading then tries to get an even more accurate reading via "refinement". Link to comment Share on other sites More sharing options...
engmia Posted November 14, 2016 Report Share Posted November 14, 2016 [quote=JamezC]So, it takes a little while for the board to get an accurate reading of the cold resistance? Also, vaping at a lower wattage, I'm guessing that affects the refinement process?[/quote]No, you should attach the atomizer when both the mod and coil/atomizer are at room temperature to get an accurate cold resistance reading. Refinement keeps monitoring the resistance when your coil cools off, and well.. refines the resistance reading. Usually those values should be incredibly small though, and you should get the cold resistance right off the bat. If you have normal behaviour, you shouldn't have to wait for the board to get accurate, and vaping at lower wattages definitely doesn't affect the refinement process. Link to comment Share on other sites More sharing options...
gsmit1 Posted August 29, 2019 Report Share Posted August 29, 2019 On 10/22/2016 at 10:54 AM, Spector NS5 RD said: just so you know, the "temp protect" message isn't an error. it purpose is to let you know that you've reached your set temp and the dna board is adjusting wattage to maintain and not go over that set temp. i have that message turned off. i find it quite annoying, SUPER helpful!! This has been jist killin me. Of course it males perfect sense once somebody points it out. How did you turn off the message though? I can't find it in Escribe. This is a DNA 60. Link to comment Share on other sites More sharing options...
Wayneo Posted August 29, 2019 Report Share Posted August 29, 2019 2 hours ago, gsmit1 said: ... I can't find it in Escribe Theme Designer -> Screens Link to comment Share on other sites More sharing options...
gsmit1 Posted August 30, 2019 Report Share Posted August 30, 2019 7 hours ago, Wayneo said: Theme Designer -> Screens What's the matter with these people putting a screen setting in the screen setting area? 🙄 Link to comment Share on other sites More sharing options...
zark Posted August 30, 2019 Report Share Posted August 30, 2019 9 часов назад, Wayneo сказал: Theme Designer -> Screens Что нужно сделать на вкладке Screens, чтобы отключить сообщение "temp protect". Или Вы имеете ввиду отключение функции "Сoil should be temperature-protected" Link to comment Share on other sites More sharing options...
Wayneo Posted August 30, 2019 Report Share Posted August 30, 2019 On 10/22/2016 at 10:54 AM, Spector NS5 RD said: just so you know, the "temp protect" message isn't an error. it purpose is to let you know that you've reached your set temp and the dna board is adjusting wattage to maintain and not go over that set temp. i have that message turned off. i find it quite annoying, 21 hours ago, gsmit1 said: SUPER helpful!! This has been jist killin me. Of course it males perfect sense once somebody points it out. How did you turn off the message though? I can't find it in Escribe. This is a DNA 60. @zark Comrade, considering the thread is about the message, and 'message' was mentioned 3 times in the post I replied to, my response was about ........ the message. 1 Link to comment Share on other sites More sharing options...
saschacolussi Posted September 9, 2019 Report Share Posted September 9, 2019 Hi guys, just bough my first DNA mod a lost vape triade 250c. I've got what the message means but just can't get it to stop I mean, the message still is on my mod settings but, what am I doing wrong? Can anyone help me, would appreciate it. Link to comment Share on other sites More sharing options...
gsmit1 Posted September 9, 2019 Report Share Posted September 9, 2019 1 hour ago, saschacolussi said: Hi guys, just bough my first DNA mod a lost vape triade 250c. I've got what the message means but just can't get it to stop I mean, the message still is on my mod settings but, what am I doing wrong? Can anyone help me, would appreciate it. As I learned myself, that message is simply saying that the build has reached and is being maintained at the set temperature. It won't and shouldn't stop unless intentionally disabled in Escribe. If you haven't done that, it will continue to display and that is by design. If you want it to go away, you need to do what the fella told me above. Connect your mod to Escribe, go into the screen dialog and disable that message. It might be slightly different for the 250C, but I'm sure the general principle is the same. Link to comment Share on other sites More sharing options...
