Everything posted by dwcraig1
Gee, you must be asking about the DNA80C. No TC just Replay.
I'm still thinking about the problem with the Tita X. I wonder if the anodization on the edges of the chamber to deck is the culprit. Looking at a review it seems that the area is anodized. This one is Ti, the cheaper ones are anodized aluminum.
Dna60's generally will read slightly higher restances. By slightly I mean 0.40 ohms may read o.42 ohms.
Atomizer Analizer would read as shown in your video if the coil was warm, just shouldn't be that much of a change with SS316.
Your resistance change from cold to hot is way too much. Here are some things to be checking. Make sure the positive post on the bottom of the RBA is screwed in tightly. Is the positive on the RBA securely contacting the mods positive output, there have been cases where they barely contact because the legs of the boro box limits it. It your hybrid drip tip tight enough and does the chimney of the RBA stick out at least a little on the top of the boro box.
I'm going to say that you most likely need a new Color Screen. You might try rebooting the device though EScribe and see if any change comes about. Or remove and reinstall the battery. They can be found here: https://www.evolvapor.com/product-categories/replacement-parts And here: https://www.protovapor.com/product/replacement-dna-screen/
Overheating of the Board "Chip too hot"
dwcraig1 replied to cloudzey's topic in DNA 75 Color and 100 Color
I'm just guessing here as to what else might be the probem if it's not what's already mentioned. On the board there are two inductors and there have been cases where one either falls off or breaks connection. The board will work with just one. These are where I woud expect would be the component that would give off the most heat. Maybe you can see if the both feel about the same temperture after hard use. -
Are your other DNA100's that don't overheat in the same type of enclosure? -
problems with dovpo riva DNA 250c. help someone
dwcraig1 replied to DRiva91's topic in DNA 200 and 250
It looks to be running at your set wattage after boost is finished. Note there is current output from the battery and current output from the board and they will not usually ever match up. -
Can you post a screen shot of your device firing like this? Are you using temperature control? Check boxes indicated. -
Your last screen shot shows it throttling down from 34 watts to 29.38 watts. With the cell that you are using and firing at 34 watts that looks like there is still a problem. You seem to be on the right track to solving it. Is your adjustment screw on the battery cap at the end of it's adjustment? Meaning do you feel it may need to be holding to battery tighter?
" I noticed it kept climbing in charge when not using it to the point of gaining almost 10% charge within minutes, then taking a couple puffs, it quickly drops back to what it should be." Pretty normal behavior especially when charge is on low side. It is better to note actual standing voltage than to use the estimated percentage as it is just that (estimated). Here is a CSV for battery curve from my DNA250C, save yours first then give at a try if you want. It may be the same as yours or maybe different. Battery curve only changes percentages and battery bar, doesn't change how the mod works. DNA100C battery curve.csv
For what ever reason the board isn't receiving enough power from the cell (amps) do to a bad connection, could be cell fitment, bad solder joint, ect Use EScribe's Device Monitor to see your voltage drop while firing. Here is one of mine that has a poor battery to board connection. The voltage drops to 3.37 volts when fired at 45 watts. If it drops to soft cell cutoff of 2.75 volts it will throttle down the wattage. Check yours with Device Monitor.
The correct setting would be 18650 and cell soft cut off at 2.75 volts (default)
I would be looking to the battery cap for a poor connection. Try cleaning the groves on the battery cap and the groves on the mod for the cap with a cotton swab and alcohol. Does that screw adjustment on the battery cap come apart? Clean it's threads as well. Does the battery fit tight enough in the mod when the cap is installed?
https://www.protovapor.com/product/replacement-dna-screen/ And here but "Out of Stock" at the moment: https://www.stealthvape.co.uk/product-category/evolv/evolv-screens/
Dna60 Burnt pcb contact
dwcraig1 replied to king aries's topic in Connectors, Components, and Accessories
https://www.stealthvape.co.uk/product/evolv-dna60-usb-board/ or https://www.protovapor.com/product/evolv-1a-micro-usb-datacharging-board/ I would think that there are more places.
help Centaurus DNA 250c "Cant figure out the device version"
dwcraig1 replied to dupz's topic in DNA 250 Color
Have you tried another cable? Might be caused by dirty USB port on mod, lint from pocket, ect.- 9 replies
- dna250color
- escribe
(and 1 more)
Tagged with:
I have been mixing my own liquid for over 12 years now. I use to use sorbitol for sweetner but because of how fast it would gunk up my coils I switched to ethyl malto. You might want to research about using sucralose.
Yes, you got it. Use Device Monitor in EScribe to see it live. Be sure to check the "Power" and "Power Set: boxes.
