VapingBad
  1. Hit them up on social media of a forum where they have an active rep if you can.
  2. I believe auto tab order is right to left - top to bottom, taken from the first pixel hit, so if you have a row make sure the tops are level, and preferable all the same size.
  3. Yeah hidden only offered creating condition and not editing one, I have reported that a couple of times.
  4. Either with side cutters or snap off with pliers or put the edge in a vice and snap, they are designed to snap off and it doesn't matter if you don't snap the rails off in one go, do a little at a time if that feels safer. ETA you can clean up the edge after with a file or sand paper if needed.
  5. Made in Ohio USA
  6. Version 1.0.0
    1,193 downloads
    I made to be usable for you lot and to see how you can use conditions, gauges, toggles etc work as making themes has a significant learning curve. As a quick start base for you to use and abuse, no rights claimed use/share any of it. Looking forward to far more beautiful theme from you lot. Things that are not obvious are: Clicking the profile name on the main screen takes you to atty setting. Clicking on the profile name in the atty screen let you change profile. Clicking the Ohm symbol in the atty setting page remeasures your resistance. Temp is swamped for voltage on the main screen if temp protection is turned off or you have a non-temp sensing coil. On the recording screen if you click the number you are taken to the most recent puff and if you click on the graph you are take to the field selection screen. Most icons you can select will show some text in the status field saying what they do. In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status: default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field: atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage Enjoy
  7. There is a GearBest account, but sadly since I told them they were welcome here to help customers and not just post offers when they created the account (I even went back channel to ensure it was an official account) more than a year ago they haven't taken us up on the offer Vapor.gearbest.com
  8. The onboard charger is probably better than most, I charge 18650 externally for convenience, but am really liking a reasonable charge rate from a 166 with the max recharges, been searching for a charger that would do that for 3 or 4 years.
  9. No, there is only one battery profile slot on the device, you can't set C rating, but you can set USB current limit in Device Monitor\Diagnostics though the maximum charge rate is fine for all batteries you are likley to us (>= 20 A CDR). The best feature for preserving your batteries is maximum recharges that should double their life and only cost about 10% capacity.
  10. I haven't tried TD for the 200, but as a heads up the 75C the min step on temp and watts is 1. If you load an older version of EScrib and it accepts 0.2 then it's a bug in TD.
  11. I spose the general tab would over rule the setting, but I have been controlling it on the mod a lot lately, sometimes I have it a 5 mins sometimes 60 mins and sometimes off. I have just done a quick test setting to 1 min and checking it locked after a minute, then turning looked off and checking after 2 mins that it is unlocked, the second test failed, but connecting to EScribe it cleared the checkbox on the general tab and it is still clear on the mod. So it is looking like auto lock is not working, but I recall it working during the testing, for now I would max the lock time as a workaround.
  12. In theme designer \ screens then select the screen the lock is on on the rhs, then select the checkbox.
  13. It's definitely working for me, check the toggle control source is Display\Lock\Auto-Lock and the on and off images are correct.
  14. No just both power wires matching each other, not a big deal for such a short run though.
  15. Looks good to me, I would use the same gauge for both power lines between the board and charger (conns 11 & 12).
  16. You are right, the increased sag with cylindrical batteries will have a significant effect on the result. But the main purpose of the test is to make a charge vs voltage curve for you batteries and you don't have to run them that low while vaping. But because these devices throttle back when they hit the low cut off limit you would not be running them too low or damaging them. The capacity figure is correct and I agree you are unlikely to use it all, but that is personal choice really and you can just lower the figure.
  17. Just noticed StealthVape have linked to this thread in their blog, Hi guys! They are probably my favourite mod making and wire supplier, run for vapers, by vapers and been in the business for longer than I have been vaping (nearly 5 years now).
  18. It was an .ecigtheme file, if I read aright you have it now. IE can be a pain, still it's better than Netscape
  19. In the photos the 1st is when preheat is on, 2nd is preheat off, 3rd is dropped out of temp protection. 4th is TP-enabled=false, 5th is TS-Material=false. This is how the conditions are set: The TP icon: default shows on image, atty\temp-protect-enabled=false as the condition for showing the off image. atty\temp-sensing-material=false also for showing the off image. Text status default shows "PH" for preheat atty\preheat-enabled=false shows "---" atty\temp-protect-enabled=false shows "PWR" in yellow atty\temp-sensing-material=false shows "PWR"in yellow atty\temp-sensing-dectect=false shows "???" in orange (tested with an ss coil using a NI profile) Temp Field atty\temp as default atty\temp-protect-enabled=false shows diag\atty\voltage atty\temp-sensing-material=false shows diag\atty\voltage
  20. Opps, I just noticed I put the wrong status text on temp on the atty screen, if you downloaded it I would just edit it, but here is a fixed version. DNA75C VB001.ecigtheme
  21. It seems to be reading the ohms far too low, unless you have a big Ni coil then I would stay >= 0.05 ohm, if not Ni check the mod resistance is not set over 0.01 on the mod tab in EScribe.
  22. It will probably be a loose connection somewhere.
  23. If you want the theme I posted earlier it is here /topic/65562-topic/?do=findComment&comment=885174 it has examples of how to use conditions, gauges and toggles etc.
