Discharge Profiles (.csv for 2 & 3 18650 batteries (Sony VTC6 & Sammy 30Q)
6 minutes ago, giz_60 said:
Run the battery analyzer to get a more accurate profile for your cells...
Edit: The % indicator is an estimation of the remaining % of the battery left...being off by 1 or 2 % in no way hinders the operation of the device
Yeah I know that the battery percentage does not influence the functionality of the mod, I was curious to see if it can be fixed
can someone pls post the csv for triple Vtc6 konion battery( or is it the same with triple sony vtc6 battery). Thanks.
Edited by Vick
New user here. Sorry to be a bother but could someone PM me the  CSV for the 2 sony vtc6's  when they get a chance? Thanks in advance.
edit: also need the max peak/sustained input current. I saw something posted  a few pages back , but am not sure if thats for the sony vtc6's or a different battery.
Edited by SenorDolph
  • 4 weeks later...
  • 3 weeks later...
Op 20-3-2017 om 15:58 zei Ari0107:
ChunkyButt200 zei:
okie dokie,here ya go........... THIS CURVE IS FOR 2 SONY VTC6 18650 CELLS
THEIR CAPACITY (WATT HOURS) IS - 18.78
I USED A "CELL SOFT CUTOFF" OF - 2.6V.
txt Sony VTC6 Battery Curve.csv
 you might have to remove the ".txt" extension and leave the "csv" part for it to be usable with the escribe program, i think.
I can't download it cause i'm new member, Pm it to me please,
do you still have that file please , 2x sony vtc6
  • 1 month later...
i run battery analyzer to 3 x vtc6 on wismec reuleaux. guess what?!
analyzer run at 40w , and i got 31130 Wh with 2.8 soft cutoff ( 1.6Ω , 20awg single coil)
i m really happy atm ! i had 3 x 30q for 2 years (i still love them! no significant battery life drop still) , and the new results are excellent!
the longer battery life is noticeably!! (3x30q = ~27.000Wh vs 3xVtc6 = 31.000)
  • 1 month later...
  • 2 months later...
On 2/21/2017 at 12:31 PM, giz_60 said:
Here is the .csv file for 2 LG HG2's....csv LG_HG2 (2)_18650_3000 mah_17.43 Wh.csv
Settings as such:
Wh=17.43
CSC=2.8
Maximum puffs
Why are you wanting to turn off USB charging?
Edit:  Download the .csv file & remember where you downloaded it to...Go to 'Mod' tab...Load CSV...choose file you just downloaded...
Hello. Can this file be used for paranormal 250c?
8 минут назад, hado82 сказал:
If you use HG2,  why not?
  • 4 months later...
hello everyone i need cvs four 2 LG HB2 1500mAh batterys four my paranormal dna250c can some one help me out ?
Edited by ximie
  • 3 months later...
  • 4 months later...
1 hour ago, tankwart said:
Hello everyone,
I need a discharge profile  .csv file,for 1 battery Sony VTC6 18650.
I have only found for 2x and 3x in this topic.
Try those, they will be almost identical as these are per cell, up to 4.2 V regardless of the number of cells.
Thank you very much for your very helpful reply.I believe this will help others too!
Кривая CSV очень мало влияет на производительность мода. Исключение являются Sony VTC6 18650, по тому, что производитель допускает разряд до 2,5V (все стандартные настройки допускают разряд до 2,7V).  Если Вам не важно абсолютно точное отображение % заряда на экране мода то можно обойтись CSV по умолчанию. Если Вы хотите видеть реальную информацию про батареи, то необходимо провести анализ батарей на своем моде и со своими батареями. Если при этом Вы хотите продлить срок жизни батарей, то необходимо полученный Вами CSV откорректировать вручную в соответствии с формой кривой CSV которую дает производитель в технической документации.
  • 1 year later...
