dwaindablane Posted May 8, 2017 Report Share Posted May 8, 2017 That's probably for the best at the moment, the only reason to be using the new version is for the new DNA75C. But still its good to find these things now. Link to comment Share on other sites More sharing options...
James Posted May 8, 2017 Author Report Share Posted May 8, 2017 shrahman said:Have the "Soft Reboot" and "Hard Reboot" options from the previous eScribe versions been removed? I can't seem to find them anymore in eScribe 2.0Good catch. I've fixed this for the next EScribe service pack. Link to comment Share on other sites More sharing options...
dwaindablane Posted May 8, 2017 Report Share Posted May 8, 2017 Thank you James, for your quick response. Link to comment Share on other sites More sharing options...
James Posted May 8, 2017 Author Report Share Posted May 8, 2017 Tubbyengineer said:I've been having a poke and noticed that using Escribe 2 with a DNA75 the indicator light settings are not loading correctly when you load a theme.Good catch. I have fixed this. It will be working in the next EScribe service pack. Link to comment Share on other sites More sharing options...
James Posted May 8, 2017 Author Report Share Posted May 8, 2017 JimScotty0 said:On my DNA 250's, I also see it revert back to default settings on the following in Theme Designer no matter what I do:New Coil Yes/No: (I do use custom X/Y settings)Temperature Protected:Thanks! I've fixed this. 1 Link to comment Share on other sites More sharing options...
giz_60 Posted May 8, 2017 Report Share Posted May 8, 2017 Until all the bugs & kinks get worked out of the new version of Escribe, one could install the old version of Escribe as well, so as to make proper adjustments to the non-C board...just a thought... Link to comment Share on other sites More sharing options...
James Posted May 8, 2017 Author Report Share Posted May 8, 2017 I'm glad people are trying EScribe 2.0 with other boards. That's how the bugs and kinks will get worked out. 1 Link to comment Share on other sites More sharing options...
giz_60 Posted May 8, 2017 Report Share Posted May 8, 2017 James said:I'm glad people are trying EScribe 2.0 with other boards. That's how the bugs and kinks will get worked out. Just a suggestion if someone is attempting to make changes that Escribe 2.0 isn't allowing them to... 1 Link to comment Share on other sites More sharing options...
James Posted May 9, 2017 Author Report Share Posted May 9, 2017 I've posted up SP1. This Service Pack corrects minor bugs, and most significantly, it won't lose your DNA 60/75/200/250 theme settings any more.This should be usable on those DNA products. Let me know if you run into anything. Link to comment Share on other sites More sharing options...
spippo Posted May 9, 2017 Report Share Posted May 9, 2017 Thanks for sharing friend ;-) Link to comment Share on other sites More sharing options...
Wayneo Posted May 10, 2017 Report Share Posted May 10, 2017 @James Can you explain why, for the 1st time, there are 2 versions (U.S & International). Is it perhaps ONLY languages/localization? Thank you. Link to comment Share on other sites More sharing options...
Jolly Rodger Posted May 11, 2017 Report Share Posted May 11, 2017 James said:I've posted up SP1. This Service Pack corrects minor bugs, and most significantly, it won't lose your DNA 60/75/200/250 theme settings any more.This should be usable on those DNA products. Let me know if you run into anything.@James....still seeing this round robin issue ...giz_60 said:James, Unless I am missing something, it seems that whenever a screen is set to 'round robin', when it goes from the top field to the bottom field on the screen & visa versa...the 'status' is not updating to what is entered for that field, but rather retaining the 'status' of the field it was last on...hope that made sense...VapingBad said:I'm getting the same. Link to comment Share on other sites More sharing options...
giz_60 Posted May 14, 2017 Report Share Posted May 14, 2017 On 5/3/2017 at 10:05 PM, James said: Please let me know what bugs you encounter. Wider testing of the software will undoubtedly uncover some, and I'll be glad to fix them. Suggestions and other feedback are also welcome. @James When setting up a field to display the USB charging current (Miscellaneous → USB → Current), regardless of the battery's charge level, it is always showing 0.75A on the device screen. Inline meter is reading 0.11A on a fairly full charged cell, but the device is always showing 0.75A ? Only when the cell is fully charged does it change...to 0.00 Link to comment Share on other sites More sharing options...
