Everything posted by Lowbytes
Seems to be better - downloading the settings now 7seconds instead of 40 seconds
Just a short feedback The overall performance of escribe seems to be slower than it was on V.17 - with 18 and 19 i often see the "color wheel" - reading the data of my 75C device needs 45 seconds and longer - device monitor seems to be smoother in v19 than it was on v18 But everything seems to work but a bit "laggy"
So we have a confirmed Bug - Thanks @Wayneo for the confirmation - hopefully the Team will fix it!
Hmmm..... trying to link to my Problem - under High Sierra and Mojave ------ Maybe someone else can please check this - the problem exists on different machines - so it seems to be a general Problem
Yes - the placement of the 510 connector on the Hcigar VT75D is "suboptimal" ..... if you use an atomizer that may leaks e liquid can easy drop into the mod or the display ...... i had exactly the same problem After opening the mod for the screen replacement i found a some e-liquid inside of the mod!
Will this temperature sensing bug ever be fixed?
Lowbytes replied to Dejay's topic in EScribe, Software and Firmware
Hmmmm.....Never had any problems like you..........Maybe in fact that i always lock ohms and doing fast battery swap.......????? -
Usually it should be around 0,003 - 0,004 if everything is fine ........
Safe? Why not ? If it works with your coils - you may will get burned cotton if it runs dry - but first of all it should give you a constant vape experience - may the quote of constant puffs is not good enough to announce this feature official.... So happy - it´s there it seems to work good enough to use it ........ so let´s not discuss further - as result evolv may remove it ...... Hopefully NEVER happens ;-)
Maybe initially the PK Mode was not designed to be used regular ? Who knows - why announcing a feature that may work but not 100% ........... Happy that it could be used without official Support
As Soulvape already tested and confirmed even Kanthal and NI80 Coils running in Replay mode - you only have to switch to PK mode........
"replay" rumor mill's already turning
Lowbytes replied to Podunk Steam's topic in DNA 75 Color and 100 Color
AFAIK there is no US board - there are two versions of software and firmwares - for the US market and the int ones! Who will hold you up - doing things the way you do? ;-) So - if the int version is released ............................................................. -
Form follows function ! First of all WE are all happy that a mac version exists ! No matter if it looks like a Mac version or like software from the year 2000! For ME it makes no difference how it looks - as long as it is working as expected! For a long period of time we had to use Windows / Parallels to program our devices - this now is over - so for me no need to discuss the look of the mac version !!!!!!!!!!!!!! I´m that happy with this peace of (FREE) Software !
check atomizer message after SP23
Lowbytes replied to jhdelamain's topic in DNA 75 Color and 100 Color
Any update? -
I´m pretty sure that your problem is different - because you have "Check Atomizer" on every firmware even on SP22 - so you did the right thing! -
Exact my opinion!
As far as i know : Latest boards out of the RMA process are labeled as DNA250 but are DNA200 - So if escribe shows DNA200 it is a DNA200 ! Hopefully someone of the DNA stuff will look into this and give us a statement!
We´d already tried it via Facebook - For all native german speaking - you can also visit the German DNA Crew on Facebook - btw. My real name is Michael Brandt so feel free to contact me! -
With all of my DNA75C i´m on the latest SP - without any Problems (Only vaping in TC Mode) So i wonder why others having problems! Beside this fact i also wonder about the "silence" from Evolv........ -
Coil Face ID ;-) - You made my Day! Beside this - w´d like to use the boost with slow heating coils - not for more power - a lot of people asking for Preheat ! Most of them using chinese mods with custom firmware - always the same question " i wonder why my cheap mod can preheat and the DNA not?" (Kanthal non TC)
Maybe the ribbon cable is not connected correctly to the board - maybe the ribbon cable is sitting too close to the fire button (in some mods it is sitting that close to the fire button that it may got pinched) - so your still under warranty - i would try to get it replaced!
Try to use escribe - device monitor and look at the numbers - i´m sure that everything is fine except the Display is showing wrong
I would bet that the Display / Display ribon cable is damaged .....
