Frank65 last won the day on April 14
Frank65 had the most liked content!
Full Name
Frank Mora
Location
Italy
Therion , Paranormal , Jac Vapour
11,667 profile views
Frank65's Achievements
Senior Member (3/3)
65
Possible bug or board problem and firmware
Frank65 replied to Vapors Tongue's topic in EScribe, Software and Firmware
Looks like both theme and autolock are working correctly now . 👍 -
@stephanedegee hello did you try to upload experimental software James posted above ? That solved for me the autolock bug For the missing profile , check in escribe "Hide this profile" box in unchecked Regards -
Hello Yes TC is working correctly. Also Temperature is showed correctly if no condition is used , I've tested this in some themes with same results . Probably the problem would replicate in another fields with complex showing\hiding conditions. have a nice weekend ! -
Dear James Thanks for your effort. First test on your experimental firmware seems to solve the problem , before autolocked was engaged randomly after 1-10 minutes , now after one hour mod it's still unlocked ->good ! You say "it may have other bugs" , yes you're right now some fields on theme are not visible anymore (example : atomizer temperature on main screen , reverting to last stable fw it's visible again) .-> please check This after around an hour of testing. Thanks and Regards ! -
Hello , same problem of forced auto locking here on a Sentinel dna60c. Ecig attached. Thanks for you attention 00041.ecig -
dna 250c Svapo Break Theme IT
Frank65 reviewed Svapo Break's file in DNA 75 Color, 100 Color, 250 Color
@abeirokid Hello and thanks , I try to answer your questions : - sleep mode : cannot replicate problem , if i set on device to 1 min , after 1 min my mod goes locked - click to lock : it is working when you lock ( if I change to 3 it locks after 3 clicks ) , to change unlock you should change "set unlock sequence" on settings menu on the mod. Personally i moved these parameters only one time because I like 3 clicks to lock\unlock instead of 5 , and never touched them since then and they're working , so sorry cannot help. maybe you accidently changed unlock sequence ? Please check that with escribe. regards
hello Unfortunately what you're asking it's not possible as far as I know 😕
