mikepetro Posted March 24, 2016 Report Share Posted March 24, 2016 It would be nice if Evolv released Power charts, similar to the original ones in the specs, that represented a 2S configuration. Link to comment Share on other sites More sharing options...
VapingBad Posted March 26, 2016 Report Share Posted March 26, 2016 Just for you Mike, Kanthal limits from R= P/I.I = V.V/P Link to comment Share on other sites More sharing options...
Scarab Posted April 6, 2016 Report Share Posted April 6, 2016 blueridgedog thank you for the valuable information! I translated it to russian. Link to comment Share on other sites More sharing options...
dparisan Posted October 29, 2016 Report Share Posted October 29, 2016 Hello, I have DNA 133, connected to escribe and detect that 1 0f my batteries are dead then i change the power source to Power Supply option on my escribe upload it again after that i unplugged the usb cable Then i found that that i still can firing for quite sometimes, even tough the battery indicator is empty⦠Why is that⦠TQ for the attention Link to comment Share on other sites More sharing options...
VapingBad Posted October 29, 2016 Report Share Posted October 29, 2016 Power supply mode bypasses all the battery protection so don't use it with a battery other than for testing, but it looks like you have a wiring or connection problem with the balance connection I would try cleaning that first. Link to comment Share on other sites More sharing options...
rastapharoah Posted October 31, 2016 Report Share Posted October 31, 2016 Has there been a fix for the Vaporshark charging problem yet?Updated mine a few days ago and it only charges at a stable current at 0.5A. If I try 1A or 2A it ramps up and then goes back to 0. Link to comment Share on other sites More sharing options...
jeffwilliams81 Posted November 6, 2016 Report Share Posted November 6, 2016 Lost Vape Triade DNA200When I plug into my PC and run device monitor the battery "level" check box shows me "error". All other lines are showing data and my batteries are balanced and properly working. Any ideas on what would cause this and how I might be able to resolve it? Link to comment Share on other sites More sharing options...
retird Posted November 6, 2016 Report Share Posted November 6, 2016 jeffwilliams81 said:Lost Vape Triade DNA200When I plug into my PC and run device monitor the battery "level" check box shows me "error". All other lines are showing data and my batteries are balanced and properly working. Any ideas on what would cause this and how I might be able to resolve it?]So your device works properly otherwise? What is the Pack voltage and individual cells voltages. Maybe you could post a screenshot of the Device Monitor data.... Does it charge properly? Link to comment Share on other sites More sharing options...
rbodnar217 Posted November 15, 2016 Report Share Posted November 15, 2016 I recently put together a dna 250 dual 18650. When I connect it to any type of charger or even device monitor the mod gives me a check battery error when I press the fire button. Maybe 1 out of 10 times it will fire when plugged in. It charges full 2 amps and works 100 percent otherwise. How can I fix it? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted November 15, 2016 Report Share Posted November 15, 2016 rbodnar217 said:I recently put together a dna 250 dual 18650. When I connect it to any type of charger or even device monitor the mod gives me a check battery error when I press the fire button. Maybe 1 out of 10 times it will fire when plugged in. It charges full 2 amps and works 100 percent otherwise. How can I fix it? can you post a couple screenshots of device monitor, one trying to fire the device, another the mod sitting idle. make sure cell 1-2, pack, usb current and voltage boxes are ticked. Link to comment Share on other sites More sharing options...
rbodnar217 Posted November 15, 2016 Report Share Posted November 15, 2016 I got one when the mod is just sitting charging and the other shows it trying to fire holding the button and a small part where it actually fired. I have tried different battery sets with no difference. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted November 15, 2016 Report Share Posted November 15, 2016 rbodnar217 said:I got one when the mod is just sitting charging and the other shows it trying to fire holding the button and a small part where it actually fired. I have tried different battery sets with no difference. the phantom 1.75 volts on cell 3 looks strange, not sure if that's the problem or not. i noticed your running SP3 firmware on your device. there has been an update in the past week. SP5 is out now, why do you give that a try and get back to me.https://downloads.evolvapor.com/SetupES_1_2_SP5_ServicePack.exe Link to comment Share on other sites More sharing options...
rbodnar217 Posted November 15, 2016 Report Share Posted November 15, 2016 ChunkyButt200 said:the phantom 1.75 volts on cell 3 looks strange, not sure if that's the problem or not. i noticed your running SP3 firmware on your device. there has been an update in the past week. SP5 is out now, why do you give that a try and get back to me.https://downloads.evolvapor.com/SetupES_1_2_SP5_ServicePack.exeOh wow I thought it would notify if something new was out and I had the newest! And bam problem seems to be gone instantly. Thank you very much for the help and quick response. And I found the 3rd cell to be weird as well. Maybe it was seeing it as an out of balance cell, long behold its gone. Link to comment Share on other sites More sharing options...