James Posted May 14, 2017 Author Report Share Posted May 14, 2017 @giz_60 Like DNA 75, DNA 75 Color uses an integrated charging chip and has no way of knowing the USB current level. It does get a charge status from the chip, but it's off/on. As a result, what it shows there is basically a middle-of-the-road estimate of what it expects it to be. It will show either be 0.00 if not charging or 0.75 if charging (or 0.25 if in a safety low-current charging mode). Link to comment Share on other sites More sharing options...
giz_60 Posted May 14, 2017 Report Share Posted May 14, 2017 11 minutes ago, James said: @giz_60 Like DNA 75, DNA 75 Color uses an integrated charging chip and has no way of knowing the USB current level. It does get a charge status from the chip, but it's off/on. As a result, what it shows there is basically a middle-of-the-road estimate of what it expects it to be. It will show either be 0.00 if not charging or 0.75 if charging (or 0.25 if in a safety low-current charging mode). @James Thanks...another quick & possibly silly question. Recently received the Out Of Memory message. Went to check Space Used & got the message again. Deleted a couple of fields from a screen & was able to bring up the Spaced Used info....Now the silly question....what is the difference between the 2 memory slots listed? I know it should be obvious, but....And is there any way to utilize more of the On-Board Memory? Link to comment Share on other sites More sharing options...
James Posted May 14, 2017 Author Report Share Posted May 14, 2017 On-Board Memory is used for wallpapers, fonts, and screen configuration. Off-Board Memory is used for meters, pictures, and toggles, unless they update live, in which case they go in On-Board Memory. In the event Off-Board Memory is full, it *should* automatically move extra pictures into On-Board Memory. If it's not doing that (as it sounds like), that is a bug. Could you send me your ecigtheme? Link to comment Share on other sites More sharing options...
giz_60 Posted May 14, 2017 Report Share Posted May 14, 2017 3 hours ago, James said: On-Board Memory is used for wallpapers, fonts, and screen configuration. Off-Board Memory is used for meters, pictures, and toggles, unless they update live, in which case they go in On-Board Memory. In the event Off-Board Memory is full, it *should* automatically move extra pictures into On-Board Memory. If it's not doing that (as it sounds like), that is a bug. Could you send me your ecigtheme? Well..after having the issue, I had removed some things to help resolve the issue & now I can't seem to replicate it. If I run into this again, I will send you the file... (Off topic, I had 1 message in my inbox & tried to compose a new message but got a message stating Inbox was full & couldn't compose a new message. Deleted the message, sent myself another & got the same results again. Not sure if this is normal or not.) 1 Link to comment Share on other sites More sharing options...
James Posted May 14, 2017 Author Report Share Posted May 14, 2017 Good catch! I've fixed the Inbox message limit. Link to comment Share on other sites More sharing options...
copyman Posted May 16, 2017 Report Share Posted May 16, 2017 The bulgarian translation for Escribe 2.0 is made. EScribe.po.zip Link to comment Share on other sites More sharing options...
James Posted May 16, 2017 Author Report Share Posted May 16, 2017 Hi @copyman! Thanks for this. Could you please post it to https://forum.evolvapor.com/files/category/12-translations/? If you do not put it in a .zip (this forum should allow attaching .po files), in EScribe 2.0 someone can install it easily by going Help->Languages->Install. By the way, I just got a Bulgarian translation for this forum (from https://invisionpower.com/files/file/8529-bulgarian-translation-ips-4xx/). Does it seem good quality in your opinion? Thanks! James 1 Link to comment Share on other sites More sharing options...
giz_60 Posted May 16, 2017 Report Share Posted May 16, 2017 (edited) On 5/14/2017 at 4:55 PM, James said: Good catch! I've fixed the Inbox message limit. @James Maybe we need to start a thread for forum issues...I tried to edit a post, got a message the page wasn't found & now the 'Edit' link is gone from all of my posts Edit: Now it's back...but still missing on previous posts Edited May 16, 2017 by giz_60 Edit 1 Link to comment Share on other sites More sharing options...
giz_60 Posted May 17, 2017 Report Share Posted May 17, 2017 5 hours ago, giz_60 said: @James Maybe we need to start a thread for forum issues...I tried to edit a post, got a message the page wasn't found & now the 'Edit' link is gone from all of my posts Edit: Now it's back...but still missing on previous posts Now instead of 'Edit', it shows 'Options' and the only option available is 'Hide'...also, selecting 'General Discussion' under the DNA 200 & 250 section is showing a blank page....at least for me it is.... 1 Link to comment Share on other sites More sharing options...
MacVap Posted May 19, 2017 Report Share Posted May 19, 2017 On среда, 10 мај 2017 at 4:03 PM, Wayneo said: @James Can you explain why, for the 1st time, there are 2 versions (U.S & International). Is it perhaps ONLY languages/localization? Thank you. I would like to know this too, please. Link to comment Share on other sites More sharing options...
VapingBad Posted May 19, 2017 Report Share Posted May 19, 2017 48 minutes ago, MacVap said: I would like to know this too, please. 49 minutes ago, MacVap said: I would like to know this too, please. Obviously I am not James, but there is no difference in features at the moment, but as I understand it it's in preparation so manufactures can keep to the pre FDA regulation date (8/8 IIRC) features if new features are added in the future. 1 Link to comment Share on other sites More sharing options...
VapingBad Posted May 19, 2017 Report Share Posted May 19, 2017 (quote is acting strange) Link to comment Share on other sites More sharing options...