saschacolussi Posted September 9, 2019 Report Share Posted September 9, 2019 the problem is, whe it reaches that temperature it simply stops firing. If disabled the message will it mantain the temperature? Link to comment Share on other sites More sharing options...
gsmit1 Posted September 9, 2019 Report Share Posted September 9, 2019 13 minutes ago, saschacolussi said: the problem is, whe it reaches that temperature it simply stops firing. If disabled the message will it mantain the temperature? That's a different issue that I don't know the solution to friend, though I'm sure there is one. On the DNA 60 I was referring to in this thread, the mod keeps firing whether the message was enabled or disabled. Link to comment Share on other sites More sharing options...
retird Posted September 9, 2019 Report Share Posted September 9, 2019 1 hour ago, saschacolussi said: the problem is, whe it reaches that temperature it simply stops firing. If disabled the message will it mantain the temperature? We need a lot more info so lets get started.....So do you vape it and it does reach it's set temp or does it reach temp message quickly? What type coil are you using? Is it a spaced or a contact coil? Link to comment Share on other sites More sharing options...
saschacolussi Posted September 10, 2019 Report Share Posted September 10, 2019 1 hora atrás, retird disse: We need a lot more info so lets get started.....So do you vape it and it does reach it's set temp or does it reach temp message quickly? What type coil are you using? Is it a spaced or a contact coil? I start vaping it and when it reaches the temp it gives me the message and stops firing. I'm using dual ss316L round wire and contact coil. This happens in temp control and in replay mode, what I've also noticed is that when that happens I change from one profile to another i.e. ss316l to replay and vice versa, and it starts firing again. Then, after some time it happens again. Not home right now, as getting home will send a picture of the mod monitor on escribe. Link to comment Share on other sites More sharing options...
retird Posted September 10, 2019 Report Share Posted September 10, 2019 Contact coils do not usually work well with DNA's. Try a spaced coil.... since this is your first dna you might try a single coil then add the 2nd coil if things go well with the 1 coil.... Link to comment Share on other sites More sharing options...
saschacolussi Posted September 10, 2019 Report Share Posted September 10, 2019 alright, gonna try that later, thanks a lot for the attention and help, much appreciated Link to comment Share on other sites More sharing options...
saschacolussi Posted September 11, 2019 Report Share Posted September 11, 2019 Still haven't tried the spaced coils, but here's what i was taking about. On the left the replay mode works just fine, on the 2nd puff it just stops working and on and on. Mod max output temp 315,5°C Link to comment Share on other sites More sharing options...
dwcraig1 Posted September 11, 2019 Report Share Posted September 11, 2019 With a live screen hoover your mouse on the batteries voltage drop and post what voltage it reads. Also post what your Cell Soft Cutoff is set to. Edit: I'm thinking that your voltage drop might be lower than your Cell Soft Cutoff. Link to comment Share on other sites More sharing options...
saschacolussi Posted September 11, 2019 Report Share Posted September 11, 2019 Here's my battery cell cut off. I didn't manage to recreatethe situation above, but as soon as i get that i'll post it here, thanks for the help. Link to comment Share on other sites More sharing options...
retird Posted September 11, 2019 Report Share Posted September 11, 2019 Your temp is set at 286C Your temp peak on the last puff shown is 300C.... 572F and if I'm seeing it right the power at 300C is almost 80 watts on your last puff shown but your set power at 70 watts.... What if you lower your preheat to 50 watts and the punch down to a much lower level? Could you be over driving your 70 watt setting with the preheat and punch being so high? Again.... contact coils are not usually used by most DNA users... Link to comment Share on other sites More sharing options...
saschacolussi Posted September 11, 2019 Report Share Posted September 11, 2019 I tought i should do the opposite. Set the power to what i would usually use with the coil and set the preheat to something a little higher and punch around 10-11, so it would reach the temp 286C quicker Link to comment Share on other sites More sharing options...