Spirometry Posted November 15, 2016 Report Share Posted November 15, 2016 rastapharoah said:Has there been a fix for the Vaporshark charging problem yet?Updated mine a few days ago and it only charges at a stable current at 0.5A. If I try 1A or 2A it ramps up and then goes back to 0.SP5 will fix the Vaporshark charging issue. Link to comment Share on other sites More sharing options...
eliviardo Posted March 20, 2017 Report Share Posted March 20, 2017 Can someone please help me, I've had my finder dna250 for about a month now and it ran perfectly. Then all of a sudden it won't charge my batts anymore, i've tried every charger i have, swapped out cables but none of them did the job. The thing is that when i connect it to my charger the screen turns on and i can connect to escribe. The device is still perfectly working only now i charge my batts externaly, i'm a person always on the go cause it's my job and i don't have time to charge my batts externaly. Please help. Thanks! Link to comment Share on other sites More sharing options...
giz_60 Posted March 20, 2017 Report Share Posted March 20, 2017 eliviardo said:Can someone please help me, I've had my finder dna250 for about a month now and it ran perfectly. Then all of a sudden it won't charge my batts anymore, i've tried every charger i have, swapped out cables but none of them did the job. The thing is that when i connect it to my charger the screen turns on and i can connect to escribe. The device is still perfectly working only now i charge my batts externaly, i'm a person always on the go cause it's my job and i don't have time to charge my batts externaly. Please help. Thanks!Wasn't this addressed in a different thread yesterday? ...'DNA250 suddenly won't charge'eliviardo said:Hi, I'm new here and I hope you can help me.Been a fan of DNA chips ever since, and every dna chip mod i've used I charge via the usb port and everything worked perfectly 'til now. I bought a new device, Finder dna250w. I've had it for about a month and everything ran smoothly until all of a sudden it won't charge my batts anymore. Whenever i plug it to my usb cable the screen turns on(indicating it detects the cable I assume?) but it doesn't charge, also i can connect to escribe, and i've mingled with it following every tutorial in the internet but still didn't fix my charging problem. Also i can still use the device smoothly it's just that it doesn't charge my batts anymore, also my batts are good because I still use them only now i charge them via the external chargers. I'm always on the go and don't have time to charge my batts externaly. Someone please help. Thanks! Link to comment Share on other sites More sharing options...
Wayneo Posted March 20, 2017 Report Share Posted March 20, 2017 Answer here: https://goo.gl/csaLSR Link to comment Share on other sites More sharing options...
eliviardo Posted March 21, 2017 Report Share Posted March 21, 2017 I apologize i was just hoping maybe someone in this thread knows Link to comment Share on other sites More sharing options...
giz_60 Posted March 21, 2017 Report Share Posted March 21, 2017 Not a problem...it's basically not a user fixable issue..you will need to return your device... Link to comment Share on other sites More sharing options...
eliviardo Posted March 21, 2017 Report Share Posted March 21, 2017 Yeah, I just charge them externaly it's just really frustrating considering i'm a person that's always on the road Thanks! Link to comment Share on other sites More sharing options...
giz_60 Posted March 21, 2017 Report Share Posted March 21, 2017 eliviardo said:Yeah, I just charge them externaly it's just really frustrating considering i'm a person that's always on the road Thanks!I can relate to that...Edit: I always have a spare set of batteries when I am out & about...just in case... Link to comment Share on other sites More sharing options...
Entfybez Posted August 19, 2017 Report Share Posted August 19, 2017 my screen is only showing upload settings and lights up wen i only klick on the fire button or all the time lights when usb is plugged in on the pc. escribe not finding the device Link to comment Share on other sites More sharing options...
dberry19k Posted September 8, 2017 Report Share Posted September 8, 2017 Ok so I am having an issue with a build I am doing. The device keeps auto firing whenever I plug in the battery until it times out. The up/down buttons stop it from firing until I release them. I have disconnected, cleaned, and resoldered the out and ground wires three times and I keep getting the same issue. Did I fry the board or is there something I am missing. Link to comment Share on other sites More sharing options...
blueridgedog Posted September 8, 2017 Author Report Share Posted September 8, 2017 2 hours ago, dberry19k said: Ok so I am having an issue with a build I am doing. The device keeps auto firing whenever I plug in the battery until it times out. The up/down buttons stop it from firing until I release them. I have disconnected, cleaned, and resoldered the out and ground wires three times and I keep getting the same issue. Did I fry the board or is there something I am missing. I have had this issue with a fire button that was depressed due to build issues (button was too thick). Other than that, you could have a defective fire button. If you have a multimeter you can check the button. Link to comment Share on other sites More sharing options...
dberry19k Posted September 8, 2017 Report Share Posted September 8, 2017 1 hour ago, blueridgedog said: I have had this issue with a fire button that was depressed due to build issues (button was too thick). Other than that, you could have a defective fire button. If you have a multimeter you can check the button. You mean the fire button on the board is bad? I am running an external button and have triple checked my wire configuration and it's still doing the same thing. It is frustrating to say the least. If the fire button on the board is bad will I have to send it to evolv to get fixed? Link to comment Share on other sites More sharing options...
